08-31-2019, 09:15 AM | #1 |
Re: What did you do to your truck today.The 3rd chapter
Got a couple sets of Rally wheels blasted and painted. Need a set for a K10 shorty and a K5 CST we are restoring.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count |
08-31-2019, 03:28 PM | #2 |
SoCoC10 - I’m jealous. Been looking for a set of rally’s for a while now. Keep missing them by a day. Arrrggghh!
Son and a few of his college buddies were in today so I got them to lend me a hand with final bed disassemble. Will pressure wash the rear section and start tearing it apart for new springs, seals, brakes, lines, bushings, u joints, etc. Why do photos posted from my phone always post sideways and how can I fix it? Guess I should just use my laptop. Last edited by 67C10Step; 08-31-2019 at 03:29 PM. Reason: Spelling |
09-01-2019, 02:33 AM | #3 |
Have you considered going Hugger Orange on the rallies? I went Ochre on mine to try it out and I like em. I know it's not for everyone, but I'm liking the look that I think gives it a vintage persona.
09-01-2019, 08:29 AM | #4 |
Proprietor of Dale's Corner
I was thinking "eeeeww " while I was reading but much to my surprise. They look good!
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
09-01-2019, 09:16 AM | #5 |
-Chris
Placed a 2k order with ClassicParts.com! Come on parts!!!!!!
1970 Chevy C-10 P/U, Shortbed, Fleetside - 5/7 drop, 496, TH400, 12 bolt. BUILD THREAD - http://67-72chevytrucks.com/vboard/s...d.php?t=404481 2012 F250 Super Duty P/U - intake, exhaust, tuner, 4" lift with 35's 2017 Chevy Suburban (Wifes Car) - Fully Loaded & Stock "Some people spend an entire lifetime wondering if they made a difference in the world. But, the Marines don't have that problem." Ronald Reagan, President of the United States; 1985 |
09-01-2019, 04:36 PM | #6 |
Active Member
Painted the kick panels the golden Fawn color the interior will be. Also tore apart the heater controls and cut off everything that wasn’t necessary. Glued the knobs in place then painted it black how 67’ should be. Doing the same idea with the radio since I’m not using it either. I like the idea of more space under the dash plus any weight savings I’m into.
Posted via Mobile Device |
08-31-2019, 04:08 PM | #7 |
I put the carpet in today
08-31-2019, 07:49 PM | #8 |
08-31-2019, 09:13 PM | #9 |
Finished up the dash wiring , tested all lights and gauges . Everything works great except wipers , I used my old switch and no wipers. I know the motor works , pre tested . And it’s a AAW wiring harness , so I know that’s good again , tested . So new wiper switch it is.
Then onto engine wiring and lighting up front. |
09-03-2019, 08:36 PM | #10 |
Pulled out the broken dip stick tube with a bolt and lube.
09-03-2019, 08:43 PM | #11 |
Very soon, hopefully tomorrow, I will be able to show off my new door panels - black vinyl and blue/black houndstooth fabric to match the seat. If it wasn't such a fiasco getting this done, I wouldn't be able to laugh about it - and it will be long remembered as a good idea gone bad. I bought a new set, and the houndstooth pattern was not right - an aqua blue. I couldn't return them, so I ordered the correct cloth from a place in Canby, Oregon. Today I took them in for recovering, and the cost is going to be a little higher than I had hoped. To make matters even worse, they can't remove the fabric from the cards (super glued, you might say), so it is tearing them up. They have to make new door cards for another $100. In the end, I will have $1000.00 door panels, or close to it...
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop Last edited by OregonNed; 09-03-2019 at 08:44 PM. Reason: Bad grammar |
09-04-2019, 08:08 PM | #12 |
Valve cover gaskets and paint my valve covers while I had them off.
09-05-2019, 10:12 AM | #13 |
Replaced Fan switch. Old one would not go to 3 without some work. 2 would not work at all. With new switch, 2 still does not work, but 1 & 3 does. Still need to chase this down.
Changed Ignition module in HEI. Truck would start, idle, then die like someone turned off the key. Module seems to have solved it. Somehow managed to stretch throttle cable. Only pulls about 1/4 with foot to floor. Ordered replacement from Classic Parts.
Zane's 71 Build |
09-05-2019, 03:14 PM | #14 |
Newly made door panels to match my seat installed yesterday..
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
09-05-2019, 03:23 PM | #15 |
09-05-2019, 03:40 PM | #16 |
That looks killer, but I could not bring myself to spend $1K on a set of door panels. You probably have the only set like it in the world though.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
09-05-2019, 06:27 PM | #17 |
09-09-2019, 09:40 PM | #18 |
i like them very nice touch
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
09-16-2019, 02:12 AM | #19 |
09-16-2019, 03:21 AM | #20 |
Let me double check that. For some reason I am remembering 12" I do have to reach a bit to shift - works fine, but I am thinking about adding a longer handle. All in all it works well - it is a cable shifter model
09-16-2019, 03:31 PM | #21 |
I was way off - the one I have has an 8" stick.. I'd like a little longer, however now that I have this..
09-06-2019, 10:40 AM | #22 |
They can be had for around $200 online. Just make sure the houndstooth material matches the rest of your interior... I didn't do my due diligence on mine.. Thanks, too, they look great..
09-07-2019, 05:05 PM | #23 |
Fixed AC fan issue. High was on, sometimes. Low worked on high some times. Ended up being the AC relay. Low, Med, & high now work.
Zane's 71 Build |
09-07-2019, 07:53 PM | #24 |
At the body shop.
New pitman arm. Idler tomorrow.
Squarebody used up some of my time too. New cs130 alternator and belts on it.
" That didnt make it any newer " " Dont antique the equipment " |
09-07-2019, 09:54 PM | #25 |
Too darn hot to achieve much. Painted step supports and got a few fender braces stripped and painted. Got a few more long braces to do and then I’ll sort out two good sets for my truck.
Gonna be hot here the next few weeks so my rear suspension tear down is getting put on the slow roll. Maybe a bit of work in the evenings or weekend mornings. |
