#651 |
Re: Rustbuket 67 build "Georgia"
To finish off the accessories I decided to change over to an OE type non ac setup. This meant just buying a ribbed pulley and a new belt which I needed anyway. I did however need a spacer, bolt and washer so back to LKQ for the goods. Here is the ribbed idler pulley with the LKQ yard spacer,washer, and bolt ready to install. the spacer and hardware is the same for smooth or ribbed idlers if you need one.
![]() ![]() I installed the upper intake and throttle body and while at LKQ I picked an S10 4.3 intake hat to replace that disgusting GMT vortec box thing and swap sides with my intake. I ordered a cheap Ebay S10 cold air intake kit also, just waiting on the brown truck to deliver that. Here are a few pics as she sits now. ![]() ![]()
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
#652 |
That is a strange looking EFI. 'Spider' is a good term for it.
So no A/C in wonderfully hot and humid OK? You are tougher than me. ![]() Great to see some progress again, though!
Eric 1967 C10 SWB 383 Stroker/TH400 Brother's One Piece Power Windows Shaved Doors, Markers, and Bumpers 4/6 Early Classic Drop Rear Fuel Tank (49-52 Chevy Car Tank) Surf Blue Paint Bella Vista, AR (Arkansas for those that get the 'A' states mixed up) My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=330869 |
#653 |
nice build!
my 86 c10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=496829 my 56 3100 build: http://67-72chevytrucks.com/vboard/s...09#post5712509 my 95 silverado build: http://67-72chevytrucks.com/vboard/s...35#post5879335 my gray 86 c10 http://67-72chevytrucks.com/vboard/s...34#post7624734 |
#654 |
Hey Dan,
What's going on? Your last post was in April! How's everything going? -Darien
___________________________________________ Darien 1971 C10 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=502964 |
#655 |
is this truck still being worked on? it's like you fell off the face of the earth
#656 | |||
Thanks, I dig your square! Quote:
#657 |
Hey Dan, glad to hear you are still around and kicking, even if you are kicking slowly.
I have been distracted with a bunch of stuff going on myself, but am hoping to get back to it in the next couple of weeks. Hope everyone is doing well. Hope to see some pics and progress soon. -Darien
#658 |
![]() Join Date: Oct 2011
Dang Dan,,, nice work on the exhaust!!! Are you going to be in the Lewiston Idaho area any time soon?? I could use a little help on my exhaust!! What made you choose Flowmaster mufflers? looks like it's been a while since any new updates,, any news on the latest??
Wade ![]() , JUST WALK AWAY, AND I'LL SPARE YOUR LIVES!!! , Build thread "TANGERINE" http://67-72chevytrucks.com/vboard/s...d.php?t=498570 Board Members Met: bigblock68, ol_skool_chevy ,68TT,atvpro |
#659 | |
#660 |
Still here...
So this is where is started with the passenger side rot. ![]() ![]() ![]() ![]() ![]() Rusty **** box. With that all cut back out of the way I began to fit up the outer floor extension. I reall couldn't ask for a better fit. ![]() ![]() This time I cut around the hump because it doesn't match up too well with the OE floor. Also had to open up the seatbelt attaching home quite a bit. Still a great fit compared to the other side of the truck. ![]() With that all lined up I prepped the outer floor by removing the black EDP off all mating surfaces and edges to be welded. I applied UPol copperweld to all overlapping surfaces once sanded. ![]() ![]() ![]() Next up I sand blasted and sand blasted and blasted some more. That crap was in my ears and nose and everywhere. Once blasted clean, I coated the cab supports with Eastwood rust encapsulated and again used Upol copperweld on all overlapping surfaces. ![]() ![]() ![]() Burning the floor edge in. I plug welded it to the cab supports but I didn't get a pic before sanding those smooth. ![]() ![]() ![]() Making it smooth. Grind, sand, sand. Gotta love those Roloc disks! ![]() Almost done. ![]() There she is. Good as it's going to get for a floor. ![]() ![]() ![]() A little primer to keep from flash rusting. ![]() ![]() ![]() ![]() Next up the rear pillar or "b" pillar. This part is awful. I had to slice and dice and flatten and reform and talk dirty to get this piece into submission. Grrr. ![]() ![]() Back side of the b pillar. ![]() Needs to be finish welded across the seam but done for the moment. ![]() Moving on to the kick panel. Here's what's left of the "a" pillar, blasted clean. ![]() ![]() Once again, sanding all mating surfaces to plug weld and coated with copperweld primer. The kick panel is a pretty good fitting patch. No big complaints there. Well one complaint. The kick panel fits great by itself, the "a" pillar seems to fit great by itself but the kick panel and "a" pillar do not fit together very well with one another. ![]() ![]() ![]() ![]() ![]() I am going to have to do some serious cowl repair and pull the firewall back in. It had a gap at this seam from the factory. Or at least since I got it. You could see how the spotwelds pulled the metal across the gap. There were big gaps between each spot weld. ![]() Here she is welded in. I did not weld it to the firewall yet, I have to whip up a patch to fill in above this piece and part of the cowl. ![]() ![]() Now I am fighting the "a" pillar. It is giving me hell so far. I cut it down but it sticks too far out, like it's too tall. I sliced it vertically so I can get the hinge mount surface to sit flush. I am almost satisfied with it and hope to have it burned in soon. Here an early test fit pic. It appears to fit well in the picture... ![]() I will say that the rocker panel is a great fit in every test fit so far. ![]() I guess I didn't upload a whole side view with the rocker clamped on. I will get one uploaded later.
#661 | ||
Mostly working, raising kids, and I spend most of my free time in the gym nowadays.
#662 |
I have other updates but let's stick with getting the cab squared away first before getting back to the drivetrain.
#663 |
![]() Join Date: Mar 2011
Dan, rust repair is a bear, but you are doing a great job. Will look just like new when your done...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> Last edited by oldman3; 05-14-2017 at 09:19 AM. |
#664 |
Glad to see some progress, if you want some help you know how to get a hold of me.
"God will often give you more than you can handle so you can learn to depend on him rather than on yourself" ...Craig Groeschel |
#665 |
Still Learning
What's up Dan? Good to see you still have Georgia. Nice work on the rust repair.
#666 |
Well, it's good to hear from you. Looking forward to hopefully seeing some updates sometime soon. Glad you are doing well.
