01-03-2010, 10:45 PM | #651 | |
VA72C10
Re: 1970 VA Longbed Project
You can pre-set it to a height to raise when you start up, and set three preset heights. Also can manually adjust how you like or dump all... Check out kevin of LFD (Rockcrln) thread about his 4 door tahoe project...he did an install of the kit with a writeup of the product. If you google it there are several videos of it working...I will put one up when my truck is to that stage... Thanks! Gotta stay ahead of you...you're moving on your blazer project!
Looking for a 67-72 swb or blazer project in or around VA. |
01-05-2010, 12:40 AM | #652 |
THE DAMN YANKEE
Johnathan, you are as methodical as a serial killer! Your truck is one sweet assride!!! subscribed!!!! looks awsome keep us posted. R, The Damn Yankee
01-05-2010, 12:47 AM | #653 |
VA72C10
Man, I don't know to take that as a good or bad thing J/K Thanks! Should have some more pics tomorrow...
01-05-2010, 07:42 PM | #654 |
Blaze-Air
It took me a couple of hours just to get caught up on your build. Awesome build. The amount of thought and hard work are showing. Great work Jonathan.
Hope your feeling better. |
01-05-2010, 07:54 PM | #655 |
VA72C10
Thanks...finally had to get some antibiotics and now I'm doing better. Going to go over and get some more stuff done this week hopefully...
01-06-2010, 12:03 AM | #656 |
Sofa King Crazy!!
Peppermint, Honey, Lemon and Jack - mix and drink......that will make you right again!! If there ever was such a thing!!! hahaha Lookin great! Keep it going!!
You found the Tater. My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. 1972 2wd Blazer "Porterbuilt and Sloshed" |
01-06-2010, 10:57 AM | #657 |
Greasemonkey
looking good man this thing is gonna be sick ill let you park next to me any day lol
1970 cst-10 longbed speed My Baby http://67-72chevytrucks.com/vboard/s...=1#post3113923 |
01-06-2010, 03:45 PM | #658 |
Pictures!
69' 1/2 ton LONGBED__ _______ |__\__ |__(O)______(O)] My build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=354115 |
01-06-2010, 06:13 PM | #659 |
Blaze-Air
After doing the blocks to center your tires in the wells, and having to remove the rivets, and doing the exhaust pass thru's. Would you think about getting a aftermarket center xmember if you had to do it again? Do the aftermarket ones center the tires? just curious.
01-06-2010, 07:37 PM | #660 | |
67-72 parts collector,…
But you can add the spacers just like VA72C10 did. |
01-06-2010, 07:47 PM | #661 | |
VA72C10
01-06-2010, 08:01 PM | #662 |
Just curious,... If you could do it again,... wouldn't it be easier to just "relocate" the complete trailing arm crossmember back,... the require distance?
I believe that's the route Porterbuilt is going. That way, he can build all his tubular trailing arms are the same length. And,... I'm just a moderator. No expert here. |
01-06-2010, 08:02 PM | #663 | ||
VA72C10
Soon
01-06-2010, 08:08 PM | #664 | |
VA72C10
Come on, don't sell yourself short. You've helped a ton of us out. Thanks!
Looking for a 67-72 swb or blazer project in or around VA. Last edited by VA72C10; 01-06-2010 at 08:09 PM. |
01-06-2010, 08:44 PM | #665 | |
*pending bag mounting & notch area
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-06-2010 at 08:46 PM. |
01-06-2010, 09:13 PM | #666 |
Grandpa in the rustmobile...
I cant believe ive never read your build!!! Going to be a sick truck when your done! Whens the projected done date? You have sold me on a few things for my truck, holes in the crossmember for exhaust. (Could one cut the holes without a plasma cutter easily?) I wanna do mine but not a fab expert but have a welder and access to good welders (actual people lol). And im doing my frame in 'hammererd' it looks awesome! Cant wait to see it done. Keep it up. If i knew I had that much $ in my truck. I wouldnt add it up! I thought I had lots in mine LOL. Not even a fraction.
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
01-06-2010, 09:23 PM | #667 | |
VA72C10
I'm sure it could be cut w/out a plasma but it's much easier that way. Thanks...I'm happy with how the hammered finish turned out.
01-06-2010, 10:59 PM | #668 |
Couldnt possibly do it with a hole saw...to thick Id guess......im running 2" exhaust but would like the option to go bigger 2.5 or something.
Could get a crossmember from junkyard and take it to somebody with plasma cutter...whyd you go oval vs round? I cant wait for warm weather so I can spray paint. 25* with snow tonite isnt appropriate weather for spray bombin'. Looking forward to your finished truck.
01-06-2010, 11:20 PM | #669 | |
VA72C10
01-07-2010, 11:20 AM | #670 |
crossmembers are the same67-72 as long as its trailing arms, correct?
01-07-2010, 08:52 PM | #671 |
VA72C10
Yes, all the trucks I've seen have the same....other than a carrier bearing mount on longbeds...
01-08-2010, 10:24 PM | #672 |
VA72C10
Since you guys love pictures as much as I do...here are some buckets I'm hoping to pick up next week for the truck.
01-08-2010, 10:31 PM | #673 |
I Like Mine With No Shine!
Those are nice lookin. What are they from/for?
Michael 1967 Chevrolet C10 Short Fleet (Literal Ground Up....One Day) 2006 GMC Sierra Crew Cab 4x4 1969 Lincoln Continental Coupe Project FOR SALE http://67-72chevytrucks.com/vboard/c...ct=4578&cat=17 1981 Honda CM400 C Bobber SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=384152 |
01-08-2010, 11:02 PM | #674 |
VA72C10
they are aftermarket designed for hot rods. They are lowback buckets approx 24" tall plus the brackets...I will modify them so they fit right underneath the window
I won't have any updates this weekend because I'm traveling to Florida. My wife's grandfather has cancer and has just decided not to take any more Chemo because the cancer is still spreading. So we want to visit with him before his health goes further downhill. Going to leave in a few hours, drive all night/day and see him tomorrow. Have other family near Tampa and then will head back Sunday so I can be back at work Monday.
01-08-2010, 11:21 PM | #675 |
If you have any problems or need to stop for a break going down or coming back, give me a call. We are about 30 miles off I-95 I'll PM you my new phone number.
1969 C10 SWB Project Charity Case AKA "Roscoe" 1971 Cheyenne Super A Combined Effort The Service Station-A practical ministry for those in need |
