Old 02-20-2009, 11:55 PM   #576
TimE
Hey Y'all!!
TimE's Avatar
Re: My 1965 build thread
Originally Posted by joe231 View Post
that is what you get for leaving us without "adult supervision"
Wow Alan!! What are the chances that you would score a tilt column that would fit your truck that was already painted the correct color?
Just hopin' I live long enough to finish something!!!
TimE is offline   Reply With Quote
Old 02-21-2009, 12:07 AM   #577
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Yeah, it was a good score. The guy had it in a 1970 C10. I'll have to make some mods to it to get it mounted and then paint it gray to match the gauge bezels.
Alan's Classic is offline   Reply With Quote
Old 02-21-2009, 10:04 AM   #578
Alan's Classic
What adult supervision? I'm just a little kid in a big body. Just wish I was here at that time to come out and play.
Just sitting here waiting for it to warm up, 18 degrees right now supposed to be 58 today.
Old 02-21-2009, 11:21 AM   #579
Alan's Classic
I was searching for tail light ideas and keep going back to my original idea. using 2 1959 Caddy taillights frenched on both sides. I can use a piece of exhaust pipe to french them the way I want. Just rotate this pic 90 degrees so it would flow into the bedside.
Old 02-21-2009, 01:04 PM   #580
protrash64
Resistance is Futile
protrash64's Avatar
You need to enlist ChiefRocka to help with the drywall before you get too much more stuff in there. The truck is really looking nice, I always check in and see what your working on next.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 02-21-2009, 03:03 PM   #581
4dranch
Shloooooong bed member #2
4dranch's Avatar
STOP Alan, stay inside or you will end up with a bum ankle like I did trying to be a kid playing basketball with my daughter.
Caddy lights look sweet.
David,
Daughters 66 truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=484601
Learning to drive a 3 on the tree:
http://www.youtube.com/watch?v=CcCMvRgBo1Q
4dranch is offline   Reply With Quote
Old 02-21-2009, 11:20 PM   #582
Alan's Classic
Thanks Protrash, I'm waiting to get my cable and water ran to the shop before I button up the sheetrock. That's not a bad idea. I wonder if John would come out when I'm ready? Thanks for checking in.
Thanks David. If I stay inside then you'll catch up with me.
I didn't work in the shop like I wanted. The honey do list caught up with me. But, I was able to excape for a little while and go look at a truck that sdailey found for me. It's got the best hood I've seen around here on a none restored truck. I wish it had a fleet bed and a V8. I guess I can't have it all. The outer rockers are very nice, but the floors need some work.
I don't know much about the 6 cylinders, can someone identify this one. Will the distributor fit all 6 cyl
This is my 55 3100 6 cyl that I thought about putting a HEI on
Inside the cab
Inside the hood
Old 02-22-2009, 01:27 AM   #583
Alan's Classic
I couldn't stand it I had to go to the shop and do something. Threw in the new (used) tilt to see what all needs to be done to it to get it mounted. I am wondering if it needs to come toward the seat a little more. It's at a comfortable position like it is. If ya'll see something that I am missing let me know.
Like I said before I need to rewire it. I have a donor column that is not a tilt. Will the turn signal assy transfer over even if it is going from a non tilt to a tilt?
gearbox to column alignment pic
It looks like the shaft is sticking out more than usual.
Like I said before, I messed up on the Rt front cab mount area and I don't know how. Can't blame it on alcohol, cause I don't drink. It really doesn't matter I still have to fix it. The bolt is where it needs to be.
Old 02-22-2009, 01:38 AM   #584
jason65
Registerd User
jason65's Avatar
I do. It needs an orange shag dash cover. Trucks lookin good Alan.
jason65 is offline   Reply With Quote
Old 02-22-2009, 02:21 AM   #585
joe231
joe231's Avatar
you already looking for another
man you won't believe what i found....a '65 big back window cab that is original with NO signs of rust or repair! i can't swing it now, but wish I could....
he said I could have it for $500.....so tempting
man this last pic hurts my heart
CHEVY ONLY
Old 02-22-2009, 09:19 PM   #586
ol Curt
Junior Member
ol Curt's Avatar
Alan,
I think that motor is a 230, judging from it's color. The 230 or 250 would be hard to tell apart. The HEI on it wouldn't fit the older model which is probably a 235. There would be a series of numbers/letters stamped in a pad just behind the distributor that would help id the motor.
ol Curt is offline   Reply With Quote
Old 02-22-2009, 10:26 PM   #587
Alan's Classic
I took today off due to our 17th anniversary. I told her 3 more years and I would've been a free man. She wanted the dinning room repainted. Had to pull some border off. About all of it came off really easy except the last 4 feet. It was just taking to long to get it all off. So guess what I did......Drug a air line to the house from the shop and sanded the rest of the border off. A picture is worth a thousand words.
Not looking for another project just tryin' to find a good hood. Then sell the rest.
Wish I was closer I'd get it if you didn't
My mistake hurts me too. I'm here sharing how to do this body work and I do something like that. On the up side I think anyone that reads this will learn as well. I'm still baffled how it happened other than not paying attention.
Originally Posted by ol Curt View Post
Alan,
Thanks Curt, when I start working on the 55 I'll post the numbers so I'll know. I plan on getting the other truck and when I do I'll post the engine info.
My wife took this pic the other day of my good side while I wasn't looking then she came out too help. I was rolling the frame into position so I could set the cab on.
Old 02-22-2009, 10:36 PM   #588
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
wow, you really like you truck
Aren't wife's good at snapping pics like this when you least expect it?
IvelDesigns is offline   Reply With Quote
Old 02-22-2009, 10:37 PM   #589
Barebones66
Barebones66's Avatar
Wait, you drug the airline inside to do four feet ? You rock dude
1st project 66 SWB
Dave
Barebones66 is offline   Reply With Quote
Old 02-23-2009, 12:09 AM   #590
Alan's Classic
A little over kill, but if I didn't come up with something I still would be there getting glue off. 40 grit does great in removing wall paper.
Old 02-23-2009, 12:18 AM   #591
TimE
Hey Y'all!!
TimE's Avatar
That really stinks about the cab mount being off. Everything else is looking good (even the wall!).
Old 02-23-2009, 12:42 AM   #592
Barebones66
LOL ! Man thats funny...
1st project 66 SWB
Dave
Old 02-23-2009, 12:11 PM   #593
Strodder
Daring to be Different
Strodder's Avatar
WHAT NO MASK????
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 02-23-2009, 12:16 PM   #594
4dranch
4dranch's Avatar
He took it off to cheese it up for the camera
David,
Daughters 66 truck:
Old 02-23-2009, 12:19 PM   #595
Strodder
Strodder's Avatar
I meant to ask you what you are going to do to make the column fit under the dash. Will you cut it open to fit the diameter of the column, or just fill it? I'm going to have the same problem. Got any ideas? I thought of cutting the notch bigger, and bending, & welding small tubing for the lip so it's not a sharp edge.
Looking at the picture it doesn't look like your column will work that far in when tilted up.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 02-23-2009, 05:50 PM   #596
Alan's Classic
Originally Posted by Strodder View Post
WHAT NO MASK????
I ummmm, .......ummmmmmmm
Yeah that's it........
Keep in mind this the column is close to where it's gonna be, but as far as the opening I will just leave it the way it is. Once it's all done and painted there won't be many people that notice that there is a big opening. I thought about running a piece of rod around the opening, but I think I'll put some kind of door edge guard or something like it to make a gasket.
This is with the column tilted all of the way up. I might pull the column back toward the seat some more once I get it centered. When I center it and get the mounts on it might rise up a little more. Thanks for the input.
Old 02-23-2009, 10:57 PM   #597
FreeRideYZ250
A wet towel, and hold an iron on it, will usually release the glue too. Or a steamer of some sort.
How much drywall damage did you do with the power tools? Drywall is a little softer than metal.
FreeRideYZ250 is offline   Reply With Quote
Old 02-23-2009, 11:00 PM   #598
Strodder
Strodder's Avatar
GOT BONDO??
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 02-24-2009, 11:31 AM   #599
Alan's Classic
We tried several things, but we didn't have any success in that area for some reason. Sanding with 40, 80 and 180 did the trick with minimal damage.
GOT BONDO??
Not getting much done, fighting a cold. Trying to get some rest. Going to bed around 1-2 a.m. every night and getting up at 6:30 is catching up with me.
Old 02-24-2009, 05:58 PM   #600
kizer
Its Deja Vu time again
kizer's Avatar
Been there done that. 3 or 4 days of those hours and then all of the sudden whammmm the 5th day day its like a load of bricks smacking you down.
Its not pretty but its mine to figure out.
The build / The Photos / Build Diary
kizer is offline   Reply With Quote
1959, 1960, 1964, 1965, 1966, c10, hugger, impala, orange
