Old 07-14-2017, 08:28 PM   #551
Beau2a
Beau2a's Avatar
Re: What did you do to your Blazer/Jimmy today?
Installed 4 new ball joints and 4 new wheel bearings.
Beau2a is offline   Reply With Quote
Old 07-15-2017, 08:20 AM   #552
SoCoC10
SoCoC10's Avatar
Originally Posted by Moreyel View Post
Has anyone done it this way? Pros? Cons? I'm gonna take the decent floor from this 72 P/U And put it in my 72 K-5
I dont know why, but when I attach my pictures to this site, they're upside down. They're fine in my library. I tried turning my photos upside down, but no luck.
When I figure it out, I'll re-post.
The pickup cab floor is good. I know I'm destroying a good cab for the floor but I think it's better metal than the patch panels I see on line.
Any thoughts?
I bought a K5 carcass for a few hundred dollars the rear floor area. A day's work of cutting welds, removing carriage bolts and I had a factory floor for my medium Blue CST. Sold the Blazer carcass for what I bought it for originally = free rear floor for me. Plus the repop sheetmetal is never as thick as the original factory GM stuff. My two cents.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO
71' Cheyenne C10 Hugger Orange on Saddle SWB
Besides these two, too Many to count
SoCoC10 is offline   Reply With Quote
Old 07-15-2017, 08:25 AM   #553
SoCoC10
SoCoC10's Avatar
Helped my metal guy remove the front clip off my 72 Highlander. Getting rust repair to the lower "A" and "B" pillars, new torque boxes and outer rockers.
Old 07-15-2017, 10:28 AM   #554
DeadheadNM
Carpe manana
DeadheadNM's Avatar
In the first pic above you catch a glimpse of the screw used to affix the fender seal bracket used for CST applications - same as that used for the glove box hinge to the dash w captured washer.
Old 07-15-2017, 01:13 PM   #555
briank
I disassembled my rear hatch catch mechanisms and actually got my rear hatch to work like it is suppose too. Now waiting for a temp sending unit so I can button up the engine and drive it.
briank is offline   Reply With Quote
Old 07-15-2017, 09:20 PM   #556
broda1
broda1's Avatar
After my last post, I got an urge to upgrade my dash. Completed a Dakota Digital this afternoon with my son after the billet pedals and Holley carb upgrade from a few weeks ago.
broda1 is offline   Reply With Quote
Old 07-21-2017, 11:36 PM   #557
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Spent part of the day dunking replated frame clips for the rear wire harness in Plasti Dip.
Old 07-22-2017, 07:14 AM   #558
bobshotrodblazer
BigBlockBobby
Finished vintage Ac install
Bob
bobshotrodblazer is offline   Reply With Quote
Old 07-22-2017, 07:53 AM   #559
1972 Jimmy
1972 Jimmy's Avatar
I did the same thing to my wire harness clip. I was really amazed and how much the plastic dip shrunk when it dried. I had to dip them 2 or 3 times to match the OEM thickness.
1972 Jimmy is offline   Reply With Quote
Old 07-22-2017, 10:49 PM   #560
DeadheadNM
Carpe manana
DeadheadNM's Avatar
These seem to be really close with only one dip - I got lucky with the stuff I found at Home Depot. I looked but couldn't find any similar reproduced clips so back to use for another several decades for these.
Old 07-22-2017, 10:50 PM   #561
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Painted the replated frame clips for the gas lines, brake lines, tranny lines, and hose clamps.
Old 07-22-2017, 11:21 PM   #562
Beau2a
Beau2a's Avatar
drilled holes and installed hood letters
Old 07-22-2017, 11:58 PM   #563
Another 72
Removed my 35x12.50x16.5 BFGs, front 8-lug Dana 44, removed 4-inch leafs, installed new original height springs from Michigan Springs, and pre-positioned 6-lug Dana 44 from another 72 Blazer under front of truck. It was hot as hell so attaching the replacement axle will have to wait a bit.
Rob
"1967 Wanna Be" 1972 K5 Blazer
Another 72 is offline   Reply With Quote
Old 07-23-2017, 08:14 AM   #564
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
I bet you were sweating on that job! 😬
Tom Vogel is offline   Reply With Quote
Old 07-23-2017, 02:55 PM   #565
Beau2a
Beau2a's Avatar
Big time. I've been dreading this for a year, but I'm happy with how it turned out.
Old 07-30-2017, 01:35 AM   #566
3757chevy
3757chevy's Avatar
Wasn't today , but I got my Heartthrob Exhaust on last month and I got to enjoy the sound of it again Today. I don't even turn the stereo on anymore The right side pipe runs higher to the Thrush chambered mufflers because it has to clear the t-case , but the tailpipes still come out even.
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 07-30-2017, 09:01 AM   #567
bobshotrodblazer
BigBlockBobby
Made my own spare tire holder
Bob
Old 08-01-2017, 07:27 PM   #568
LuckyScott
LuckyScott's Avatar
Replaced the passenger door window regulator and glass. Had to disassemble just about the whole door to make it all work. Bought a new piece of glass with the metal channel already installed and it works great. All the old stuff was rusty and the regulator would not move at all.
Now it works all nice and the window is not all scratched up.
LuckyScott is offline   Reply With Quote
Old 08-05-2017, 07:48 PM   #569
kmg123
Put LED headlamps in. Gold color and white halo DRL's...
kmg123 is offline   Reply With Quote
Old 08-06-2017, 12:49 PM   #570
Blazer690
Blazer690's Avatar
Bought a NOS tilt column indicator housing from truck stuff for sale. This is what they look like after block sanding and polish. This time i'm going to clear it or they end up looking like primer.
Blazer690 is offline   Reply With Quote
Old 08-20-2017, 10:18 PM   #571
Moreyel
Active Member
Moreyel's Avatar
Finally started my rust replacement project. Bought a fine 67-8 pickup cab & chassis with good floorboards, etc. After discussion on this forum and seeing the cost of many parts this cab has that are good, I decided to cut the pieces out that'll work on my 72 Blazer.
Mounted a winch in the ceiling beams, pulled it off and am getting ready to start cutting.
I'll report and hope for advice as I go.
Deadhead, I welcome you to come see it anytime. I look forward to your input.
72 Blazer, 70 El Camino SS, Anniversary HD FatBoy, 2012 Ram 3500 4WD Dually, 17 Dodge Challenger, 80 Vette, 65 Chevy 3/4 Ton 4 W/D Pickup and some more.
Wife: 06 GMC Duramax 3500 4WD Single Wheel, 2016 BMW X3.
Next: Rust removal on my Blazer.
Thinking of putting a 50 Chevy cab on a 76 Chev 4 WD pickup.
Members Met: Aldtime, DeadheadNM
Moreyel is offline   Reply With Quote
Old 08-20-2017, 10:23 PM   #572
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Morey I want to see that! Looks great.
Old 08-21-2017, 06:11 PM   #573
psuedopimp
psuedopimp's Avatar
Got the replacement long bed truck floor cut down and ready to weld up.
psuedopimp is offline   Reply With Quote
Old 08-21-2017, 11:27 PM   #574
Stokester
Got the finishing touches on my doors and back panels! After much much deliberation I went diamond plate! Brushed it with a wire wheel and then shot a coat of clear. LED's turned out good!!
Stokester is offline   Reply With Quote
Old 08-21-2017, 11:28 PM   #575
Stokester
