03-30-2022, 09:53 PM | #626 |
Post Whore
Re: My Dusty 71 GMCe Electruck
well dem ISOFORMA USA Amazon vendor peeps did us no favors weldering that stud aka bolt in there like that for us, don't tell a.c.ward but gosh darn it he was right it was impossible to extract this contraption in it's current native state, so these bolts had to be liberated, thank you for using cheap easy to grind grade 5 hardware
and don't we all just luv buying new parts, just so that we have to modify 'em! |
03-30-2022, 10:09 PM | #627 |
Post Whore
alright there it is, the transmission supported by a custom rubber mounted bracket, I am very pleased with the result
03-30-2022, 10:11 PM | #628 |
Post Whore
what's that, you wanna take a closer look at the grinds, I mean the welds, ... sure
03-30-2022, 11:57 PM | #629 |
I usually dont think far enough in my "projects"to plan ahead for remove-ability. then have to redo it, lol
your work looks good brother.
A C Ward Retired US Army 66 El Camino 67 SWB underwent major Surgery- http://67-72chevytrucks.com/vboard/s...d.php?t=776475 |
03-31-2022, 07:25 AM | #630 |
6>8 Plugless........
It's looking really nice. I still say a mockup gas engine needs sat in there to make it look like there really is a gas engine in there. What Jeep do those mounts come from? That looks like a good option for many things.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
03-31-2022, 07:56 AM | #631 | ||
Post Whore
thanks, appreciate that
here's a direct link and a pic of the listing for when the link expires ISOFORMA USA Polyurethane Motor Mounts - Heavy Duty, Durable Bushing, Fully Welded Interlocked Steel - Compatible with 2/4WD 1986-2006 Jeep Comanche MJ, Wrangler TJ, YJ, Cherokee XJ Engines - 2-Pack |
03-31-2022, 07:59 AM | #632 |
Post Whore
so I was dying to try and fit the batteries back in there
03-31-2022, 08:04 AM | #633 |
Post Whore
it's gonna be s!ck
same pics from a little bit of a step backness, just to try and take all that perspectus in |
03-31-2022, 08:12 AM | #634 |
Those batteries being almost flush with the top of the frame sure would leave a lot of room for a front trunk though. That Bluetooth steering is cutting edge. I think the funniest thing I saw from SEMA last year was a big lifted truck had no front drive shaft. Instead it had the Bluetooth logo cut out of aluminum and bolted to the yoke flange. You might even be able to incorporate something like that on this build.
03-31-2022, 08:16 AM | #635 | |
Post Whore
Note: the sharp peak in the middle of the first battery pack is there because I have yet to cut holes for the engine crossmember bolts in the aluminum brackets, once I do that they will go down about 1 1/2" |
03-31-2022, 06:23 PM | #636 |
Your motor compartment is starting to fill up nicely.
03-31-2022, 08:11 PM | #637 |
Post Whore
03-31-2022, 11:04 PM | #638 |
04-01-2022, 01:08 AM | #639 |
Proprietor of Dale's Corner
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
04-01-2022, 04:09 AM | #640 |
Post Whore
and doin' the million mundane little things
04-01-2022, 06:28 AM | #641 |
Since you’ve got those pesky bolts removed, could you weld the nuts to the bracket for easier removal? Nice progress!
71 C10 72 K20 72 K10 Super Kirk |
04-01-2022, 07:12 AM | #642 |
Maybe even one with a generator on it for back up situations? That way if you can find some gas you can at least recharge your batteries and make it where ever.
04-01-2022, 10:41 AM | #643 |
Post Whore
04-01-2022, 10:43 AM | #644 |
Post Whore
I got the stock OEM Lexus GS450h two piece drive shaft so I started to work on the middle donut support mount, I believe it's crucialistic that the short shaft is perfectly in line with the transmission
I started out by divorcing the two pieces just to make the short stick lighter and easier to work with, plus mounting it by itself gave me a line of sight to test with my eyecrometer |
04-01-2022, 10:45 AM | #645 |
Post Whore
I also chose to remove the bulky rubber doo dad off the long shaft, at the end that would mate with a Lexus differential
this is where we will welder up an "American" [pronounced: Universal] joint |
04-01-2022, 06:00 PM | #646 |
Post Whore
next it was time to stack sum plates
for this I decided to work out front in my driveway, figuring it's been days since my last HOA complaint! |
04-01-2022, 06:01 PM | #647 |
Post Whore
here I'm just showing off my protractor and sliding ruler skillz
04-01-2022, 06:09 PM | #648 |
Post Whore
Public Service Announcement
If your drill remnants look like this, this means you have a good sharp drill bit. This is Goodness! If they look like sparkle glitter that means you have a bad dull drill bit. This is not good. |
04-01-2022, 06:10 PM | #649 |
Post Whore
poking holes
04-01-2022, 06:13 PM | #650 |
Post Whore
yes, but what is he making ???
