Old 02-19-2018, 09:46 PM   #601
C/10 King
C/10 King's Avatar
Re: Post those wheels gallery
Originally Posted by Faastone27 View Post
I know this was not intended for me but i am also running a 20X9 in front and no rubbing at all
Nice wheels and nice truck!!!
C/10 Rene
1966 Short Fleet "The Hag"
1967 CST Short Fleet "Dark Poly"
1971 Short Fleet
1970 Jimmy Custom 2 WD "Golden Ticket"
1972 Blazer 2 WD "Retro Blaze"
C/10 King is offline   Reply With Quote
Old 02-19-2018, 10:13 PM   #602
Mhussnatter
The 15x12 fit in the rear without any modifications? What backspacing do they have and what tire size you running on those 12" wheels?
Mhussnatter is offline   Reply With Quote
Old 03-05-2018, 10:00 AM   #603
1badmonza
1badmonza's Avatar
Got the new 20" Vintecs on and loving the look now!
IMG_E1217 by Mike Lanclos, on Flickr
IMG_E1232 by Mike Lanclos, on Flickr
IMG_E1213 by Mike Lanclos, on Flickr
1968 C10, 5.3 with 4L60, 2600 Circle D converter, all CPP suspension with big brakes, 4.5-7 drop, 20" Billet Specialties Vintec wheels all around, AC with Jam and ready to CRUISE!
1badmonza is offline   Reply With Quote
Old 03-12-2018, 10:35 PM   #604
del4fun
del4fun's Avatar
Too Clean!!!!
US ARMY RET, SUPPORT THE TROOPS
1972 Custom/10 Short Fleet 4.5/ 5 Drop
Dogg Pound Customs
del4fun is offline   Reply With Quote
Old 03-13-2018, 07:30 PM   #605
bobshotrodblazer
BigBlockBobby
Originally Posted by del4fun View Post
Too Clean!!!!
She’s a beauty!
Bob
bobshotrodblazer is offline   Reply With Quote
Old 03-14-2018, 09:59 PM   #606
808_67C10
808_67C10's Avatar
Totally agree... love this truck and those wheels are classy!
Frank (Hilo, Hawaii)
Trucks, Tacos, and Beer go together like Peanut Butter and Ladies!
85 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=760383
67 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=489298
79 K5 Blazer SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=657461
808_67C10 is offline   Reply With Quote
Old 03-15-2018, 01:31 AM   #607
mike16
Very sexy rims. so good looking I'm looking for more too bad I can only have the five of them on my truck at any one time, but there's room in the bed for more
mike16 is offline   Reply With Quote
Old 05-01-2018, 08:00 PM   #608
88gtstreetrod
New guy here and new to the 67-72 trucks. I have been looking all afternoon for the answer and there are so many combinations I am not sure what will work? I am hoping someone can respond and help please
Looking at buying a 1971 GMC 1500. The truck has original 5 lug front disc and rear drums. The truck is lowered 5" in rear and 3" in the front.
I am looking to buy the Rocket Booster Classic Muscle Wheel | Gray from Coker Tire. Not sure what size rims and tires and back sizing?
Thinking 20x8 and 20x10 rims from what others are running, but not sure what backspacing?? I would like of the rims/tires to fill the wheel well and sit flush (or as much as possible) to the edge of the fender.
Any opinions and/or pics of your set up with the tire size and backspacing.
Thank you!!
88gtstreetrod is offline   Reply With Quote
Old 05-02-2018, 12:29 AM   #609
cornerstone
cornerstone's Avatar
The homework that I did led me to purchase 20x8 fronts with 4.25 BS and 20x10 rears with 5.5 BS. I am hoping that they will fit just inside the wheel wells, so I can play with my air ride and not rub. I know that there is a difference in axle housing widths of .75 inch on each side (1.5 inches total) wider for my 72. I am fairly certain the 71 is the same but 70 and below is narrower. Im sure someone will correct me if I am mistaken. I dont have my body on the frame now so I cant take pictures and show you.
cornerstone is offline   Reply With Quote
Old 05-02-2018, 10:01 AM   #610
knomadd
knomadd's Avatar
First, good luck with your purchase. Second, like cornerstone said, there is a difference between the width of the rear axle, and I believe he's correct that 71 was the year it changed, but I could be wrong. I'm not certain about 69-70 rears, but I know the 67-68 are narrower. Stepsides are also a bit different for wheel fitment than a fleetside. There isn't an easy answer because of all of these factory differences. Add into that all of the custom work some guys do and you'll blow your mind reading all of the different combos.
Here's an example. I had 22x9.5's with 5.75" BS on all 4 corners of my 71 fleetside. I had rubbing on the control arms and shock bodies up front, and the larger wheels wouldn't let the front ride or air out as low as I wanted. I now have 19x8 4.75" BS and 20x10 5.5" BS without issues, but I'm not running factory spindles or control arms. It will also depend on how wide of a tire you add to those wheels.
Your best bet would be to measure them yourself. You should always check on your own vehicle to make sure what you're buying will work, before you spend the money. Figure out what's on there now and how much more room you have to go, and use a good online tool like https://www.rimsntires.com/specspro.jsp to compare what you have to what you want. This tool isn't going to replace actual measurements, but it will sure help get you in the ballpark.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 05-02-2018, 09:30 PM   #611
88gtstreetrod
Thanks Duane for the feedback. It's a fleet side and and everything is stock except of the lowering. From what I can tell, a 20x9 with 5.5 backspacing and a 8.5 width in the front should work. I will check out the site. Thank you.
Old 05-03-2018, 10:22 PM   #612
JRracing
I have some wheels being made right now at a place in cali, Pro wheels is the company I think. These will be either a big hit or a big flop. 22x10 5.5 bs/20x8.5 4.75 bs.
They are going on a 68 sbss. We have been poking at for over 10 years. Its a frame off build.
We should have the wheels in 3 weeks. I will post them once they are mounted up.
59 apache sbss.
68 sbss.
57 belair"old man car".
JRracing is offline   Reply With Quote
Old 05-29-2018, 08:17 PM   #613
JRracing
Damit...I got pics but having a hard time getting them on photobucket. Were else can i download these? There is only a few.
59 apache sbss.
68 sbss.
Old 05-29-2018, 08:24 PM   #614
Southpaw69
just upload them here. Click the little paper clip and browse and select file.
Southpaw69 is offline   Reply With Quote
Old 05-29-2018, 08:31 PM   #615
JRracing
these are premier wheels, "Hot Rod" 22x10/20x8 305/40/22 and 255/45/20.
59 apache sbss.
68 sbss.
Old 05-29-2018, 08:36 PM   #616
JRracing
These were just put on this week. So adjustments on the way. Lowering the rear 2". Also considering cutting this rearend 1" off each side and doing disc brakes and a posi unit.
We are rushing to finish this up for the HotRod power tour which starts next Saturday in Bowling green KY.
59 apache sbss.
68 sbss.
Old 05-29-2018, 09:11 PM   #617
JRracing
This is my 59 apache with a set of wheel vintique truck wheels. 15x8/15x7 235/75/15 coker 3" white walls.
59 apache sbss.
68 sbss.
Old 05-29-2018, 09:16 PM   #618
JRracing
Thank you. I finally got photobucket to work.
59 apache sbss.
68 sbss.
Old 05-29-2018, 09:21 PM   #619
Grandview
17x9.5
Grandview is offline   Reply With Quote
Old 05-29-2018, 10:46 PM   #620
BC10
BC10's Avatar
Wow! Absolutely gorgeous!
BC10 is offline   Reply With Quote
Old 05-30-2018, 01:07 AM   #621
vt05091
vt05091's Avatar
Old school:
vt05091 is offline   Reply With Quote
Old 05-30-2018, 10:28 AM   #622
JRracing
Thanks BC10
59 apache sbss.
68 sbss.
Old 05-30-2018, 10:43 AM   #623
72 GMC C1500
72 GMC C1500's Avatar
20" American Racing Iroc's
72 GMC C1500 is offline   Reply With Quote
Old 05-30-2018, 06:22 PM   #624
Murph72
Murph72 is offline   Reply With Quote
Old 05-30-2018, 06:24 PM   #625
197D_C10
197D_C10's Avatar
Nothing special here. Just your standard set of 15 x 8 chevy rally's on 275/60/15 BFGs. I'm looking to go 20's, but there are a few wheel options that I like its hard to make a decision. I may just have to have a set for each day of the week.
197D_C10 is offline   Reply With Quote
