Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 04-06-2016, 09:51 AM   #601
7dee2
7dee2's Avatar
Re: 72 K30 Build
The goal was to have the oil pan bolted on but had the wrong oil pump pickup. While we’re waiting for a new pickup to arrive it’s a good time to paint.
Brett
67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594
72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.)
72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614
YouTube: https://www.youtube.com/@6dee7-7dee2
7dee2 is offline   Reply With Quote
Old 04-11-2016, 11:02 AM   #602
7dee2
7dee2's Avatar
Re: 72 K30 Build
Picked up the seats from the upholstery shop and they did a really nice job. We also snagged another 4 bolt 454 block for our poor neglected Camaro project.
Brett
Old 04-12-2016, 12:22 AM   #603
swamp rat
swamp rat's Avatar
Re: 72 K30 Build
Nice!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 04-12-2016, 01:03 AM   #604
First c10
First c10's Avatar
Re: 72 K30 Build
Originally Posted by swamp rat View Post
nice!
x2
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 04-12-2016, 11:22 AM   #605
7dee2
7dee2's Avatar
Re: 72 K30 Build
Thanks you guys!
Pickup arrived and pan is on, first time trying a one piece oil pan gasket we will see how well that works out. Had to use ¼” longer bolts at the timing chain cover and I read somewhere a daub of silicone in the four corners and you are good to go.
I was a little concerned that if I painted this Summit dampener you couldn’t read the degree marks. Thought about just notching it at zero and painting it anyway but after taking some thinner on a rag to one of the markings I found they’re on there really well. Decided to just clear it and leave the metal finish.
Brett
Old 04-12-2016, 01:24 PM   #606
First c10
First c10's Avatar
Re: 72 K30 Build
Looks like the same kind/type gasket I used on the SBC. I bought a Mr gasket oil pan bolt set and it had 4 longer bolts, 2 front bolts at the timing chain cover and 2 and the rear main seal.
GO GO!!!
Old 04-13-2016, 10:12 AM   #607
7dee2
7dee2's Avatar
Re: 72 K30 Build
The front ¼-20x3/8 bolts were so short with the factory pan they could not reach the cover at all. The rest of the BB set is 5/16-18x5/8 and they all grabbed thread well enough to hold 25-30 lbs. hopefully they stay put!
Our intake did clean up good enough for me not to paint it, also installed a FlowKooler water pump and will use the thermostat they sell also. We’ve had heating issues in the past with some of our big blocks and I can tell you these water pumps work really well.
Brett
Old 04-13-2016, 10:42 AM   #608
First c10
First c10's Avatar
Re: 72 K30 Build
Hey Brett I have the same type rockers on the SBC I am putting in Jr. (Roller tips I think mine were ProForms)
I need to find that little Vacuum fitting that wye's on your intake. Where did you find it?
GO GO!!!
Old 04-14-2016, 09:38 AM   #609
7dee2
7dee2's Avatar
Re: 72 K30 Build
The rockers are part of the Comp Cams kit, we got all their stuff even push rod guide plates, the dist. gear and fuel pump push rod. I'm guessing it’s an original factory fitting that came on our 72 402 and was moved to this intake when they swapped it on that motor. Back in the day Corvette and the truck line shared many parts so one of my favorite vendors is Paragon. Here’s a link to their vacuum fittings section, I think it would be their product# 1362. https://www.paragoncorvette.com/sear...Vacuum+Fitting
Hey looky there, some orange did make it even if only temporarily! Time to take it off the engine stand and mate it to the trans. I finally opened the box to get a look at our recon low stall converter. It’s almost ready to drop it in the chassis.
Brett
Old 04-14-2016, 09:58 AM   #610
First c10
First c10's Avatar
Re: 72 K30 Build
hey Brett thanks for the link. they have many configurations. motor looks about ready to drop in!!!
GO GO!!!
Old 04-14-2016, 02:58 PM   #611
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 72 K30 Build
It's looking great! Keep at it!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 04-16-2016, 09:39 AM   #612
mjensen
mjensen's Avatar
Re: 72 K30 Build
Wow, I go away for a month and come back to some serious progress!!!
Mike
'69 GMC 3/4 ton 4x4 Build Thread
mjensen is offline   Reply With Quote
Old 04-18-2016, 10:53 AM   #613
7dee2
7dee2's Avatar
Re: 72 K30 Build
No problem Scott hope that helps, and yep that’s the update for today.
Thanks Ryan!
Hey Mike, thanks glad your back, we have made some progress lately.
It’s in there.
Brett
Old 04-18-2016, 10:59 AM   #614
JJorgensen52
Simple? What's simple?
JJorgensen52's Avatar
Re: 72 K30 Build
It’s in there.
The biggest problem I see with this is that you have to put a cab on top of it... so pretty!
CURRENT
'50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build
'63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos
'66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos
'69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!)
'72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh
'99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily)
'99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs)
SOLD
'71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder)
JJorgensen52 is offline   Reply With Quote
Old 04-19-2016, 10:04 AM   #615
7dee2
7dee2's Avatar
Re: 72 K30 Build
Thanks Jim and congrats to you on your new truck buddy it’s a looker!
Took a little gas to clean up the transfer case and all that black paint just fell off (jk all Sunday afternoon with a tooth brush is more like it)? Man that was lucky (not)! Since we didn’t go orange on the block we didn’t go red for the TC either, kind of have a black and cast iron gray thing going.
I don’t know if I mentioned this before but our transfer case came in but was not the original to our donor 84 K3500. The cast date is 3/22/71 and it also carries a tag on the PTO cover that is dated 5/6/71 so it looks like it’s found its way back into a correct generation truck. And yes that is a piece of speedo cable stuck in the speedo gear.
Brett
Old 04-19-2016, 10:47 AM   #616
First c10
First c10's Avatar
Re: 72 K30 Build
Looking good Brett,
That motor in that looks huge even with the heavy running gear.....
I have a question as I have 2 transmission cross members. One is like the one you are using(from an 86 burb) and the other has a more of a drop(original 68 from the truck). How did you know which one to use?
GO GO!!!
Old 04-20-2016, 10:56 AM   #617
7dee2
7dee2's Avatar
Re: 72 K30 Build
Thanks Scott, the Longhorn frame is kind of unique in that its section height is at its widest in that area (kind of pregnant). If we had used the gen2 correct ½ or ¾ ton TC cross member it would have needed to mount to a lower support pedestal to maintain the correct factory height or angle, same as GM originally did with the auto trans cross members in this frame. During mockup we figured this out that they both land in approximately the same place if the gen2 member is mounted under the upper flange and the later gen3 is mounted below the lower flange. So our decision was made it would be much easier and cleaner to use the later gen3 cross member. Using a gen2 ½ or ¾ ton frame I would think you would need to shim the gen3 cross member down some due to the section height of those frames to achieve the same angle which is more critical to carbureted applications.
A sling and cherry picker makes short work with the cab out of way.
Brett
Old 04-20-2016, 11:15 AM   #618
First c10
First c10's Avatar
Re: 72 K30 Build
Great information Brett thank you! I do have both gen crossmembers. One thing I noticed I will have to remove the carrier bearing drop bracket as it will get a 1 piece drive line when completed and is in the way.
Will you be using a 1 piece driveline? if so how long will it be in that frame? the hulk build drive line was 48 1/2" c to c of ujoints.
GO GO!!!
Old 04-21-2016, 10:29 AM   #619
7dee2
7dee2's Avatar
Re: 72 K30 Build
Yep a one piece driveline is still our plan and if we were going to stop at the transfer case it would be about 67" c to c! I think our only hope to get any kind of gas mileage is the gear change we did and a Gear Vendors OD unit. The OD is unit 12 1/4" and utilizes a slip yoke it also replaces the 205 tail housing with an adaptor. My guess is we will end up around 52 ish when all is said and done.
Here’s a fuss bucket maneuver, been thinking we’d run spark plug shields just because they'll give a factory look and I happen to have 6 originals off the 402. They don’t repro these but the ones GM sells are kind of close especially with a little work. Going to run them in the front right position under the A/C compressor were you can’t see them anyway, told yah fuss bucket!
Brett
Old 04-29-2016, 12:36 PM   #620
First c10
First c10's Avatar
Re: 72 K30 Build
Quite over here HAHAHA!!
After installing the ram horns I may have to fab up some sort of shield like you have.
GO GO!!!
Old 04-29-2016, 11:01 PM   #621
swamp rat
swamp rat's Avatar
Re: 72 K30 Build
Nice work, keep at it!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 05-02-2016, 10:12 AM   #622
7dee2
7dee2's Avatar
Re: 72 K30 Build
Been a little side tracked lately so we put the K30 on hold for a couple of weeks.
Brett
Old 05-02-2016, 12:16 PM   #623
flashed
Re: 72 K30 Build
Im ready to see more when you get ready .
flashed is offline   Reply With Quote
Old 05-02-2016, 02:51 PM   #624
First c10
First c10's Avatar
Re: 72 K30 Build
Hope all is well....
GO GO!!!
Old 05-03-2016, 10:25 AM   #625
7dee2
7dee2's Avatar
Re: 72 K30 Build
No worries, Blue my C30 has decided it needs some maintenance (jealous of the K30 ), Mrs.7dee2 is loading me up with honey do’s and one of my boy’s is moving again so just life taking over.
Brett
72chevy, dually, flatbed, k30, motorhome
