07-26-2018, 06:55 PM | #7026 |
Re: What did you do to your truck today? Chapter II
Packed the rotor bearings. Fixed the tailgate rattle a few days ago. Cost a wapping 4$ have enough to do probably 100 gates. I used white grease on the trunion works great
07-26-2018, 06:56 PM | #7027 | |
07-26-2018, 07:06 PM | #7028 | |
Active Member
So you just stretched a bike tire slice to fit around? It still fits in the hole? And it doesn't scrunch up when you move it?
David Larsen 1970 Chevrolet C-10 |
07-26-2018, 07:11 PM | #7029 |
07-26-2018, 07:21 PM | #7030 |
That's cool. At least I got some good product photos for the rotors & tie rod adjusters. Thanks for the info.
1969 GMC 2500. 250 I6, 4-speed w/ granny low |
07-26-2018, 08:14 PM | #7031 |
Got the power steering box and linkage installed.
07-27-2018, 10:59 AM | #7032 |
Getting a handle on my latest project
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
07-27-2018, 12:58 PM | #7033 |
‘70 stepside, wet sanding clear and getting ready to paint cab. I hope ... it’s hot in Las Vegas. But super fun after 8 months of prep.
Posted via Mobile Device |
07-27-2018, 01:45 PM | #7034 |
Ordered these, pretty excited!
07-27-2018, 04:55 PM | #7035 |
How did I get this OLD!
Whitened the smile on the "Redheaded Stepchild"
http://67-72chevytrucks.com/vboard/a...1&d=1532724792
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023 Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt. |
07-27-2018, 06:10 PM | #7036 |
[QUOTE=Canuckvetter;8310129]Whitened the smile on the "Redheaded Stepc
http://67-72chevytrucks.com/vboard/a...1&d=1532724792[/QUOTE They look much more gooder
Do it, Do it right, Do it right the first time |
07-27-2018, 09:26 PM | #7037 | |
Steven '67 SWB, 250ci, 3OTT.......this is my first build...... I wonder if my grand kids will say, "I would give anything to have my grand dads 2005 Chevrolet Z71" |
07-27-2018, 09:29 PM | #7038 |
finally got my horn.... horning
next up, inspection!!!!!!
07-27-2018, 10:19 PM | #7039 |
What I did next to my truck today
@ 102* F in the shade it was too hot to work on it so I worked on old Motocycles next to it in the shade instead.....
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH |
07-27-2018, 10:40 PM | #7040 |
laying low
Nate I hope you had a big round fan blowing on you while in that heat. I am proud to have a home shop, as hot as it is, but I do remember many a years working up under the big trees out back. We had a bunch of big old pecan trees back then and seems like there was usually a bit of a breeze there.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
07-28-2018, 12:49 AM | #7041 |
A/C window shaker in the shop and it stays 21.5C or around 70F all year long winter or summer 70F.
07-28-2018, 01:15 PM | #7042 |
'67 C-10 SWB '18 Sierra Denali '18 Volvo XC90 |
07-28-2018, 04:22 PM | #7043 |
partly legal now!! still need tags we are inspected though.....
07-28-2018, 05:46 PM | #7044 |
Soon the hard work pays off
07-28-2018, 07:00 PM | #7045 |
STILL Too Hot !
No ;
I don't have a fan out side, I should get one but then I'd have to run a cord out side, etc, etc. ~ the last time I forgot the put the cord away one of the dogs ate it, I'm lucky it wasn't electrocuted . The heat is miserable so this morning I and an old Friend rode bikes up into the mountains for breakfast, it was hot up there too . I'm trying to add a photo but it's been downloading for over 15 minutes now.....
07-28-2018, 07:14 PM | #7046 |
07-28-2018, 07:26 PM | #7047 |
Decided not to spend money on a new gate🤣
07-28-2018, 07:27 PM | #7048 |
Replace the flex fan and found my crank pulley is out of alignment to the water pump ,alt and ps pump. Ps Pump I shimed it out but the alt there is no real way to shim it. Once I get the alt to lime up o the crank I can shim the water pump pulley out.
07-28-2018, 07:46 PM | #7049 |
Built up my dolly to get the cab higher off the floor for my painter.
07-28-2018, 08:46 PM | #7050 |
