Old 04-30-2015, 11:19 PM   #626
CodyWorks
Talking Re: My new project 86 Silverado
Awesome. I may have misread the previous post. It was only like 15 pages ago lol. 600 is even better. Guaranteed smooth.
CodyWorks is offline   Reply With Quote
Old 05-06-2015, 10:22 PM   #627
Sodell
Sodell's Avatar
Are you going base coat clear...if so all you need to sand down to is 400. Use 400 wet....
Scott
87 Chevy 2WD SWB, 88 4x4 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=610652
Sodell is offline   Reply With Quote
Old 05-06-2015, 10:28 PM   #628
CodyWorks
X2 on what he said. 400 is really all u need to do. We used 320 for everything when I was doing collision repair. But you can paint over 400 w/ no problems at all. Also, it doesn't take as much time to block it down as it would w/ 600.
And I really hope your using base/clear. It's the way to go nowadays.
Old 05-22-2015, 09:52 AM   #629
naphtali5725
naphtali5725's Avatar
anyone help me with a partial frame VIN... stamped in two places on top of the passenger frame rail
CFF395273
my frame VIN and Cab VIN don't match...
to top it off... cab VIN tag has been removed/reattached in the past...
have to go thru BS with DMV... would like to know what the frame came from if possible...
thanks guys
My build thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=515829
Disabled Veteran
82nd Airborne Division
Operations: Desert Shield, Desert Storm, and Uphold Democracy
naphtali5725 is offline   Reply With Quote
Old 05-26-2015, 07:44 PM   #630
Sodell
Sodell's Avatar
CFF395273
thanks guys
What are you asking? You can use the vin from the cab...
Scott
Old 05-27-2015, 04:08 AM   #631
naphtali5725
it's all good... i figured out the info i needed from that frame VIN...
the frame and cab VIN don't match, pita
My build thread...
Disabled Veteran
Old 05-30-2015, 01:51 AM   #632
naphtali5725
DMV inspector was supposed to be here today to check it all out... didn't make it, he'll be here Monday or some other day next week.
i'll know more then
My build thread...
Disabled Veteran
Old 05-30-2015, 09:44 PM   #633
Sodell
Sodell's Avatar
That sucks
Scott
Old 06-02-2015, 02:10 PM   #634
naphtali5725
update...
alright here's the scoop from the NC DMV inspector...
cab VIN was valid, not stolen etc. 1986 long wheel base truck
frame 1985 short wheel base, and was stolen in 1987, legally recovered, then used to build my truck
he confiscated the VIN tag that was on it
they will issue 2 new VIN tags, with a NC issued VIN... (with the same number affixed in different spots... one in door jamb, and one under the hood)
one will be affixed underhood near the brake master cylinder
one will be affixed inside the drivers door area on the cab
NOT necessary to re-VIN the frame, but those numbers will be on the title record with the new VIN's to tie them all together in one vehicle
he said it was good that I had taken it back apart, if the cab or frame was in an active theft case, and the truck was assembled, they would have taken the whole thing.
however, since everything was apart, all they would have done was either take the cab or frame by itself if either was an active theft case
once they come back in 2 weeks with the VIN's and apply them, then I can go get it re-titled in my name, whilst i wait for the title to come back, it will have to be bonded as proof of ownership until title is in hand
once title is in hand with the new VIN's, that's it, all is ok, nothing to worry about anymore
so i'm glad i went through the correct procedures, if it would have been found out during a traffic stop, or whatever... it would have been impounded, legal fees, lawyer fees etc. etc. etc. you know the deal...
that's about it. inspector suggested getting stuff like this taken care of before you drop a ton of money into it, he's seen guys heartbroken when they tow their **** away, and it takes about a year for the judicial process to get it back
FWIW
My build thread...
Disabled Veteran
Old 06-11-2015, 08:01 AM   #635
naphtali5725
2nd update:
DMV inspector came yesterday, he affixed the 2 VIN tags to my truck... they are made of the same stuff as the month/year stickers on a license plate... just stickers with the new NC assigned VIN
one in the door jamb, the other near the master cylinder.
next step, i have to get it bonded for 1 1/2 times the estimated tax value, and then go apply for the new title... bonds start at 100, not sure what the estimated tax value is...
and that's it... process was pretty straight forward, the inspectors were both really cool about everything, we talked about other stuff more than about my truck, hope this helps!
My build thread...
Disabled Veteran
Old 06-11-2015, 10:02 AM   #636
naphtali5725
estimated tax value was 560.00 LOL
My build thread...
Disabled Veteran
Old 06-11-2015, 10:43 AM   #637
68Timber
I know the pieces fit
68Timber's Avatar
Good to hear everything went well. The sticker part is a little odd. What happens if you lose them? Do you have to go through the whole process again? I was expecting a "new other" vin tag with rivets, something a little more permanent.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 06-11-2015, 12:52 PM   #638
naphtali5725
i thought the same thing... but it's a sticker with my NCS number(VIN) from the NC DMV, since all the paperwork blah blah, is already done, a replacement sticker would be issued, same number. but it's a little weak, i mean how much does a number tag stamping machine cost?
My build thread...
Disabled Veteran
Old 06-27-2015, 04:42 PM   #639
naphtali5725
next week, i should have my bond for my truck, so i can apply for the title. when i get the new clear title, i will re-assemble what I had, and continue on, i obviously didn't get it done in time for my birthday yesterday as i had planned, so i'm hoping by the 1st of the year...
My build thread...
Disabled Veteran
Old 06-27-2015, 09:02 PM   #640
jpnh
jpnh's Avatar
Happy birth day/good luck on the truck
jpnh is offline   Reply With Quote
Old 06-27-2015, 09:07 PM   #641
naphtali5725
thanks man, they say after 50 it all goes downhill fast LOL
My build thread...
Disabled Veteran
Old 07-01-2015, 11:09 PM   #642
naphtali5725
sneak peak of the other engine...
My build thread...
Disabled Veteran
Old 07-06-2015, 10:00 AM   #643
naphtali5725
these heads for the new motor
http://www.ebay.com/itm/BERNARD-MOND...item3f4a263788
My build thread...
Disabled Veteran
Old 07-06-2015, 10:12 AM   #644
68Timber
68Timber's Avatar
A friend bought a set of those for an Olds 350 he has. They're not installed yet but he said they looked good out of the box.
John
74 Honda Z50 build
Old 07-06-2015, 10:17 AM   #645
naphtali5725
they're good for close to 500hp out of the box with the right cam/intake/carb etc. on a 455 or stroker, so my goal of 450 should be doable pretty easily
My build thread...
Disabled Veteran
Old 07-18-2015, 11:57 AM   #646
naphtali5725
still waiting to go get my bond for 1 1/2 times the value of my truck, which is about 800.00
bond is 100.00, once i get that I can go apply for my new NC title
taking a little bit of time, had football camp to go to for my son, so i'll be on track next month
updates real soon
My build thread...
Disabled Veteran
Old 07-27-2015, 07:55 AM   #647
naphtali5725
updates on the new motor... short block is done from pan to cam, i have my heads, and other engine items ready for install
should be able to run down to Florida and get my motor in a few weeks.
My build thread...
Disabled Veteran
Old 07-27-2015, 12:06 PM   #648
NONHOG
NONHOG's Avatar
Mark doing this engine?
"I feel the need for speed!"... as soon as I am done with my nap.
NONHOG is offline   Reply With Quote
Old 07-27-2015, 12:45 PM   #649
naphtali5725
cutlassefi? yes he is
do you have an Olds?
My build thread...
Disabled Veteran
Old 07-29-2015, 08:12 PM   #650
naphtali5725
engine is done to the point where i need to assemble it the rest of the way... heads/intake etc.
My build thread...
Disabled Veteran
