Old 04-30-2019, 12:31 AM   #626
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: The 1960 - 1966 Chevrolet & GMC Pickups Factory Correct Restoration Thread
Originally Posted by allchevy58 View Post
It comes off the relay, goes through two holes on radiator support, in front of the radiator, three clips hold it up in front of radiator, over to hole in radiator support right side of battery.
perfect! thank you so much.
Old 05-09-2019, 11:19 PM   #627
Johns 66
Johns 66's Avatar
Originally Posted by 60-66 View Post
On a solid white or off white truck the rim was black whether it was a custom or not. Also should mention here that white custom trim trucks only had white between the custom side door and bed trim , you see lots of black and red painted inserts on them but this is NOT factory.
Jon
Do you think this could have been a dealer add on, kinda like the rear bumpers. Reason I ask is I had a older local gentleman tell me he "Thought" that dealerships would paint the red/black strip between the trim to break up the white.
I know its hard to what if things because you could literally what if everything
Former Decorated Combat Marine...Semper Fi!!
Instagram jorourke322
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=734699
2019 GMC AT4
Johns 66 is offline   Reply With Quote
Old 06-15-2019, 03:34 PM   #628
bhap
bhap's Avatar
I am painting the dash on my 62 Custom C10 and would like to paint the glove box door inset the correct dark gray color. Does anyone know of a rattle can color/brand that comes close? Should this be satin or gloss or ?? Thanks for your help.
And thanks to 60-66 for the reference picture!
Bob
bhap is offline   Reply With Quote
Old 06-17-2019, 08:44 AM   #629
60-66
60-66's Avatar
Originally Posted by Johns 66 View Post
Jon
I suppose anything is possible , Chevrolet never did this but I suppose the new owner could request it. Ive collected a LOT of dealer pictures with these trucks in the showroom or on the lot. Not one picture is like that , But , its impossible to say if one or two possibly may have done this without some documentation.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 06-20-2019, 09:09 PM   #630
LVPhotos
LVPhotos's Avatar
How "rare" is the '62 day/night mirror... my 3rd optbut scored one intact. Every other truck had standard.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 07-05-2019, 11:10 PM   #631
Jargo
1963 frame off restored back original down to the correct bolts, screws, paint and engine, video is on youtube. This should help if you want to see original. (The oak in the bed instead of pine and an passenger sun visor are the only things not original)
https://youtu.be/t1PeXPF6whs
Jargo is offline   Reply With Quote
Old 07-06-2019, 06:02 PM   #632
1966 K10
1966 K10's Avatar
Beautiful truck!
Did you leave that one item non factory for personal taste or to test the purists?
1966 K10 is offline   Reply With Quote
Old 07-06-2019, 06:05 PM   #633
SBPage1
What a great video and more importantly a great story. Beautiful truck!!
SBPage1 is offline   Reply With Quote
Old 07-06-2019, 10:08 PM   #634
Jargo
Thank you
Old 08-05-2019, 02:55 PM   #635
msgtmac
What radiator are you using?
msgtmac is offline   Reply With Quote
Old 08-05-2019, 08:45 PM   #636
63gm
I'm wondering if anybody would have a picture with the dimensions of the cab from factory. I'm concerned my cab may have moved a little bit when I was taking the floor apart. thanks
63gm is offline   Reply With Quote
Old 09-11-2019, 11:04 PM   #637
demckenz
How many are aware of a date code stamped in the bed wood. Mine is a 66 SWB and has a date code stamp. Just throwing it out there.
demckenz is offline   Reply With Quote
Old 09-13-2019, 12:15 AM   #638
oem4me
That date code has been noted on a few trucks here, but most beds don't survive well enough for the stamp to remain visible. Also, I've noticed most that are reported are from '66. Not sure on the significance of that fact. Can I ask where your truck was assembled?
Old 09-16-2019, 10:42 AM   #639
demckenz
Assembled in Atlanta
Old 11-18-2019, 04:27 PM   #640
65 C20
Are you sure it is '62.
I purchased a re-pop mirror arm and put my '73 nova mirror on it.
Cal.
65 C20 is offline   Reply With Quote
Old 11-18-2019, 04:47 PM   #641
jbgroby
jbgroby's Avatar
It was a factory option as far back as 1960, Its listed in the OEm Options catalog as seen in the pic.
jbgroby is offline   Reply With Quote
Old 11-18-2019, 07:21 PM   #642
SBPage1
BHAP...did you ever get a response to your question on dash colors/paint? I’m having the same issue.
Old 11-18-2019, 09:51 PM   #643
LVPhotos
LVPhotos's Avatar
Cal.
Yes. I have had the truck since 1998 and know the previous owners. The original tan was under the rattle can paint. Probably never removed since installed. Short of junk yards there was no parts swapped except front fenders, now I got 2 nos ones to put on.
Old 11-27-2019, 08:19 PM   #644
bhap
bhap's Avatar
SBPage1, no I have not found the correct color for a 62 Custom Cab glove box door - anyone have a paint code or match?
Old 11-28-2019, 11:48 AM   #645
60-66
60-66's Avatar
Fawn Beige and Cameo white are the two colors for the dash
Old 11-30-2019, 06:22 PM   #646
bhap
bhap's Avatar
My question was the dark gray or black on the glovebox door on a custom cab - see pic a few posts up.
Old 12-01-2019, 10:48 AM   #647
60-66
60-66's Avatar
Im slipping , forgot about the gray. The only reference I find in the data book on that color is Charcoal Gray.
Old 12-15-2019, 07:25 PM   #648
Brad54
Brad54's Avatar
Hey guys, I've got a primer paint question:
I know the bed and front sheet metal got black primer, cap and doors got red oxide primer.
What color primer did the cowl covers and cowl vent get?
Also, and this is pretty important to me for my build, what color primer did the '60-62 grille, headlight doors and bumpers get?
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 12-16-2019, 02:38 AM   #649
oem4me
The factory primer/sealer on the cowl extensions and vent grill were red oxide, the bumper and front grill were black.
Old 12-16-2019, 07:27 AM   #650
SBPage1
Thanks BHAP and 60-66! My 61 has a darker gray colored dash and the glovebox has gray too. This is factory colors and I want to eventually paint the dash. I think I have found the correct color and will send a post after I test it on some other metal to see if its a match. Appreciate ya’ll!
