Old 03-17-2019, 11:25 PM   #551
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: "Crewcab Jake" the 84 to 74 conversion
I temporarily put the finished pieces back together . I ordered a can of SEM primer and a can of SEM Ivory. It should be here tomorrow so I can see what it looks like soon
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-19-2019, 10:18 PM   #552
N2TRUX
Happy to be here
N2TRUX's Avatar
I decided to use SEM brand primer to ensure proper adhesion and smooth out some small imperfections on the console pieces. SEM offers more than one primer. The one used here is a flexible primer and surface which is ideal for my intended results
Articles-
"Refining Sierra"
Old 03-19-2019, 10:27 PM   #553
N2TRUX
Happy to be here
N2TRUX's Avatar
I sprayed a few light coats on the interior of the console. I will scuff this to soften the rough edges before adding color.
The exterior surface got several wet coats after initially cutting in with dry coats. Once it cures, I'll scuff the areas that need attention and give it one final layer before color.
Articles-
"Refining Sierra"
Old 03-19-2019, 10:36 PM   #554
N2TRUX
Happy to be here
N2TRUX's Avatar
I ordered a can of SEM Ivory #15853 based on a color chart. Unfortunately the color is actually lighter than the sample show. More importantly its lighter than the seat color which is not what I'm after.
Articles-
"Refining Sierra"
Old 03-21-2019, 09:55 PM   #555
N2TRUX
Happy to be here
N2TRUX's Avatar
So the SEM Ivory was a no go. Based on that color being much lighter than the chip, I decided to go darker. I was hoping the results would be the same and I was correct. The new color is SEM #15843 Medium Parchment.
Once again its virtually impossible to photograph accurately. It is a very close match to the vinyl color of the seat, but it is a shade or two darker.
Articles-
"Refining Sierra"
Old 03-21-2019, 10:01 PM   #556
N2TRUX
Happy to be here
N2TRUX's Avatar
If your wondering why I'm using rattle cans vs spraying from the gun, its about consistency. I have had difficulty getting my local automotive paint store to mix SEM colors consistent in color. Rather than fight it, I decided to find an off the shelf color hoping to have better luck.
I have a lot of pieces to dye, and I want them to match.
Articles-
"Refining Sierra"
Old 03-21-2019, 10:30 PM   #557
N2TRUX
Happy to be here
N2TRUX's Avatar
Now that I have a color I'm pleased with I can try to have it mixed and hope it's the same.
Meanwhile heres a sneak peek of where I'm headed. The lighting makes the seat look a bit yellow.
Articles-
"Refining Sierra"
Old 03-22-2019, 07:34 AM   #558
Joseog83
Joseog83's Avatar
Looking Great!
Joseog83 is offline   Reply With Quote
Old 03-22-2019, 09:13 AM   #559
rustytruck50
rustytruck50's Avatar
Nice!!!!!!! That's gonna be really sharp!!!!
-Doug
'05 RCSB Sierra 2WD
'71 Sierra 2WD Longbed
'98 Silverado K1500 Xcab...sold
'72 Highlander"Raymond"...sold
rustytruck50 is offline   Reply With Quote
Old 03-22-2019, 09:43 AM   #560
Hammered 77
Hammered 77's Avatar
Ken, I see you used SEM primer first and then the SEM dye. Is the primer a good adhesion promoter vs there adhesion promoter or do you use both?
Rick
Hammered 77 is offline   Reply With Quote
Old 03-22-2019, 10:31 AM   #561
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by Joseog83 View Post
Looking Great!
Thanks guys. I'm trying to find a combination that retains the vintage heritage with a bit of contemporary styling.
Articles-
"Refining Sierra"
Old 03-22-2019, 10:44 AM   #562
N2TRUX
Happy to be here
N2TRUX's Avatar
Rick
Rick, this is the first time I have used the SEM primer. In the past I have not needed to fill minor blemishes so I do my usual prep followed by Bulldog adhesion promoter. Due to some small scratches, and a dark to light color change I decided to try the SEM Primer.
I'm very pleased with the results. It lays down smooth and dries quickly. It does leave a lightly dusty surface that needs to be scuffed with Scotch Brite, but I would normally prep any primed surface anyway.
After it cured over night and I scuffed it with Scotch Brite, I gave it a scratch test with my fingernail. I was not able to remove the primer without using excessive force. The primer left a slightly porous surface so I felt confident that adhesion was not a concern.
Normally I'm one to lean toward "better safe than sorry". I decided to forgo the Bulldog not wanting to add any more material build than necessary.
PPG bought out SEM and the prices have gone up 35%.
I'm going to compare the cost of primer vs Bulldog and decide how to proceed on the remaining parts.
Articles-
"Refining Sierra"
Old 03-22-2019, 11:23 AM   #563
SCOTI
SCOTI's Avatar
….PPG bought out SEM and the prices have gone up 35%....
That's jacked-up. SEM was/is a very consistent go-to for many that didn't have the equipment or workspace for a pro (or similar DIY) set-up.
Now because PPG owns SEM, prices suddenly need to go up 35%..... ???
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 03-22-2019, 11:51 AM   #564
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by SCOTI View Post
That's jacked-up. SEM was/is a very consistent go-to for many that didn't have the equipment or workspace for a pro (or similar DIY) set-up. Now because PPG owns SEM, prices suddenly need to go up 35%..... ???
Scoti prices have been climbing anyway. I used to pay 12.00-14.00 a can for SEM. Now its averaging 20.00 a can or higher. I found the cheapest to be at O'riellys and they actually stock it in their warehouse.
I'm am in contact with Tammy from Tamco Paint. They offer premium quality paint at a very affordable price. I going to see if her products can be used as a vinyl dye.
Articles-
"Refining Sierra"
Old 03-22-2019, 08:51 PM   #565
1970SWB
1970SWB's Avatar
Not sure what Tammy has for vinyl dye/paint, but........Tamco has an excellent adhesion promoter (#HP-2010)
John Stevens,
ASE master auto tech., ASE master autobody tech.
I-car platinum certified
'70 Chevy SWB pick up
'77 Chevy SWB 4X4 PU
2 '70 Buick GS Stage-1 4-spds
1970SWB is offline   Reply With Quote
Old 03-24-2019, 09:49 PM   #566
N2TRUX
Happy to be here
N2TRUX's Avatar
I plan to talk to Tammy soon to see what she suggests. I really love that she has fantastic products and keeps her prices very fair. I plan to support Tamco as much as possible.
Articles-
"Refining Sierra"
Old 03-24-2019, 09:53 PM   #567
N2TRUX
Happy to be here
N2TRUX's Avatar
I did a final mock up assembly on the console to ensure everything fit. I'm really pleased with how it came out, and the color I ended up with. The interior is going to be very light and inviting once finished. It will retain the vintage vibe with lots of modern amenities.
Articles-
"Refining Sierra"
Old 03-24-2019, 09:58 PM   #568
JoeinT.O.
Thanks for taking the time to post all the pictures and info of your build. It is very motivational. I can't wait for the weather to get warmer here.
Joe in T.O.
JoeinT.O. is offline   Reply With Quote
Old 03-24-2019, 10:08 PM   #569
N2TRUX
Happy to be here
N2TRUX's Avatar
I had to do a test fit with the seats just to be confident I had accomplished my goal. From the factory, these consoles sit to low to be used as an arm rest. My objective was to raise it enough to offer a comfortable seating position and be able to rest my arm on the console lid.
I found a position that will accomplish that goal and still be asteticly pleasing.
Articles-
"Refining Sierra"
Old 03-24-2019, 10:10 PM   #570
N2TRUX
Happy to be here
N2TRUX's Avatar
Joe in T.O.
My pleasure sir. This keeps me motivated as well.
Articles-
"Refining Sierra"
Old 03-24-2019, 10:31 PM   #571
N2TRUX
Happy to be here
N2TRUX's Avatar
Today I spent time ordering parts. I have decided at some point Jake will have a fuel injection system so I'm going to plan ahead. My primary has tank is an 87+ which means it's baffled. I ordered the secondary tank the same way. For now I have to use a a traditional fuel pickup on the primary side, but I'm going to run a F/I pickup with pump in the secondary tank. Obviously I won't be able to use that setup now, but it save me time and money in the future.
Articles-
"Refining Sierra"
Old 03-24-2019, 10:40 PM   #572
N2TRUX
Happy to be here
N2TRUX's Avatar
In the past I have had great luck with Spectra tanks. This one had to be modified to fit. Nothing some massaging with a hammer on the flange couldn't fix, so I tested the bracket fitment and prepped for paint.
I wiped the production lubricant off and scuffed it down with Scotch Brite. A final prep with brake cleaner and it was ready for paint. I sprayed the bottom side first. I gave it three full coats of satin black Krylon.
Articles-
"Refining Sierra"
Old 03-24-2019, 10:50 PM   #573
N2TRUX
Happy to be here
N2TRUX's Avatar
While the tank was curing I went to work on the door panels. I'm using 88-91 Suburban panels to accommodate the power doors I have installed. I plan to run the 81-87 brushed aluminum inserts, so the Suburban filler panels needed to be cut down. After stripping the old cloth away, I ran the panels through my table saw, cutting the top section off.
Articles-
"Refining Sierra"
Old 03-24-2019, 10:55 PM   #574
N2TRUX
Happy to be here
N2TRUX's Avatar
Unfortunately no one makes the brushed inert for the rear doors. I have a set that's driver quality that I'll attempt to restore. If anyone has a set in mint condition please message me.
Articles-
"Refining Sierra"
Old 03-25-2019, 09:58 PM   #575
N2TRUX
Happy to be here
N2TRUX's Avatar
This evening I was able to flip the tank over and paint the top side. I cleaned and prepped with brake cleaner and Scotch Brite, then hit it with Krylon. The Spectra Premium pumps #SP05N1H is on its way from Summit racing. I should be able to complete the assembly in a couple of days.
Articles-
"Refining Sierra"
