#526 |
Re: 68 aka "Chained in Porterbuilt Prison"
![]() Do you have any newer pictures of the truck or any of the smaller projects? Thanks...... |
#527 |
67cheby
![]() Join Date: Sep 2008
Yes ....pics please !
Posted via Mobile Device |
#528 |
A guy with a truck
Cool idea for the door locks, I would just make sure the parts you use are either highly reliable, or easily attainable/replaceable...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#529 |
![]() Join Date: Apr 2007
Ok i'm back....swapmeets and honey do's ......just got one-piece -window in drivers side and finally got good news that the bearclaw works were i welded it in "without" any mods..looks like lock will unlatch with mechanical linkage from new ring brothers handles....due here any day.....got new door cylinders from GMC Pauls coming ...will mod with mechanical linkage for lock...So I welded up passenger door bearclaw bracket and that "pain-in-azz" curly bar for trim break....Thank God for rolocs discs!!......more this week.....jim
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791 |
#530 |
good to see you back!
#531 |
Good to see your progress on the one piece window install, looks great. I also was wondering about bear claws but was concerned about fitment.
By the way I really liked your idea on the switches.... Posted via Mobile Device
1967 GMC shorty Parts Pile: NoLimit, Accu Air, Kore 3, Matts Classic Bowtie, March Performance, Lokar, ScottsHot Rods, Vintage Air, American Auto Wire, Circle D, Accu Air, Borla, Budnik, Ididit, One Piece Windows, Doug Thorley, Pypes, AutoLoc, Porterbuilt, CPP, Dynamat, Dakota Digital, Fesler 1968 Chevy c10 shorty Stepper (Patina LS project) 1967 gmc custom Long Box (Farm Truck Project) |
#532 |
67cheby
Nice !
#533 |
The claws were thin enough to clear window edge..and linkage from handles "should" work mechanically...but switches and solonoids will work if it becomes a pain...If i stay with inside door lock knobs the action will be reversed...up will be locked...down unlocked...just a straight bar sliding up and down inside claw...may be able to use a "u shaped" arm under bar to reverse action back to normal...will see when all parts arrive...by the way when u see and here how these doors close with the claws....."big smile!!"....jim
#534 |
CCTek
Really Nice! It's about time you get back to work! It probably took you 20 minutes just to find your thread to update it.
![]() Keep the updates rollin!
Chad 68 swb Project http://67-72chevytrucks.com/vboard/s...d.php?t=262840 72 swb Project SOLD http://67-72chevytrucks.com/vboard/s...=1#post3993641 THANKS TO: Hermance Design (www.hermancedesign.com), Paradise Road Rod & Custom, Harry Opfer Welding, Tri-State Machine, Wegner Automotive Research, Nsane Hotrodz (www.nsanehotrodz.com), Clayton Machine Works, CCTek (http://www.candctek.com) |
#535 |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Killer work, looks great.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
#536 |
Tot Roddin'
Lookin' good!
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#537 | |
#538 |
Here's the pic of window and door pooch I'm concerned with....and then work on door jamb....start to finish 1 hr......made easy with cab cuts from a forum vendor....then before and after.....
#539 |
And last 2...before and after finishing pie cut.....will finish tomorrow..Anybody know what that damn round indention was for??..jim
#540 | |
![]() They were thinking WAY ahead.
Jim '71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E '57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works '87 BMW 325i - daily driver |
#541 |
CCTek
Looks good Jim, I see you what you mean about the pooch. WHich do you think will be the issue, the inner or outer or both? I need to watch those videos. Do you think this setup is better than the other that has the little triangle in the front corner? Who's power lift setup are you using?
#542 |
My 72 had the idention with a screw through it and a coiled spring mounted on the back side, unsure what it held but i put a washer in it and welded it up to smooth the area out.
#543 | |
#544 |
well I'm back again.....another swapmeet coming with changes....business always gets in the way!!....lol....these pics aren't for the faint of heart....1st is of how door looks before welding old handle mounts up...R.B. handles are cut flat faced so did not look good on curve of door where old handles were SO....had to move done 1 1/2 inch...actually looks better to me ...in a couple of days I'll let ya'll decide....cut out handle "cup" and holes to an easy-to-weld rectangle.....last two pics are what it takes to make all 3 lock positions work with bear claws and 1 piece windows....That's locking with key-inside rod-and power actuator....all welded to bear claw for 1 assembly .....biggest pain so far.....and no I will not market these!!.....what a pain in azz...lol....also notice at top of bear claw....that is extra lever bracket added for opening from outside handle..Glad I took geometry in school...getting the proper lever action was the most time consuming...............jim
#545 |
the indention held a spring lever on the inside of the cab that held the jack tools for changing the tires
#546 |
thanx...this cab had no hole just indention..was wondering.........
#547 |
![]() Join Date: Jun 2002
Super nice work ! Thanks for the word on the one piece door glass.
![]() click here to see my buildpage http://67-72chevytrucks.com/vboard/s...d.php?t=394656 ---------------------------------- 1979 C10 Silverado Big10 SWB Factory 454/400 Cardinal Red/Santa Fe Tan (original paint) 1969 Camaro X44 LS swap 1968 C10 SWB Fleetside (SOLD) 468BBC MultiPort TPI / Dynamic EFI P4 Black/Black 1963 Nova SS convertible (SOLD) 194 I6/ PowerGlide |
#548 |
67cheby
Wow
#549 |
Still Learning
Very nice progress! more pictures.....
#550 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
As far as the glass for the doors goes mine are either all the way up or all the way down a small prive to pay I think..??
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
