Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 09-18-2019, 09:10 PM   #676
RockTonka
RockTonka's Avatar
Re: Our "What are we going to do?" 66 Suburban Build
Struggling a bit with the rear coil conversion kit from CPP...lower brackets are bending down. I pulled them, straightened them, and welded in some gussets...we'll see if this lasts or if they will need to be completely redone.
1958 Chevy 1 ton dually 4X4 dump/flat bed
My build thread
1966 "Not-So-Original" Chevy Custom Trim Suburban
My Time-Killing Project Truck
1966 GMC Extended cab 1 1/4 ton 4X4
My Son's build thread
RockTonka is offline   Reply With Quote
Old 09-18-2019, 09:48 PM   #677
RockTonka
RockTonka's Avatar
Little video from before we tore it apart again for bigger, better cooling...
My build thread
Old 10-04-2019, 03:30 AM   #678
RockTonka
RockTonka's Avatar
We reached out to CBR for some cooling options on both tranny and engine, here's what I've got mounted so far...should help with keeping tranny cooler.
My build thread
Old 10-05-2019, 02:56 AM   #679
RockTonka
RockTonka's Avatar
We knew we needed a lot more cooling capacity/air flow than the old 27x19 radiator pkg. had provided.
After a bit of back and forth with CBR, we ended up with a 3" thick, 38x19, double-pass radiator that incorporates a unique tube design which dramatically increases the effective tube surface area and a core design that reduces the spacing between tubes from 9mm to 6mm...which means more tubes.
All in all, we have a radiator that has over twice the surface area with 2 16" Spal fans pulling 5000 cfm's through it...I don't think overheating is going to be a problem.
Our challenge is making it fit...opening up the inner fenders and making a completely new radiator support is the plan.
My build thread
Old 10-06-2019, 01:23 PM   #680
piratexpress1369a
piratexpress1369a's Avatar
That looks like it will be a tight fit
My 63 GMC Panel Slow Build
http://67-72chevytrucks.com/vboard/s...=1#post5457281
63
piratexpress1369a is offline   Reply With Quote
Old 10-07-2019, 12:36 AM   #681
RockTonka
RockTonka's Avatar
Yea, kinda...but we started connecting the dots this weekend and it looks like we'll be alright.
My build thread
Old 10-09-2019, 06:16 PM   #682
likaroc13
Rollin' Old Skool
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 10-10-2019, 01:16 AM   #683
RockTonka
RockTonka's Avatar
I hope so!!
We've got the main framework of the rad support lined out and have started working on fitting in a battery box.
My build thread
Old 10-13-2019, 03:10 AM   #684
RockTonka
RockTonka's Avatar
We have the battery, rad overflow, and NOS auxiliary fuel system fit back in...pretty tight making everything work. We ended up removing a fair amount of inner fender, but it's all good.
My build thread
Old 10-13-2019, 03:19 AM   #685
RockTonka
RockTonka's Avatar
More pics...
My build thread
Old 10-13-2019, 11:32 AM   #686
piratexpress1369a
Wow that is a tight fit
63
Old 10-13-2019, 11:41 PM   #687
Captainfab
60-66 Nut
Nice work.......
Old 10-14-2019, 02:17 AM   #688
RockTonka
RockTonka's Avatar
Yep, but it's all in there!
Originally Posted by Captainfab View Post
Nice work.......
Thanks Capt., we appreciate that!
We've had the reworked tranny back from BTE for a couple weeks now.
BTE has impressed the s**t out of me with their support and willingness to help with some problems I had with a local builder.
If you remember, I sourced a few parts from BTE in spring...aluminum drum, input shaft, intermediate shaft, torque converter, mechanical diode, and a few other little things. I had a local builder assemble the tranny.
We cooked the tranny in the first 10 or so miles!
I reached out to BTE for direction... I knew there weren't any problems with their parts, but I didn't trust my builder any more.
BTE had me send the tranny to them in Mt. Pleasant, MS so they could inspect it. They quickly found a couple builder related problems.
BTE completely rebuilt the tranny, tightened up the TC a bit, and had it back to me in less than a week!
We reinstalled the tranny tonight...I don't expect any more problems with it.
My build thread
Old 10-14-2019, 02:33 PM   #689
likaroc13
Rollin' Old Skool
Nice work.......
Sounds like some great customer service from fellow Mississippian's at BTE as well!
Phillip
My Build threads:
Pics:
Previous Rides:
Old 10-21-2019, 01:24 AM   #690
RockTonka
RockTonka's Avatar
Yep, definitely!
My son didn't like the interior light housing and decided to do something about it.
He ground the perimeter down until the center released and replaced it with a piece of light cover from the shop.
He's replacing every bulb in the burb with LED's...should be a lot brighter!
My build thread
Old 10-21-2019, 01:31 AM   #691
RockTonka
RockTonka's Avatar
We also disassembled the front end, painted everything, and reassembled...going back together for good...again!
My build thread
Old 10-22-2019, 09:45 AM   #692
piratexpress1369a
Awesome..you going to test it on the dyno
63
Old 10-24-2019, 12:12 AM   #693
RockTonka
RockTonka's Avatar
No, not on a chassis dyno. It's been tuned on the engine dyno...that was important to get it dialed in. I can't justify the $$ for time on a chassis dyno.
My build thread
Old 10-24-2019, 01:28 AM   #694
RockTonka
RockTonka's Avatar
Continuing with the conversion to all LED...much brighter!
My build thread
Old 10-28-2019, 01:29 AM   #695
RockTonka
RockTonka's Avatar
We finished up most of the wiring (lights, new fans, tranny temp sensor, etc), topped off all the fluids, and put a few miles on it this afternoon.
We kept it conservative...only about 20 miles, but we did hammer on it a few times. Everything kept cool...maybe too cool. The burb ran great though, gonna try to just kick back and enjoy it for a bit...although there are a few more things I want to do to it.
My build thread
Old 10-28-2019, 01:47 AM   #696
RockTonka
RockTonka's Avatar
Short walk around vid from this evening...
My build thread
Old 10-28-2019, 09:53 AM   #697
cwcarpenter98
cwcarpenter98's Avatar
Dadgum, definitely my favorite suburban
Are y'all still running the Camaro rear sway bar?
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 10-28-2019, 11:03 PM   #698
RockTonka
RockTonka's Avatar
Thanks CW!
We pulled the rear sway bar off...the mounts on top of the axle were hitting the frame as we played around with spring rates on the coil overs.
We will run a bit with just the coil overs to see if they can compensate much for body roll...we have adjusted the rebound/compression a bit with positive results though.
My build thread
Old 10-29-2019, 12:46 AM   #699
cwcarpenter98
Originally Posted by RockTonka View Post
Thanks CW!
That would be a good reason to pull it off
I just went back to where y'all installed it (page 12 for anyone else wondering) to see how y'all had mounted it. I want to add a bar to my truck as well, so I've been gathering up ideas. Still have stock stuff under mine, so no worries about hitting anything yet.
Sounds like the coil overs are the way to go, but for now, stock is just fine
Christian Carpenter
Old 10-29-2019, 01:09 AM   #700
RockTonka
RockTonka's Avatar
If you were closer, I'd make you a deal on my old one...shipping probably isn't worth it.
My build thread
