Old 06-17-2020, 10:17 PM   #526
Hubscrub
Cruzin
Hubscrub's Avatar
Re: Lime Wife's 67
Floor patch done, cleaned up the under side of the cab, did some seam sealing and primed it.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 06-17-2020, 10:22 PM   #527
Hubscrub
Cruzin
Hubscrub's Avatar
Re: Lime Wife's 67
I picked off the poor bondo patch the po did on the cab corner and patched it correctly. Found a shift knob hiding behind it. Other that the radio area I plan to fix I think I'm done with patches on the cab.
Proverbs 3:5,6
Old 07-25-2020, 08:13 PM   #528
Hubscrub
Cruzin
Hubscrub's Avatar
Re: Lime Wife's 67
Since "hopefully" the patch work on the cab is done (except radio have a patch can't find it right now) . I've been working on the frame and drivetrain. I painted and installed the trans dipstick, installed fuel pump, bent me a new 3/8 fuel line and installed. I ground down some of the rough places on the manifold and painted them with Eastwood manifold paint.I removed the exaust in one piece during tear down, it's not old and in good shape so I cleaned 8t and painted it with some high temp silver just to make it look a little better, we will see how it last. Being the ever not thinker of I should have done this near the first I tried to get it back in the frame in one piece I soon realized this ain't gonna work so I cut it at the muffler and installed and welded back together and got some new weld on hangers also. Now for the other side.
Proverbs 3:5,6
Old 08-07-2020, 06:09 PM   #529
Hubscrub
Cruzin
Hubscrub's Avatar
Re: Lime Wife's 67
Exaust done
Proverbs 3:5,6
Old 08-10-2020, 08:44 PM   #530
Hubscrub
Cruzin
Hubscrub's Avatar
Re: Lime Wife's 67
Bent a vac. line for the trans modulator,no idea what stock looked like the po just had a rubber hose all the way.
Proverbs 3:5,6
Old 09-11-2020, 04:59 AM   #531
Hubscrub
Cruzin
Hubscrub's Avatar
Re: Lime Wife's 67
Finally got the cab bottom painted.
Proverbs 3:5,6
Old 12-06-2021, 07:59 PM   #532
Hubscrub
Cruzin
Hubscrub's Avatar
Re: Lime Wife's 67
Where did a year go? I'm still working on her SLOWLY. My job when crazy over the last year and a half was working 7 days a week plus other projects . Getting better now so hopefully can get back going. I've been messing with trying to figure out what I'm gonna do for accessory brackets. I'm planning on installing Vintage Air so i want to move the alternator to the driver side. So I've been looking at their brackets, or alan grove brackets, just pricey to me for brackets. But i want it right so got to pay to play.
Proverbs 3:5,6
Old 06-11-2022, 08:32 AM   #533
Hubscrub
Cruzin
Hubscrub's Avatar
Re: Lime Wife's 67
Been working on patching the radio cutout. Back to stock look for me.
Proverbs 3:5,6
Old 06-12-2022, 03:49 AM   #534
OneOffStroker
Re: Lime Wife's 67
I don't know if you've figured this one out yet, but my go-to is to pull the newer serpentine setup off of the early 90's GM trucks. It's just two big cast aluminum brackets that hold the P/S pump, alternator (driver's side) and A/C compressor (Pass side) as well as the idlers and tensioner all built in. I don't know how your local yards work, but my local Pick-n-pull only charges around $80 for the brackets with accessories attached. I usually buy a new A/C compressor though for around $140 from Rock Auto. You will need a Torx set to remove from the truck in the yard though, in case you are going to get one.
1972 C10 "Shop Truck" Build - EFI, 5-speed, Posi, and Patina http://67-72chevytrucks.com/vboard/s...d.php?t=834292
1957 Chevy pickup - Twin Turbo 5.3/NV3500, Jag IFS & IRS, AirRide http://67-72chevytrucks.com/vboard/s...d.php?t=606987
Check me out on YouTube - "Tiny Garage Fabrication" http://www.youtube.com/oneoffstroker
OneOffStroker is offline   Reply With Quote
