11-23-2020, 02:07 PM | #651 | |
Re: 1971 Stepside LS Build
11-23-2020, 04:42 PM | #652 |
Looking really good step!
For the DD fuel sender. The instructions say "recommend" you run 2 wires back to sender. I did not do that and it works pretty accurately from what I can tell. 1. I ran the 1 wire back for data connection on sender. 2. Sender grounded to frame. 3. DD sender ground connection(I just ran this to ground buss in cab via the AA wire harness. I have ran the tank empty couple times, put in 5 gallons once, put in 10 gallons another time, they all read correctly. I think the issue is ground here. If you don't have an excellent ground, resistance and/or noise on the grounds could make the gauge not read correctly(like when your radio isn't grounded well and you hear engine rev in your speakers). Using twisted pair helps reduce noise on those lines. I won't say this is perfectly spelled out here, someone can correct me if needed, but you get the picture. Check them grounds!
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444 "It's only money". |
11-23-2020, 05:12 PM | #653 |
Almost Satisfied
Good to know. My setup appears to be working and I don't want to mess with those two wires ever again
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
11-23-2020, 06:14 PM | #654 |
Yeah it should be fine. If it doesn't read at all I would say you have either a wire connected wrong or damaged, or, you didn't go into the DD setup menu and calibrate the sender to proper ohms.
11-23-2020, 06:18 PM | #655 |
Almost Satisfied
71CadC10 was having the issue. I am not. Hopefully, this will help him though
11-24-2020, 10:35 AM | #656 |
I have DD gauges in my Camaro with an LS swap. I love the gauges, but they do have their quirks. I had to send the BIM back to them multiple times in order for them to get all the gauges working, and even then I ended up running a separate oil pressure sender. They're also sensitive to EMI.
But once they're working, they are really nice!!!! At any rate. I love this build! Keep at it! |
11-24-2020, 12:27 PM | #657 |
yes thanks...the twisted pair was the only solution I could get to work. Just wanted to ask others experiences.
Had the 0-90 GM programmed in setup originally had 1 wire going to 'sender' on DD box. tank flange grounded to the frame right by the tank. I hooked Ohm meter to the sender with bed off, I would get a good reading with key off. As soon as I would turn key to run position, the ohm meter would show 1- (infinite resistance I believe = open circuit). Once I ran 2 new twisted wires, the 2nd wire I hooked to 'sender -' on the DD box. ran this to a screw on the tank flange. Now it works...maybe someone better in electronic circuits can explain it...I'm just happy to put bed back on and be done with that issue LOL.
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear |
11-25-2020, 10:21 AM | #658 |
Almost Satisfied
Started working on the sound system. I want the tweeters up higher and not in the kick panels. I've seen a couple different ideas where they are cut into the dash above the ac vent, but I don't want to cut the dash. I think I really like this location. Now to see if I can fabricate a housing that fits into this area and looks like a mini ac housing for the tweeter. A 3D printer would be really handy right now, but I will have to use fiberglass or keep it simple and go with a plastic pipe that is made to fit.
11-25-2020, 12:15 PM | #659 |
These trucks are difficult to put things like tweeters in inconspicuous locations. I have decided to go with component front speakers, mounting the tweeters in the doors. When I have new door panels made down the road, I will have tweeter pods built into them so they angle the tweeter towards the center of cab rather than flat on the door.
I think your idea here will be just fine. They should be up higher for their intended use, but dude I don't think they would look good above the A/C vents and also, your probably not going to notice much difference anyways having them a little low. Especially if your not daily driving it and hearing it on a regular basis. Looking good! .
11-25-2020, 12:37 PM | #660 |
I find myself shutting the radio off and listening to the truck more often! Just to hear it and also to listen for any odd noises...
But I'm also glad I have a good amount of bass-I like to feel my music too.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
11-30-2020, 12:25 PM | #661 |
Almost Satisfied
29 years later she backed out of the garage on her own power and with brakes
Of course, it was raining yesterday when we finally got the brakes bled out. That kept me from going around the block. I am now on a mission to get a better tune loaded so it will run well enough to enjoy the trip. The initial tune is so rich that it just loads up and dies without a little throttle at all times. Still working on the stereo speaker placement. I'm leaning toward just putting the tweeters in the kick panels like everyone else does....boring!
11-30-2020, 12:32 PM | #662 |
Congratulations! Big milestone.
What ecm are you using? I'm considering a holley. Also what size wheels/tires are you using? |
11-30-2020, 12:40 PM | #663 | |
Almost Satisfied
11-30-2020, 01:10 PM | #664 |
Big day - congratulations!
11-30-2020, 01:59 PM | #665 |
It looks killer man. Excellent job. Ready to see that bed install!
12-01-2020, 10:09 AM | #666 |
SOOOOO CLOSE!
Looking awesome. Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
12-02-2020, 12:50 AM | #667 |
Fantastic! Been seeing the progress on the ol FB. Hoping to get down there and see this at the meetup in April!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
12-02-2020, 09:02 AM | #668 |
I'm trying....
Big step. Looking awesome. Congrats.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
12-02-2020, 02:45 PM | #669 |
29 years- wow! Good for you!! Looks nice
71 C10 72 K20 72 K10 Super Kirk |
12-04-2020, 11:31 AM | #670 | |
I have one 10" shallow JL in my 4 door F-250 and it is plenty IMO. I can't imagine one in a reg cab. I went with the JL C5's in the doors and it never distorts even at full volume. Awesome build...its an inspiration for mine that I just tore completely apart. Hope mine turns out half as nice as yours. |
12-07-2020, 10:36 AM | #671 |
Almost Satisfied
What a weekend. I decided to drive her around the block on Saturday. It was a little nerve racking to say the least. The tune continues to be a struggle. My local tuner only wants to put a baseline tune in until I take him the truck. Because of this, it runs really poorly and wants to die when I slowed down at an intersection or turn. The transmission was slipping, but that was just a low fluid situation. Guess I should have tightened the bumpers up all the way because I could hear them rattling I did notice that I can hear the power steering pump moaning more than I would like. Is that normal and you just can't hear it on the moderns? Lastly, it seemed to get hot quick. A fan kicked on and the gauge was reading over 220. I must have an air pocket or something. Have to resolve that.
Getting closer for sure. I'll take it to the tuner after Christmas and see if we can get it lined out.
12-07-2020, 10:41 AM | #672 |
Almost Satisfied
Since I couldn't resolve the tune issue and just didn't want to mess with the temperature problem I decided to work on my kick panel enclosures. My original mock up was quickly trashed due to the dimmer switch being in the worst location. Tip for those of you building and wanting to go with kick panel speakers...move your dimmer out about 2" now.
So, I worked on this set up. I can just get my foot under the speaker to hit the dimmer button. I don't think I will ever use the high beams on this truck as it won't be out on back roads at night unless something went really wrong. I can hit it for the inspection though This was my first time building something like this and using the fiberglass resin. I was a lot of fun and was a pretty easy project. I did get in trouble for smelling the entire house up with the resin
12-07-2020, 11:00 AM | #673 |
Sorry you're having so much trouble with your tune. I had a tune put in my PCM by Tunedbyfrost.com as they are pretty reputable on LS1Tech and it ran really well. Started right up, idled great even with my cam. No issues with dying or running rough. Once I got HPTuners, I did a couple scans and the trims weren't very far off. I've spent some time fine tuning it, but I was impressed at how well it ran out of the box. It's about $250 and you'll be without your PCM for a couple weeks though.
You'll have to add coolant as you drive it around - probably an air pocket. Did you fill the engine through the upper hose first? That's what I did and then monitored the overflow tank and no issues now. Also keep in mind that these engines run pretty warm from the factory. Tuners typically lower the fan temps so they come on right around 200 which is 10-20 lower than factory. I thought if you were running a standalone water temp sender that the temp could be reading differently than the OEM sender, but I believe you have Dakota gauges reading through OBDII so they should be accurate if coming from the factory sender. Also check your power steering fluid and spend some time turning lock to lock to get it bled. Just keep taking it for short drives and checking everything and soon things will normalize and you'll get to where you only have to check fluids once a week and can just get in it and drive it without worrying as much. But I know the feeling-after having your hands on every single nut and bolt and now having a running vehicle you're constantly listening for noises and things out of the ordinary. Those speaker enclosures look sweet!
12-07-2020, 11:46 AM | #674 |
Great progress man, kicks are awesome!
12-07-2020, 11:57 AM | #675 |
Almost Satisfied
Thanks guys!
I do understand why they want the truck to tune it. They have been burned by putting in a "close" tune and then the guy goes out and runs the crap out of the engine and then blames the tune for something failing. At the same time, I think they should be able to get it close enough that it will at least go around the block. I think I will check out the place you suggested. I can live without the ecm for a couple weeks. I did fill the upper hose initially. Should I let it idle with the radiator cap off and see if I'm getting bubbles? I felt the heater core hoses at the firewall and they were warm so I think the water pump is pumping. I didn't change out the thermostat or water pump on the engine...I probably should have when it was all apart.
