07-21-2019, 07:40 AM | #601 |
Re: Columbus..the 1957 IH 4x4..
Make a new tank?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
07-21-2019, 07:52 AM | #602 |
Post Whore
Possibly....I searched the net last night for gas tank cleaning...there are a few options out there...several companies that do it actually cut holes in the tank and sandblast the inside...then weld the patches back in ,and then seal the tank inside and out....I sent a quote request to a place in Ga..I'll see what they charge....if it's to high I may do it myself...or build a new tank....like I needed more to do...
07-21-2019, 03:37 PM | #604 |
Post Whore
Hadn't thought of clr John..I'll grab a jug and pour in it...but I have my doubts...
07-21-2019, 05:15 PM | #605 |
I know the pieces fit
Yeah I’m guessing at it. But you’d think there’s something simple and available otc that will dissolve that stuff.
07-21-2019, 08:17 PM | #606 |
Post Whore
i think the epa got rid of all the good over the counter stuff...dang epa
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 07-21-2019 at 10:32 PM. |
07-21-2019, 09:41 PM | #608 |
Proprietor of Dale's Corner
I'm thinking cutting the hole and sandblasting is gonna be the answer.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
07-21-2019, 10:29 PM | #609 |
Post Whore
I poured a gallon of apple cider vinegar in the tank this afternoon...gonna let it soak and see what that does...
at work we have a keylite chemical cleaning tank I thought about trying..its some stout stuff..will eat up aluminum..wont hurt metal...but I'm not sure how the filler neck is attached (its not welded,, I think it may be soldered)and worried about it coming loose... ive got some carb and parts cleaner ,,not sure what brand it is though...no label left on it and ive had it for awhile...
07-22-2019, 02:28 PM | #610 |
I had a carburetor full of crusted up gunk and it was suggested to me (on this forum) that I soak it in hot Pinesol. I didn't actually heat up the Pinesol, but I was pretty amazed by how well it cleaned up the carb. One guy said he diluted the hot Pinesol 20:1 although I just used it straight. Might work for your tank???
Rick 78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel 71 GMC C25 350/TH400 - Project Angie 59 Chevy SWB Stepside (next in line? Not sure now ) 2001 GMC Sierra K2500 |
07-22-2019, 02:31 PM | #611 | |
07-22-2019, 03:29 PM | #612 |
Post Whore
Funny yall mention pinesol...when you suggested berryman,I googled it and a video popped up on berryman vs pinesol....https://m.roadkillcustoms.com/carbur...k-alternative/
07-22-2019, 04:36 PM | #613 |
Post Whore
Well it seems like the vinegar may be working...I dumped a gal in yesterday and checked it today...it was sitting on the bottom and the bottom looked fairly clean...but the tank bottom was the best looking part of the tank...I dumped in another gal and have it on its side now...we'll see how it does on the worse looking stuff....
07-22-2019, 08:23 PM | #614 |
If the deposits are more rust than foreign material you might be able to try electrolysis. Fill up the tank, find an anode and run 12V through it.
07-22-2019, 09:01 PM | #615 |
Post Whore
thanks nitro...right now its the deposits that I cant get loose...
ive seen a lot of gunky gas tanks in my time, but ive never seen one this bad... gonna add 5 more gallons of a.c.v. in the morning and let it sit...we'll see what happens
07-23-2019, 11:07 PM | #616 |
I’m not sure if it would make a difference but hienz makes a cleaning vinegar that is 6% acid instead of 5. Looking forward to your results
Dwight |
07-23-2019, 11:56 PM | #617 |
Post Whore
thanks for the info Dwight...I didn't know there was different % on a.c.v...I just always grab the Walmart brand...I know the name brand stuff is nearly double the cost of wm..I use a.c.v. in my meat marinades for my smoker...
07-24-2019, 08:57 AM | #618 |
This is news to me. Now I'm going to check and see if the % is different between cheap and name brand. I also use it a lot for marinades for the smoker.
07-24-2019, 08:45 PM | #619 |
Post Whore
Well I checked walmart,kroger,and heinz brands of both white and apple cider vinegar...all of them are 5%...
On another note..the vinegar ain't working...the tank bottom is somewhat clean but it's not cutting anything of the sides or ends....looking more like I'll be cutting holes in it and sandblasting ....
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 07-24-2019 at 09:27 PM. |
07-24-2019, 10:16 PM | #620 | |
07-25-2019, 09:00 AM | #621 |
IMG_0176 by Robert Moorman, on Flickr
I found this vinegar, but it has some herbicide stuff in it too. I've used it, but make sure it's outside, well ventilated and you don't wash it off near any plant life and you NEED to wear proper PPE when using it. It's NASTY stuff! IMG_0175 by Robert Moorman, on Flickr This is the vinegar I use when I want to get rid of rust. 9% is as strong as I've seen if it's just straight vinegar. I don't know what it would do for that tank, but it took some chrome off of a wrench that was rusting. I soaked it for a day to kill the rust. It's now black. Maybe you could look for this on line before you cut into the tank. If you think it's worth a shot. You may be tired of waiting on this tank and be ready to get it done.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
07-25-2019, 09:30 AM | #622 |
I stand corrected, sum beach!
07-25-2019, 11:37 AM | #623 |
Post Whore
yikes !!!!! 20%....thats some stout stuff...
07-25-2019, 03:36 PM | #624 |
Maybe just seal/ coat the inside of the tank? You could lock all the garbage I under the sealer?
PS - you’re running all new fuel line - right?
Scott ______________ my '51 build: http://67-72chevytrucks.com/vboard/s...d.php?t=677979 |
07-25-2019, 04:14 PM | #625 |
Post Whore
Scott , i talked to the guy i got the tank sealer from and sent him pics of what the tank looks like inside...he says i need to have a almost 100% clean tank for the sealer to work properly...it sticks to bare metal..not the gunk i have...and yep ..all new -6an fuel lines
i got a ruff estimate from boyds tanks on building a custom aluminum tank..but there are a few things that the new tank will have to have to fit properly and work, fill spout location and angle,recessed sending unit and pickup, and theres a locating rib in the tank middle,...all that may drive a new tank price to high... looks like ill be cutting holes and sandblasting...
