#526 | |
Almost Satisfied
![]() Join Date: Mar 2002
Re: 1971 Stepside LS Build
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
#527 |
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444 "It's only money". ![]() |
#528 |
Perfect color Shannon! I bet you are grinning from ear to ear.
Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
#529 |
Almost Satisfied
Continuing to work on the exhaust. I have very little clearance between the H-pipe and the trans cross member. I am not sure if this will present a problem. According to Holley the system should be rigid all the way to the headers and not use the flex pipe. The hangers allow for flex.
#530 |
Hey man, I have that same clearance in a couple spots and no issues hitting. My exhaust is using rubber isolators similar to yours. So that isn't rigid mounting. If you used the flex's at headers, then rigid mounting would be hanging the exhaust directly to the frame with no isolators. Right?
Anyway, you should be ok. If you grab the exhaust and rock it back and forth, does it touch? (put a rag in between that fresh paint first ![]() .
#531 | |
Almost Satisfied
#532 |
Same here. My exhaust system is that close to the frame and cross members in a few places. The only way the system can move is at the rubber in the hangers, to allow for heat expansion. You may want to keep an eye on it though since you have a nice paint job on your chassis, but I imagine the heat will have dissipated enough by the time it gets to the trans cross member. You're going to have a one of a kind special truck in the near future...
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
#533 | |
Roto Reuter thats the name...
![]() Join Date: Feb 2010
![]() https://67-72chevytrucks.com/vboard/...d.php?t=790866
~ Dan ![]() My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
#534 |
Almost Satisfied
Wrapped up the exhaust this weekend. I'm very pleased with how it turned out. I had to wire everything back up and put my temp hydroboost holder back on so I could fire it up and listen to it.
#535 |
That exhaust looks great man. The frame is just killer. You will have to keep us updated on those slip style clamps. I cannot speak with experience but I have read everywhere they don't hold over time. But I take that with a grain of salt cuz it's all coming from the internet
![]() I see how the exhaust appears to have shifted to the left on you both sides, it's close to frame up by LH bank header, and also close at the pass-thru on RH side cross member. But looks like there is plenty of room though. Exhaust moves SO MUCH when final welding everything, I learned this the hard way and had to cut and reweld a couple places.... It's still too close for comfort over my trans cross member... Love it man, can't wait to see it with the body on. ![]() .
#536 |
![]() Join Date: Aug 2018
That is one clean chassis. How was the sound? What I don't like about my black widows is the have the "clapping" sound (for lack of better term) at certain RPM's and throttle.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
#537 | |
Almost Satisfied
#538 | |
Almost Satisfied
#539 |
Almost Satisfied
Cut and polish continues. Hope to start assembly next week on the cab, doors, and fenders.
#540 |
Wow man, that paint is gonna be awesome.
#541 |
Almost Satisfied
The day finally came where the frame goes back to the shop to meet up with the body. I rolled it out in the driveway and waited for the trailer to show up.
Who knows if they will get it back on the frame when they said, but it feels like progress. Hopefully, it will be home this weekend.
#542 |
I'm trying....
![]() Join Date: Oct 2013
It is real progress. Great build. Can't wait to see them married.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
#543 |
![]() Join Date: Dec 2012
Your detailed planning and execution is coming together nicely. Excellent progress IMO.
Keagan 68 SWB C-10 original 350 A/C 503 Mean Green |
#544 |
One of these days very soon we're going to get an update and it's going to be a picture of body on frame and it's going to be huge! It's really a one-off truck.
#545 |
love the build....looks great. I was looking at your pics and realized we have very similar tastes on color and wheels LOL.
mine is 04-06 GTO Quicksilver metallic, with antique white lower. looks like the same silver you went with. Your chassis and build are on another level!!
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear |
#546 | ||||
Almost Satisfied
#547 |
Wahoo.. You are moving forward for sure. These fine details do take some time.
You will certainly enjoy it! Dave
#548 |
Ah cool....I was skimming thru and saw you were looking at GM truck silver of some type. The triple nickel Dodge color will look killer
I saw you discussing the Precision push on door seals...I just put the driver side on. Seems to be 1-2" short on overall length, and you gotta slam it firm due to the pressure. Maybe my door openings got too big LOL? I took a pic of the package tag, I think these are the '2nd' design but don't recall when I bought them. curious your experience with them when installed. I have a set of glue on soft-seal, might try that on the passenger side
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear Last edited by 71cadc10; 09-23-2020 at 07:10 AM. Reason: add pics |
#549 |
#550 |
It's a long time a comin' man!! I bet you're dreaming about driving that bad boy every night.
