05-16-2021, 10:43 AM | #551 |
Re: My 1970 GMC Project
Progress is going to be slow for a bit. Our little one was born on the 13th and she is perfect. This is Daphne.
05-16-2021, 02:40 PM | #552 |
Congrats!
05-16-2021, 04:55 PM | #553 |
Congrats!!!
05-16-2021, 11:08 PM | #554 |
Right on! Enjoy this time with your little one, they change so fast!
05-17-2021, 12:13 AM | #555 |
Congrats!
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444 "It's only money". |
05-17-2021, 01:31 AM | #556 | |
05-17-2021, 02:26 AM | #557 |
Congrats cute little gal look forward to seeing wrenches in her hands on future builds
I work on my stuff with my kids great to teach them how to do real things with there hands |
05-17-2021, 11:06 AM | #558 |
Almost Satisfied
Wow! Congrats. She is beautiful
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
05-17-2021, 11:23 AM | #559 | |
05-18-2021, 09:05 AM | #560 |
Daphne is absolutely perfect.
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
05-18-2021, 09:20 AM | #561 |
05-23-2021, 09:42 PM | #562 |
Congradulations.
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
05-23-2021, 09:48 PM | #563 |
I made it into the shop for the first time since Daphne was born. I have filled in the radius in the rear corner of the passenger rocker/cab corner. I then started to fill the leading edge of the rocker as it was much to rounded for my liking. Only a small piece of wire was needed to match the door to the rocker near the front.
05-23-2021, 09:49 PM | #564 |
05-28-2021, 12:24 AM | #565 |
Gaps are looking real solid! Keep it up!
05-28-2021, 12:50 AM | #566 |
05-30-2021, 09:14 PM | #567 |
Re: My 1970 GMC “Project Splice”
This afternoon I was planning to finish up welding the edge of the passenger rocker but that turned out to be a bust. I got all set up, turned on the welder and went to make a tack.....out of gas. Oh well, found something else to do for the afternoon. I cleaned up the upper windsheild area and got some marglass over the seams I welded shut. While I was there, I also filled in the spot welds under the lip of the roof edge. Once that was done, I tried yet another door I scored off of my uncle and bam! We have a winner. after a few more adjustments, I will be happy with this door as a start. The body lines are off very slightly but at least the upper window frame has nice gaps. I can always adjust the body lines with filler.
05-30-2021, 10:27 PM | #568 |
Congratulations on the newborn! Truck is looking awesome. I am jealous of the body/welding work. That's probably my weakest area unfortunately. I'll stay tuned and see if I pick up a few tips from you.
05-30-2021, 10:31 PM | #569 |
Thanks man. It's been pretty cool being a dad so far. The biggest thing I can recommend is practice when it comes to welding. Stay tuned and you see alot of body work Thanks for the compliments on the truck as well.
06-06-2021, 06:57 PM | #570 |
Progress continues on the passenger side. I got the rest of the rocker edge welded up and smoothed off. I also got a good coat of marglass laid down on the outside of the rocker. Should be done with welding on the cab now for a while so hopefully I'll be laying down some regular bondo soon.
06-06-2021, 10:37 PM | #571 |
First of all, congratulations on the arrival of little Daphne, she is so precious!
You really had a lot to deal with on this truck, and I thought the rust issues on my truck were bad... You are doing a spectacular job! I still have a rust area up under the dash where the cowl inlet rusted through. That will be a challenge to fabricate the replacement patches and get them welded in. Once that is done, I can epoxy prime the cab interior and apply the Lizard Skin. Have you given any thought to applying any sound deadening/thermal barrier? My goal is to do such a good job rust proofing my truck that it can be a daily driver without the worry of it rusting out again. Again congrats on the beautiful baby girl and the work you have done on your truck! |
06-06-2021, 11:10 PM | #572 | |
06-07-2021, 07:40 AM | #573 | |
06-07-2021, 08:58 AM | #574 |
Are you doing liner inside the cab? Im trying to figure out if I want to or not.
70 C20 Build link : Project Montezuma http://67-72chevytrucks.com/vboard/s...d.php?t=794479 How to repair that rusted out 67-72 c10-c30! Please subscribe! https://www.youtube.com/c/MaycoCustomRestorations |
06-07-2021, 09:51 AM | #575 |
I'm not decided on that either. I was leaning more towards just doing the underside but not too sure. Does anyone think it would be beneficial to do both sides?
