#551 | |
Re: My new project 86 Silverado
anyone else?
My build thread... http://67-72chevytrucks.com/vboard/s...d.php?t=515829 Disabled Veteran 82nd Airborne Division Operations: Desert Shield, Desert Storm, and Uphold Democracy |
#552 |
Check out the vendor board here. Wes and Frank come to mind.
"I feel the need for speed!"... as soon as I am done with my nap. |
#553 |
thanks!
#554 |
will be going Thursday to pick up my engine, will post pics then, been a long time, and i'm glad it's finally built and paid for LOL...
#555 |
picked up my engine today!!!
#556 |
here it is, nothing fancy, stock colors for 1976, some cheesy chrome was supplied by the builder, i'll leave it
![]() it's what's inside that counts LOL will have an Edelbrock RPM intake and headers, I know a guy on another board that has a 87 swb wilh the same setup as mine, and I forget what headers will fit, but I have the email… Oldsmobile 455… specs... Block bored .030 over Honed with torque plates Decked .010 Mains align honed Crank turned/polished .010/.010, straightened Factory rods reworked, ARP bolts Factory cast high compression pistons advertised as 10.25:1 - .010 in the hole Hastings moly rings Clevite main/rod bearings Melling high volume oil pump/pickup/drive rod Rotating assembly balanced with dampener and flex plate installed Clevite cam bearings Bullet hyd flat tappet cam - .512 lift 230/284 duration on both int/ex on a 110 LS Matching valve springs 110lbs closed, 285lbs open Cloyes true double roller timing set J-heads reworked (bowl hog, not ported) milled .022, new 2.07 int and 1.68 exhaust valves New lifters/pushrods/rocker arms Stock 4 barrel intake Modified 800cfm Quadrajet, 76 main jets - 48 primary rods - DB secondary rods All Felpro gaskets
#557 |
Look at all that torque!
#558 |
looks so tiny in the picture… but 460+ cubes makes for serious torque… should be a blast to drive
i have another cool Olds build going on now as well… from an Olds builder in Florida... Olds 455… specs… Block bored .025 over for a Pontiac Icon piston Scat 7.00" H Beam rods "N" crank Balanced ARP main studs Align honed Square decked Bored and honed Block dressed and relieved Federal Mogul Main brgs Clevite rod Brgs Durabond Cam bearings Mahle Moly Top ring set - file fit. Cloyes Billet timing set. waiting on reworked C-heads and a Performer Intake from an Olds builder in Ohio… will decide on a Hyd roller cam soon...
#559 |
touched base with Jim Lehart, progress coming along on my 461 Pontiac... maybe 2 more months..
I should do a poll to see which one, the Olds or Pontiac gets installed...
#560 |
I'm biased, so I vote Olds! Also its been done several times. Not sure how well the Poncho fits? (mounts and exhaust?) Either way looks like fun!
#561 | |
wish I had kept my 67 step side... maybe i need another one lol
#562 |
been cold here for days and days... waiting on motor mounts to come for my 455... using Olds 403 mounts from a 78 Trans Am so I can use the standard Chevy frame side mounts...
like these...
#563 |
got the motor mounts for my engine... have to go back to Florida, my Dad's recovering from some surgery... will install and hook it up as soon as i'm back mid March
Going to be buying my gauge kit in the next couple of weeks, it's about the only electrical left that i need to get, then i can start wiring the truck...
#564 |
the weather is not motivating me at all...
#565 |
Poor truck. I hate snow.
Current Build 89 s10 ecsb 2wd 4.3/700r4 50k OG Miles Instagram- shaggin_s10 '86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt (Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD |
#566 |
X2-
#567 |
gonna get a lot of work done today... yeah right
![]() got 6" of snow last night... my 40 foot waterfall...
My build thread... http://67-72chevytrucks.com/vboard/s...d.php?t=515829 Disabled Veteran 82nd Airborne Division Operations: Desert Shield, Desert Storm, and Uphold Democracy Last edited by naphtali5725; 02-24-2015 at 11:38 AM. |
#568 |
![]() Join Date: Jun 2010
I hear ya. -1 here right now.
Roy 85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818 1987 R10 shortie |
#569 |
got my engine side mounts today... from firebird central.com
#570 |
Sweet! Thanks for Serving btw!
#571 |
#572 |
My dad was with the 75th Regiment and Airborne qualified.
#573 |
yeah the ranger regiment, all are paratroopers, all of us dumb grunts jumped together LOL
504th for me in bragg tell him thanks for his service
#574 |
after checking over my engine, the builder did not know a few Oldsmobile specific things... in the left rear of the engine, there is a 29/32" plug for the oil galley, behind that plug is the actual oil galley threaded pipe plug, well for the Olds engines, that galley pipe plug is supposed to have a .040 hole in it to oil the distributor gear...
so i have to pop that 29/32 freeze plug out and replace the galley pipe plug with the right one with the .040 hole in it... i already have them to replace, but is a bummer... delays delays grrrrrr ![]()
#575 |
Thank you, sir! And atleast you have the parts already. lol
