#601 |
Almost Satisfied
![]() Join Date: Mar 2002
Re: 1971 Stepside LS Build
I started laying out all the wiring and plugging in the obvious stuff to determine routing etc. The kit is pretty simple once I had it all laid out where I could see it all in front of me. Got the wires ran to the front and rear. Crimped the front lights and began routing. Have to make it all pretty, but I am enjoying the puzzle and making it all look as clean as I can. I wanted to skip work today and continue working on the truck, but I decided I better not finish this thing up too quickly.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
#602 |
![]() Join Date: Aug 2018
There's something about a red interior in these trucks that really does it for me. I kind of enjoyed the wiring process, it was fun to start trimming out the interior and seeing things light up. The Autowire kit is great.
I know how you feel, I want to take Friday off work to take advantage of another warm day to get more priming done.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
#603 |
Very clean. Makes me wish I went ahead and lengthened/rerouted my LS harness into the cab. My PDU is "plumbed full"
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444 "It's only money". ![]() |
#604 |
Almost Satisfied
For those of you that did an LS swap with the AAW Classic Update kit...
1. Where did you wire in the PCM to the harness? I have a pink wire (BP Automotive harness) that I had going to my ignition pre wiring the whole truck. Not sure where to run it to on the harness for power. Use accessory plug? 2. Vintage Air. I have a 10 year old (brand new) evaporator. Has a red wire to batter and a purple wire to key power. Do I need to go to battery, or can I go to harness inside the cab for this somewhere? 3. Fans, I am using + fan wire from harness and fan 1 and fan 2 wire from PCM harness. What is the best way to jump the + wire from AAW to both fans. So, going from one wire to feed two fans. Will I have an issue doing this? For fan power I am going to my mega fuse block instead of directly to battery. Will that be an issue? 4. I hope this all works. I was feeling confident, but now I'm second guessing some of these last details.
#605 | |
2. I just got my evaporator and am planning to use the heater circuit. It's a pretty large wire (orange or red, can't remember). 3. I soldered two wires onto one connector then they split off to both fans. Mine are powered from the mega fuse and work just fine. 4. Don't worry! If you apply the same level of detail and forethought into wiring as you have on the rest of the truck, it will work great. Even if it doesn't, Plan B. Here's a picture of the backside of my fuel pump/fans fuse block. The pink is the fan wire from the AAW harness (basically just an ignition trigger so the fans can't run when the truck is off). Blue wires - one is the trigger from the PCM and the other is a lead for Vintage Air trinary switch (both ground triggers).
#606 |
Almost Satisfied
Thanks MD Potter. I appreciate you taking the time to answer those. Beaterku stopped by the house today to see the truck on his way through with the family and he set me straight
#607 | |
I used the 4-prong switch from PSI.
#608 | |
1. If your talking about getting power ran to your PCM, that should be CLEAN(fused) battery power straight to/from your battery. GM designed it this way. If your talking about ignition power, yeah, accessory circuit works just fine. 2. Vintage Air also recommends to get CLEAN battery power, direct from battery. I had to extend the power wire they sent in the kit because I remote mounted my battery. I mounted the connection right next to battery on frame rail. The key power I did same as mdpotter, used the "BROWN" heater wire from AAW harness(accessory power). ![]() And yeah, the brake switch you will need 4 prong. Here is part number if you want it. Also included my wire map for the brake switch just in case ![]() ![]() ![]()
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444 "It's only money". ![]() Last edited by TA_C10; 11-09-2020 at 06:30 PM. |
#609 |
Almost Satisfied
My AAW kit has two purple wires that go to the brake switch. I assume these are both 12v ignition wires. So, I add the PCM wire and then a brake light wire? Not sure on AAW kit what wire this is unless one of the purple wires I have is that.
#610 | |
Those two purple wires from the AAW kit basically get tied together when the brakes are on, allowing the starter solenoid to energize and it also sends signal to the brake lights.
#611 | |
![]() Join Date: Mar 2013
I don’t know about all of that. My OCD takes over and I just can’t stop lol |
#612 |
Those two purple wires go to the NSS(neutral safety switch). You have two options in the AAW kit. Standard trans or automatic. Since you have the automatic you will use the little adapter wire that turns the separate purple wires into a double purple wire plug that connects directly to the NSS as shown in my diagram above.
On my phone but can send a photo of this in the morning if needed.
#613 |
NM, found the pics...
First pic is both brake sw and nss switch. You can see the two purple wires plugged into nss. Second pic is the brake sw connection plug in AAW harness. White and orange. The AAW also includes a blue wire for optional 3rd brake light(I tapped into this blue wire btw, otherwise it's just 1 single blue wire joined at plug with white wire). This plug goes to the brake sw that you see in my first pic, not yet plugged in, open set of prongs. ![]() ![]() I used the AAW Deluxe harness. Should be same as yours. Study my diagram above and it should help make sense of it all. Wire colors should be identical. I built my engine harness, so that's the ECM TCC wire. Your BP engine harness should have a labeled TCC wire also. Have any questions let me know, I have more diagrams and a billion pics. .
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444 "It's only money". ![]() Last edited by TA_C10; 11-10-2020 at 01:59 AM. |
#614 |
Almost Satisfied
Thank you guys! I've ordered a new switch. Hope to spin around the neighborhood before the snow flies.
#615 |
![]() Join Date: Dec 2012
It will happen! Such an awesome truck. I am going to have to make a trip up to see this some day. Wiring is not my forte so maybe seeing it in person will help. Excellent job.
Keagan 68 SWB C-10 original 350 A/C 503 Mean Green |
#616 |
Thanks for all these details, great job!
#617 |
I feel like I should ask this question stepside. Are you using LED taillights? If so do you know about the ground you need to keep the TCC happy?
I found on my build thread where I posted about all these connections, maybe it will help. Post #593 gets into the above topic but on page 21 is where I started really getting into my AAW harness install. https://67-72chevytrucks.com/vboard/...switch&page=24 ![]()
#618 | |
Almost Satisfied
Did you come up with anything on your review mirror?
#619 |
Actually yes, siggy is making up more prints of the pivot ball again for me. I discovered one of them did not break under load and he is coming up with another design/material to test. I will have an update on this as soon as he sends me the new pieces. I'm pretty excited because it will be nice to finish this up and have a backup camera functioning. Speaking of that, I need to wire this up this week!
#620 |
Almost Satisfied
Decided to put down the crimpers and do something else for a break from wiring. Started messing around with potential speaker cabinet ideas behind the seat. I plan to run kick panel and tweeters in the front and then speakers in the rear corners with one 10" or 12" sub depending on what will fit. I want some space behind the seat for storage, so this is my preliminary idea. Transferring it to mdf will be fun
#621 |
must be nice to have a seat that folds down...... Ugh, jealousy setting in
![]() I really like your idea though. I will have a very similar setup. I will be interested to see how this turns out. Eventually I am going to bucket seats with console so I need to accomodate for that, but with your bench, I like how you are putting the sub directly in the middle. Is that going to be a 10"? I hear a single 10" is plenty for our small cab if the box is made correctly. EDIT: I like this guys idea and thought about doing something similar. What are your plans for that empty space for storage? Shelves? http://67-72chevytrucks.com/vboard/s...33&postcount=3 ![]()
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444 "It's only money". ![]() Last edited by TA_C10; 11-11-2020 at 12:43 PM. |
#622 |
That's going to be sweet. I have 2-10's and they're more than enough. Are you putting the amp on one side and using the other for storage? It looks like you're closing off the corners - that will be good so you don't lose stuff down there.
#623 | |
#624 | ||
Almost Satisfied
I just plan to leave those spaces open. When I say storage what I mean is a place to put some cleaning cloth and a couple cleaners ![]() Quote:
#625 |
Shannon it is all looking excellent. It is a good thing to be able to jump around between projects on your truck. It is easy to get bummed out working only only one thing. It all has to get done how you tackle it makes all the difference. That's my thoughts anyway.
Keep chugging along Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
