#601 |
![]() Join Date: May 2007
Re: S10 Swap how to
awesome news! glad to hear it chris
Mains52, I have hung a motor and trans in the hole using a cherry picker, jacks, and holding my tongue right to weld in mounts. level the frame first, then level the motor 4 degrees down towards the rear. keep a little offset to the passenger side (use the oval holes on the top of the s10 frame to the cast line on your trans) and keep the motor straight in the frame. by the time you set everything where it needs to be, you can tack in your mounts.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 Last edited by joedoh; 05-04-2017 at 02:20 PM. |
#602 | |
![]() Join Date: Apr 2010
Re: S10 Swap how to
if anyone is interested one of my builds is for sale in kc. he's asking 10k, and in my opinion it's well worth it. it is a 52 gmc on an s10 chassis with a 4.3/700 and a disk brake camaro rear. it is currently titled and licensed. this is literally a turn key truck, and you know i build 'em right! here's a link to the build pics https://www.facebook.com/pg/OSGcusto...55911077861390 i'll post a current pic and his # as soon as i get them,
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 |
#603 |
Re: S10 Swap how to
here are some pics of when i delivered it.
#604 | |
Re: S10 Swap how to
unless you were lifting the engine into the frame with your bare hands, your way is one step more than mine. ![]()
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
#605 |
Re: S10 Swap how to
of course i use a hoist to lift it.
#606 |
Re: S10 Swap how to
You guys crack me up.
Joedoh: Thanks for the tips. I was able to get it leveled and lined up. I got my mounts tacked in this past Friday. I used a little of your technique mixed with a little of Skymangs technique. Skymangs: I very glad to hear you're doing well. I've only been on here a little while but you seem to have a huge support group and following here and I am one of them now . Thanks for all of your tips and info. |
#607 |
Re: S10 Swap how to
you bet, just trying to "pay it forward"
#608 |
Re: S10 Swap how to
Skymangs, I would like to use my stock steering column. Is it possible or no?
#609 |
![]() Join Date: Sep 2016
Re: S10 Swap how to
Stock S10 engine question. I have the V6 in a 1988 S10. Do I keep the radiator and fan or do I need to replace those for a slimmer model to fit the Chevy 3100 front clip on? Second question, do I need to move the engine back or forward at all or is it ok in its spot and I just use the cab mounts to get the cab and fenders in the right place around the existing engine?
Thanks!
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition! Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride |
#610 |
Re: S10 Swap how to
Skymags, im glad to hear your doing better and i want to say thanks for this thread. It would be nice to put everything in a book for reference.
My question is and i dont know how much was covered but what do you do to make your box supports and how you mount them. I might have missed it after read 700+ post on this thread. Or if anyone knows the post number would be greatly appreciated. Thanks |
#611 |
Re: S10 Swap how to
skymangs, I saw the 52 GMC while browsing CL yesterday, figured it was one of yours.
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop |
#612 | |
Re: S10 Swap how to
edit: I realized I asked skymangs the same exact question as you before I did my first swap haha. I was hopeful not to move the engine too.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 Last edited by joedoh; 05-18-2017 at 01:27 PM. |
#613 |
Re: S10 Swap how to
As always, thanks for the post JoeDoh. Not sure I could have made it this far without your responses. Funny now that I have the S10 blown apart and I look at your Booger build thread, everything makes sense and looks right. I must be learning something! Any chance you have a picture of the V6 motor mounts? Do I just build an adapter plate with an 8.5" offset or is there more to it?
I'm finding myself with more and more questions simply because I am planning a few steps ahead and working on steps I know I'm good with. Obviously blowing apart the truck wasn't terribly difficult, but I didn't want to damage anything I wanted in the future. Looking ahead, I have to start thinking about what gets fabricated first, what I need to fit back on first, etc. Just have the passenger side electrical and ECU to take out and the cab can come off.
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition! Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride Last edited by gigamanx; 05-19-2017 at 08:57 AM. |
#614 |
Re: S10 Swap how to
my fenix project is a 91 s10 like your current truck, and I go into detail on how I built and lined up the motor mounts. remember that you need exactly 16.5 inches between the mounts center to center, dont let them get wider as you go back.
also in this thread skymangs does a great job explaining how to hang the motor and build mounts. on my first one (47 gmc) we built a bolt in adapter plate that moved the engine 6.5 inches, it needed a little more and it didnt make sense to use a plate to do that on the 49
#615 |
Re: S10 Swap how to
first of all thanks for all the props. i'm no where near the first guy doing this. i just thought i'd take a little of my time to share my knowledge and experience. i found it frustrating on my first build that no one would give up any real info.
gigamanx, 52ratrod and Mains52 spend some time reading the first few pages of this thread. and mains52, you can use your stock steering column, classic parts sells a bearing that will convert your closed column to an open one. for thoseOf you who don't know, I lived with my dad for the last six months. We were involved in a terrible traffic accident on 12 May, my dad passed six days later in the hospital. I am now living with my sister in northern Iowa. I still plan on coming all truck nationals though
#616 | |
Re: S10 Swap how to
Sorry to hear of so much loss in your life. I can't imagine what it takes to fight through the day but I'm glad you're doing alright.
#617 |
Re: S10 Swap how to
Thanks, it's been a rough couple of years.my wife decided that she didn't want to take care of me for rest of my life, so she filed for divorce, and she's trying to be very greedy.
#618 |
Re: S10 Swap how to
ouch! sorry to hear that!
#619 |
![]() Join Date: Mar 2011
Re: S10 Swap how to
Damn, sorry to hear this Chris, prayers that things start going your way...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#620 |
Re: S10 Swap how to
Hey skymangs. I did the muriatic acid dip as you suggested for the frame rails but it seems there is still a slippery coating of some kind on the metal. I'm wondering if I diluted the acid too much in water before applying. The container says 120z per gallon of water. Also, there is a bit of surface rust on the rails; am I ok to wire wheel that down to metal before I do the acid part or will that push the wax into the pores?
Thanks!
#621 | |
Re: S10 Swap how to
#622 | |
Re: S10 Swap how to
Still not happy with the spotty results I'm getting. Maybe I bought the wrong stuff? https://www.lowes.com/pd/Jasco-Green...9-538a2e6cad36 You can see in the pic. The middle section had naval jelly for 30 min then wire brush then muriatic acid then ammonia. Seemed to get pretty clean after all that. The other two sections had muriatic acid only as well as the side of the frame. It didn't seem to get through the rust very well. ![]()
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition! Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride Last edited by gigamanx; 06-20-2017 at 09:55 PM. |
#623 | |
![]() Join Date: Mar 2014
Re: S10 Swap how to
I'm interested in this answer as well. I never had a ton of luck with the muriatic acid. I use a combination of wire wheels, sanding discs, and flap wheels until it's as clean as I think it's going to get, then follow that with phosphoric acid...let that sit for 20-30 min (keep it wet), then wipe it off. Seemed to weld OK. |
#624 |
Re: S10 Swap how to
That is the right stuff all right. I never had any difficulty with it, I just applied the muriatic acid then the ammonia. The water after the ammonia to dilute it. Then I am free to weld the cab mounts on. I have never had all this trouble. Maybe it's not perfect, I don't know.
#625 |
Re: S10 Swap how to
On the first couple of pages it is suggested to use a 32" column, would a 33" column be too much? Or can I get away with that?
I've found one I like, but it's the extra inch.
