08-01-2019, 09:27 AM | #6101 | |
Moderator
Re: Restoring Rusty
For example... The forward lighting harness is just a few wires... A modern LS engine contains a handful of sub functions. Break em up as individual separate systems so it makes sense to you... Sensors, Fuel, Ignition, Charging, etc. The functions may interleave inside the PCM but the wiring is separate.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
08-25-2019, 09:47 AM | #6102 |
Post Whore
Re: Restoring Rusty
So started looming my engine wiring harness. The point of this thread is to show you that if you take your time wiring doesn't have to be that bad, you don't have to do it all in one shot.
I decided to do it on the truck cause I was too lazy to take it off yet again and I convinced myself this way I can ensure every sensor has the proper slack or lack there of. I will upload more pics as I do more branches. Found that a little Stevie Ray Vaughan on the good ol' hi fidelity stereo pairs really well with a 12 oz refreshment of your choice and makes the split loom slide on a bit easier, ha ha. |
08-25-2019, 09:49 AM | #6103 |
Post Whore
Re: Restoring Rusty
So I pretty much bought every size of black high heat automotive split loom from 1/8" to 1 1/2" I could find in The Amazon
08-25-2019, 09:50 AM | #6104 |
Post Whore
Re: Restoring Rusty
using the high heat Tesa brand tape that Brandon of LT1Swap.com recommended, again from Amazonia
08-25-2019, 09:53 AM | #6105 |
Post Whore
Re: Restoring Rusty
yeah that's pretty much all I did tonight (still recovering from my surgery so hold your judgement, ha ha, and don't tell my doctor) so just the passenger side four injectors, coil, and not fully in view the MAF sensor wire [good enough for the girls we go with]
hey do any of you know if they make a throttle bracket minus the cruise control hole on it, I aint got cruise control and would prefer a cleaner look, and don't feel like taking the death wheel to it just yet |
08-25-2019, 09:54 AM | #6106 |
Post Whore
Re: Restoring Rusty
if any of you kind souls could let me know how to remove these pesky GM gray wire harness connectors off the metal bracket that would be great, I am missing one and I tried to remove some at the junkyard and almost went postal, for the life of me I could not get them off without carnage
08-25-2019, 09:55 AM | #6107 |
Post Whore
Re: Restoring Rusty
those silly white bar codes on the fuel rail will keep me up at night, must peel them off
08-25-2019, 09:57 AM | #6108 |
Post Whore
Re: Restoring Rusty
yup, inch by inch, she will get done
08-25-2019, 09:58 AM | #6109 |
Post Whore
Re: Restoring Rusty
... and on to the other side, twice as many sensors/components on this side
08-25-2019, 09:59 AM | #6110 |
Post Whore
Re: Restoring Rusty
had to use a bit bigger loom on this side as there are twice as many wires, including the TPS, IAC, Alternator, Temp, Knock Sensor, etc. plus the Injectors and the Coils
08-25-2019, 10:05 AM | #6111 |
Post Whore
Re: Restoring Rusty
and here is how it all turned out
08-25-2019, 10:12 AM | #6112 |
Post Whore
Re: Restoring Rusty
I did build my own fuse block following LT1Swap.com and a hybrid of the stock, and I think it turned out great
08-25-2019, 10:14 AM | #6113 |
Post Whore
Re: Restoring Rusty
also to keep things simple, I mounted the PCM on the driver side inner fender, I thought about running the harness through the firewall and mounting the PCM on the inside of the cab, but I was surprised to find a lack of space for it there, and this way all engine stuff is in the engine compartment, so there's that
08-25-2019, 10:49 AM | #6114 |
Moderator
Re: Restoring Rusty
You don't have salt and much in the way of water to contend with in Sacramento.
I'd still spray the open relay and Pak Con fuse terminals with WURTH HHS-K or WURTH HHS-2000 creeping lube or something similar. The thing I like about WURTH HHS is it doesn't seem to attract dirt like spray greases and it keeps the water and other corrosive stuff away from open electrical contacts like fuse panels in the engine bay. You can probably get it from your Mercedes, BMW, Porsche, or Audi dealers for an exorbitant extravagant price or just buy a can from an online vendor. Nice clean wiring job.
And please let us know if and how your repairs were successful. Last edited by hatzie; 08-25-2019 at 01:38 PM. |
08-25-2019, 01:29 PM | #6115 |
Re: Restoring Rusty
Nice clean job, sir. Barring any unforeseen programming glitches, you're gonna love the swap. A word to the wise, though. Hang on tight to the steering wheel when you say to yourself "Lets see what this baby will do"
08-25-2019, 01:51 PM | #6116 |
Post Whore
Re: Restoring Rusty
08-27-2019, 03:33 PM | #6117 |
Re: Restoring Rusty
Looking good. Your clean and simple explanation of the wiring is pretty fantastic. I just might have copied and pasted all of that into a folder for future reference.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 Last edited by daddyjeep; 08-27-2019 at 03:39 PM. |
08-27-2019, 04:25 PM | #6118 |
Post Whore
Re: Restoring Rusty
08-30-2019, 02:17 AM | #6119 | |
Post Whore
Re: Restoring Rusty
08-30-2019, 02:22 AM | #6120 |
Post Whore
Re: Restoring Rusty
Looks really good Greg..!!
08-30-2019, 02:34 AM | #6121 |
Post Whore
Re: Restoring Rusty
Thanks brother, I appreciate that, the best feedback I got was at work from one of my buddies who is no joke when it comes to LS wrenchin', helps a local guy here in Sac who actually beat one of them fancy Street Outlaws in a heads up race which they conveniently didn't air, LOL, anywho he said "Looks like it belongs!" that meant a lot coming from this dude.
08-30-2019, 10:05 AM | #6122 |
Post Whore
Re: Restoring Rusty - First Drive After LS Swap
first drive into work, post my LS swap, so exciting, fingers crossed... keep grinding fellas you can do it!
UPDATE: Ok if you are reading this today, I made it there and back, well it over heated on the way back but that was a bone head oversight on my part, forgot to tighten lower radiator hose clamp. The point is that I am being flat out honest with you all here and not hiding anything to make myself look good, no build is perfect, there are just too many moving pieces, it's like we are putting together a 3D organic moving puzzle, and most often doing it by ourselves. So it's ok, that's why we do a shake down run, and yes I drove it around the neighborhood first slowly to see if anything falls off, ha ha before I took it to work, but I always feel until you make a real run with your rig, to school, work, or your girlfriend's house (shhhh don't tell the wife, jk), it's just not done till then. FYI: Took 2 months but I spent like 2 weeks redoing my entire exhaust cause I wasn't happy with it and wanted it to go over the rear axle, but using Magnaflow mufflers still. Biggest Challenge: Adapting all the metric fittings to standard: trans cooler lines, power steering lines, oil pressure sensor, etc. seems the smaller the part the longer it took, ha ha, but everyone on here was super helpful, thank you so much. Don't ask yourself will there be set backs, but ask yourself how will you handle them, (music helps, beer really works)! Most Fun: Buying, Learning and Tuning using HP Tuners. Advice: Buy the most you can in one shot: engine/accessories/transmission/wiring harness/computer/MAF/(drive by wire throttle) or risk getting nickle and dimed to death. Budget: come on you guys, what? and risk my wife seeing this ������ Formula for success = come up with an arbitrary budget amount, than double it, then plan to exceed it! Question being how fast do you want to spend? ha ha Last edited by Gregski; 08-30-2019 at 10:13 AM. |
08-30-2019, 10:07 AM | #6123 |
Post Whore
Re: Restoring Rusty
I swear I am going to paint this truck one body panel at a time, lol, I already painted the old hood, then the passenger side fender, than the hood again, well a new hood, and now you can totally tell the difference against the driver side fender which is going to get replaced and painted, oh the inner fenders were painted as well, I wanted a cherry engine bay in a rust bucket hooptie
08-30-2019, 10:09 AM | #6124 |
Post Whore
Re: Restoring Rusty
and then on the way home this happened! the lower radiator hose took a piss and the temp gauge jumped to 224* F
Um, did the Installation Tech forget to tighten the lower radiator hose clamp? [asking for a friend] |
08-30-2019, 10:12 AM | #6125 |
Post Whore
Re: Restoring Rusty
can someone explain to me please how one cuts his forearm by putting water in the radiator, LOL
