03-27-2022, 09:37 AM | #576 |
Post Whore
Re: My Dusty 71 GMCe Electruck
cutting 1/2" aluminum plate a mil at a time using my FREE Craigslist Craftsman Radial 10" saw with a Diablo 84 tooth non stick blade, yeah baby
thrilling I tell yah! Craftsman Radial Saw cutting aluminum plate |
03-27-2022, 09:53 AM | #577 |
Are you going to convert the space in front of the transmotor into a trunk?
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
03-27-2022, 10:15 AM | #578 |
Post Whore
03-27-2022, 10:20 AM | #579 |
Put some motor mounts on and the radiator, with torn off hoses like it just jumped out of there somewhere along the way.
03-27-2022, 10:30 AM | #580 |
Post Whore
that would be hilarious, and stand there all like: "it's the second time this has happened this week, damned LS!"
03-27-2022, 07:19 PM | #581 |
The two motors in the original vehicle were working in conjunction? Or on and off at different times? LS motors have a fan relay in the Computer that turns the fans on and off as needed if the motor is working harder. Sometimes only one is working while other times both are working. Is the two motor transmission using the second motor as it needs it but in your arraignment locking them together will any computer reprogramming be necessary?
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 |
03-27-2022, 08:57 PM | #582 | |
Post Whore
03-27-2022, 10:20 PM | #583 |
Wow that is cool, Alternator and starter in one. I have heard that the giant (three story tall) quarry dump trucks use electric motors for breaking.
03-28-2022, 10:13 AM | #584 | |
Post Whore
Lexus Toyota Hybrid Transmission Project 02 : Internals |
03-28-2022, 10:41 AM | #585 | |
Post Whore
with the truck almost one foot off the ground on blocks, I still could not roll the trans on the jack under it, so here I am literally hoisting up the trans with an engine crane just so I can set it on that stupid jack with the trans adapter on it, PIA PIA major PIA RECOMMENDATION: Do NOT Buy! |
03-28-2022, 10:43 AM | #586 |
I got the HF trans jack, worked ok for the 4L60.
03-28-2022, 10:45 AM | #587 |
Post Whore
was it this thing?
03-28-2022, 10:49 AM | #588 |
No, I splurged for the Pittsburgh $200 one. https://www.harborfreight.com/media/...0/60234_W3.jpg
03-28-2022, 09:39 PM | #589 |
I always us a motorcycle jack with blocks of wood under the trans. If its not high enough, I add more blocks while under the truck. I usually have to jack up the truck to get the trans slid under too.
10/10 would not recommend for safety reasons. But I still do it.....
‘53 GMC COE stock ‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘ '70 Chevy C10 LWB 350/sm465 ‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags |
03-28-2022, 09:41 PM | #590 | |
Post Whore
03-28-2022, 09:46 PM | #591 |
Post Whore
so what are the odds one of my existing trans crossmembers will work (couple more on the floor not shown)
03-28-2022, 09:51 PM | #592 |
Post Whore
having eliminated the original crossmember that held the Turbo TH350 transomatic in place in the first place, I moved on to one with some drop, using rubber feets from my stock radiator core support (run what you brong!)
03-28-2022, 09:53 PM | #593 |
looks like it was made for it
03-29-2022, 09:07 AM | #594 |
That fit nice.
I just noticed that the front of the transmission looks like a "fidget". Yeah, keeping grandkids this week....
03-29-2022, 10:21 PM | #595 |
Post Whore
mounting the transmission is by far the biggest job on this project
03-29-2022, 10:24 PM | #596 |
Post Whore
I'm going with these Jeep like AMAZON motor mounts, figuring if they was strong enuff to hold an engine they ought to hold a transmission
now hang on to your comments as this is all just spit ballin' mock up, and that frame's got more twist and turns than you know it |
03-29-2022, 10:27 PM | #597 |
Post Whore
so like most I make big plans in my head and then use what I got layin' around the garage
03-29-2022, 10:29 PM | #598 |
Post Whore
and if you've followed any of my prior builds, you know I like to class things up with rounded corners, ha ha
03-29-2022, 10:30 PM | #599 |
Post Whore
one down three to go
slow is the tempo |
03-29-2022, 10:33 PM | #600 |
Post Whore
I just trace sum random washer I find laying around
and I do two passes, first one is a ruff cut with a cutoff wheel |
