12-07-2020, 12:18 PM | #676 |
Re: 1971 Stepside LS Build
I know with aftermarket ECMs, remote tuning is pretty common.
12-07-2020, 12:49 PM | #677 | |
Almost Satisfied
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
12-07-2020, 01:30 PM | #678 |
I would think a tuner could do the same for a factory ECM. I see people discussing remote tunes pretty regularly on some of the FB groups I'm in, and on some pretty wild combinations at that. But every tuner is different. And if you've found someone that's good at it, it may be worth taking it to them if that's how they prefer to operate.
12-07-2020, 05:45 PM | #679 |
I believe a tuner can e-mail you the file or even get into the ECM so yes it can be done remotely however I believe it requires the owner to have HPTuners or EFI Live (depending on what they are using.) That purchase can add up pretty quickly. I know he is looking local for the tune that makes it easier to get updates and not have your truck down.
Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
12-07-2020, 05:57 PM | #680 | |
Almost Satisfied
12-08-2020, 12:08 AM | #681 |
Good luck Shannon
12-08-2020, 12:05 PM | #682 |
what I like to do to try and get all the air out, is unhook the 'steam fitting' cross over at the front under intake. Put a towel under the metal line where you unhooked the rubber hose here....
you want to keep filling the radiator slowly until you start to push water out that metal cross over line. That way you know the block and heads are full and air is pushed out.
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear |
12-11-2020, 08:53 PM | #683 |
Looks great, hope to see it in April!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
12-14-2020, 10:00 AM | #684 |
Roto Reuter thats the name...
I hope this works out for you. I explored the notion of putting my K10 on the dyno with a local company. They also have several options for tuning, including HP Tuners, which was how mine was set up. I used Pacific Fabrication / Tilden Motorsports for mine. By the time he added up everything I was pushing $600 - $700. He also said that he needed to add an extra bung to my exhaust system for monitoring. I quickly said no to that. I have a nice SS exhaust system that I don't need hacked up. Also, my tune seems to be OK. It's just that I wanted to see about tweaking the shift points and looking at my fan temperature settings. Good luck with it.
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
12-14-2020, 10:29 AM | #685 |
Almost Satisfied
I have the dyno run scheduled for Friday if the weather cooperates. The shop I'm going to has a love them or hate them reputation. I've seen a little of both in the process, but I think they will get it pretty close. Once it is fully going and warm again I can tweak it. I've spent the weekend going over everything I can think of to make sure we have a good run Friday.
I also worked on a new set of kick panel speaker enclosures. I just didn't like the first set that I built. I laid the speaker flat this time so the enclosures would be much thinner overall. I made sure I had room for the dimmer switch and I angled the tweeters to hit about the middle of the back glass. I am really happy with how they fit and look. A little more sanding and I can drop them off to be covered.
12-14-2020, 10:48 AM | #686 |
Sweet. You can always move the dimmer switch a little if you need to. I decided to put mine in my Ididit steering column just for this reason. Looking great though. Nice work.
12-14-2020, 04:08 PM | #687 |
Almost Satisfied
Some old school fun here. Found this picture. I'm guessing around 1989 I was putting a new stereo and speakers in the truck. I since repaired the cut dash.
12-14-2020, 04:11 PM | #688 |
Almost Satisfied
While digging I found these two square bodies that were my dads. I would love to build a 79 GMC like that green one. It was my favorite truck he had.
12-14-2020, 05:37 PM | #689 |
Nice square bodies!
71 C10 72 K20 72 K10 Super Kirk |
12-14-2020, 08:51 PM | #690 |
Those speaker enclosures are awesome man! Good work!
12-15-2020, 10:37 AM | #691 |
Yep, those speaker enclosures are top notch. My grandpa had an 84 K20 with the 6.2 diesel (about the slowest truck I've ever driven) and it was parked in the weeds for a couple years before a neighbor bought it for farm use and had it repainted and then sold it to another guy who swapped in a 350 and I think it's changed hands again. Should have kept it...
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
12-15-2020, 02:19 PM | #692 | |
and then i need to find the tweeter ones. lol Thanks
John 3:16 - Saved me... God Bless |
12-15-2020, 03:30 PM | #693 | |
Almost Satisfied
12-15-2020, 03:35 PM | #694 |
Almost Satisfied
I sanded them last night. Won't take much filler at all to smooth them out.
12-16-2020, 03:26 PM | #695 |
12-16-2020, 04:06 PM | #696 | |
Almost Satisfied
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." Last edited by 1971Stepside; 12-16-2020 at 04:06 PM. Reason: typo |
12-17-2020, 05:27 PM | #697 |
Almost Satisfied
Dyno run cancelled for tomorrow....ugh. It is amazing how hard it is to spend your hard earned dollars sometimes.
12-17-2020, 05:40 PM | #698 |
sorry to hear about that setback.
That's been my experience as well, especially with "tuners" and "high end shops who do racecars/restorations". Maybe it is just surprising how many people who get into the automotive aftermarket just don't act like professionals. Why is it "okay" for shops to cancel/turn down work/treat you like crap/do shoddy work when they want, but not okay in other areas of our lives? I wish there was something that could change, these guys (and gals) can't be having fun. Maybe it's all economics, but there is more money than ever in cars... Sorry to hijack. |
12-18-2020, 10:36 AM | #699 | |
Dave
12-18-2020, 11:57 AM | #700 | |
Almost Satisfied
