#551 |
Re: Post Your Straight Six Pics!
Now, that's what I'm talkin' about!
![]() Is that one of those one-piece aftermarket Alt, PS & AC mounts?
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
#552 |
Nope, I took the vintage air bracket, cut it up, and modified it to fit over an HEI distributor, I took the P/S bracket and cut it up to fit over the turbo manifold, and I used the stock Alt. bracket and then used Chrome tube spacers to get it out further from the block so that I could get better belt contact. I also built a separate idler pulley for the A/C drive belt so that the A/C is a stand alone belt setup that can be taken on or off in less than 3 minutes. The Pulleys are from a SBC The P/S pulley I had to chuck up in the lathe and cut the rear pulley groove off of it.
Adam My 1967 C10 - Turbo 250 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=485843 (608) 214-8706 |
#553 |
Do you have pictures with all belts in place? I have a similar setup, but I can't tell how you are driving the alternator. The factory image only shows the PS belt and doesn't show the alt belt, but it is needed.
They show their Alt belt in front of the PS belt. On mine, the water pump pulley is agaist the pump so I am assuming they had a completely different balancer than I am using. An idler for the AC belt is a nice idea because of the long run, but I haven't found it necessary on mine. I wanted to mount the Ac compressor as low as I could on the 292 so I used a External coil HEI. Maybe too low. I still have to take the belt off and raise the compressor to get the cap off. Nice turbo setup.
'67 GMC 2500, 292, 4spd, AC Last edited by RichardJ; 04-12-2013 at 02:28 PM. |
#554 |
It's a 79 fj40 landcruiser. The engine's a 2F. I think it's 258cu.in. I wanted to convert it to sbc but it's so common in my neck of the woods I decided to leave the 6. I have a 292 though that would happily take the place of the tired old 2F in that engine bay. The nice thing about 6's is the diesel like torque, it's great for wheelin.
Overkill is an often underrated achievment |
#555 | |
#556 | |
![]() Join Date: Feb 2002
Two-fifties were what you got if you didn't fill in the SBC upgrade on the dealer RPO form.
#557 |
Here is my freshly rebuilt 250, mostly stock but with long tube headers. Might try dual or triple carbs in the future....
It's in my '69 c10 project truck, and is running but hasn't been on the road yet. [IMG] ![]() [IMG] ![]()
![]() Matt. 16:26 '08 Sierra Reg Cab, shortbox - daily driver '69 C10 LWB, 250, 3OTT - summer driver '98 STi Type-R (JDM) <SOLD> '97 WRX STi (JDM) <SOLD> |
#558 | |
When you hit the gas pedal and/or it's in gear, that's when the trouble starts right? Dano
![]() ![]() It ain't yours, if you didn't build it! |
#559 |
'68 SWB Fleetside '98 K1500 Silverado |
#560 |
Sorry havent replied. I think the carb will need a rebuilding but it is getting me back and forth to work. So that is a good thing.
Stovebolt-It is painted |
#561 |
born to lose
This thread rules! I have been wanting a 67-72 c10 with a 250 or 292 lately but they have been a pain to find.
_____________________ '67 Chevy Belair Wagon 283 Powerglide '68 Chevy II Nova 2 door 350 TH400 ![]() '71 Chevy C20 350 TH350 '71 Chevy C10 Burb 350 TH350 ![]() Burb Build http://67-72chevytrucks.com/vboard/s...d.php?t=475155 Nova Build http://67-72chevytrucks.com/vboard/s...d.php?t=498979 Wagon Build http://67-72chevytrucks.com/vboard/s...d.php?t=543052 Not giving a truck. |
#562 |
not mine saw it in town last week
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
#563 |
That is a sweet lookin' mill. What's he running for carbs? Looks like 2 Holleys... Two Barrels?
I covet his valve cover.
#564 | |
#565 |
Here's mine.
#566 |
I had a crazy idea to hard pipe my by-pass lines. It was a PITA to do, but I had a couple of reasons for wanting to do this.
![]() I know that the first thought is how difficult it will be to change the fan belt. I'm willing to accept that. That's why I put a union where I did. ![]() I figure if I don't like it, I can change it later. ![]()
#567 |
![]() 250 in my 70 GMC
Jason TEAM C10 HOT ROD POWER TOUR
689 Short Step 68 Step Trucks Sold: 70 GMC, 72 K5 Members met: Andy4639 GCncsuHD CSGAS zicc1835 hotrod farm truck Mingrao Bhelton brenthiggins |
#568 |
I'm planning on running Clifford's cam, intake, headder, and the 4bb carb plate. But I just can't decide which carb to use? And also convert to HEI.
" Dead Pumpkin" 67 Chevy short bed, 292 I6, 4spd manual. Fan of the "Slant Noses". ![]() 93' Toyota pickup 2WD 2dr and 32mpg. Daily driver. 300k+ Members I've met... Mister-B |
#569 |
The new and improved 292 in mine. Replaced the original 250 with this.
_____________________ Lou Axt, Jr. 1969 C10 Longbed 292 inline 6 Offy, Holley, true dual exhaust tows a 1966 Airstream Tradewind |
#570 |
I have a 292 with Clifford headers, Offy intake and 4Bbl Edelbrock 1404 500 CFM carb. I like it a lot. I ran the Holley 4160-R8007 390 FCM for 25 years, but after rebuilding the engine, the Holley crapped out [after only 250,000 miles!], Since a new throttle plate was almost as much as a new carb, I went with the AFB type Eddy. They're a lot easier to tune.
#571 |
The Offy intake with Holley 390 has been a solid performer for me. It has been almost 2 years since installing, and no problems to date. I did swap the electric choke for a manual cable choke, but otherwise haven't touched the carb since the first week. The truck sees some around town driving, but also tows my 24' Airstream regularly.
#572 |
I also converted my 390 Holley to manual choke, plus adding a 50cc accelerator pump and converting the rod-style gas pedal linkage to a throttle cable. I have Pertronix Ignitor II which works real good.
#573 |
Boy I can't wait to get my motor rebuilt and put some extras on it.
#574 |
#575 | |
That's some serious Truck Porn right there Nathan !
![]() ![]() -Nate Quote:
