#701 |
Re: Halfbreed - GMC Z71 + IH Extd Cab
it looks great, but i do have one more question for ya, were do you get a windshild for that truck?
Truck: 1972 International Harvester 1210 Engine: Caterpiller 3116 220 HP 630 tq Transmission: Eaton Fuller rt 6610 Axles: Merritor I beam front axle |
#702 |
Try doing a search of the forums on either binderplanet.com or justih.org. I seem to recall that there might still be a supplier or two that still stock these windshields. There are also people on those forums that are buying or selling used windshields.
#703 |
hmm awsome, i need one for my 72, it has a huge crack down the middle of it
#704 | |
"Oh well, it's a driver."
A lot of custom trucks don't even run wipers; yours are re-engineered for maximum effectiveness. Just another reason to love this build!
- JB - '93 C1500 SHORT/FLEET SILVERADO, 350/4L60E ![]() Quote:
#705 |
Getting ready to start my gauge modifications. Santa brought me two of the three Autometer gauges I need. I want a 0-6k tach so I need to buy a marine tach.
To prep for the mod I took out the GM factory gauge cluster and tried to pin out all the wires. I did OK but still have several circuits that are not as EZ to figure out because they all go through the little circuit board instead of direct to the device. Here are some shots of what a factory cluster looks like if you crack it open. The face of the cluster is held onto the back via the 4-gang posts that are on the back of each of the gauges. So gentle prying is all it takes and boing out it pops. |
#706 |
As usual I will break my task into smaller tasks. I will start by migrating the idiot lights for the SES, ABS, Seatbelt, Daytime Run Lights, Batt and Ebrake up into this opening in my overhead console. This will involve surgery to the GM gauge cluster to get the graphics and the light housings off. I also need to pull wire up the back wall of my cab and create connector assys at both ends for these new circuits.
High beam and turn signals will stay on the dash and I will use the IH style bezels for these. The IH dash had a white idiot light for ebrake on and I am going to convert that to blue high beam somehow. |
#707 |
I could use some help with the Gear Indicator stuff. Does anyone know if the PRND321 lights in the gauge cluster are driven off separate wires for each gear or does the little circuit board have logic that does this off of a signal from a single wire?
And is the gear position signal sent to these lights from the tranny or from the shift lever on the steering column? Many thanks for your help! |
#708 |
GEARHEAD
You don't ever seem to take the easy way through a project do you? Good luck getting this all figured out.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff |
#709 | |
#710 |
![]() ![]() Join Date: Jul 2002
Glad you found it. I was still having my eyeballs roll around at the whole mess.
#711 |
Tear down of the GM overhead panel that will be "re-purposed" into my idiot light panel.
#712 |
Pulling wire. I managed to get my fish wire trapped for 1 day inside the corner of the IH cab. But I got lucky and it wiggled free just as I was about to go for the cutoff wheel and open up some sheet metal.
#713 |
The electrical "war room".
#714 |
The GM instument cluster has "donated" some of it's graphics and now the light chambers are exposed. Notice that virtually none of them are in a row or the same shape or on the same spacing......
.... which led me to the wrecking yard where 3 Hondas and 4 Jettas (what are the odds that there would be 4 Jettas in the yard at one time) gave up their light panel technology for me. The choice of these makes was pretty much down to a) what had wires to their bulbs instead of flex circuits, b) what had already had somebody rip open the dash so I didn't have to? The second pic shows the bulb sockets as they were being "rendered" (think butcher shop) on the way to the size I needed for my panel. |
#715 |
I eventually used the Honda stuff over the Jetta and a little while later after some cutting, flap wheel, JB Weld, more flap etc I had my very own DIY idiot light display back panel housing sub-assy thingy.
#716 |
Chevy Enthusiast
Man I love your work, you are very creative!
Tony 1985 GMC K2500 restoration Project: Rust, White & Blue 1989 Chevy R3500 CC Cummins & 4X4 swap some day... 1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress) |
#717 |
This is looking good!
Success is not final, failure is not fatal: it is the courage to continue that counts. Winston Churchill DD 2000 Chevy Suburban 4x4/5.3 Vortec/4L60E/4:10s, 18" Escalade rims, Electric fans Project Dooley One-Ton 4x4 on 38.5s Corn-binder build |
#718 |
I agree...VERY creative !!!
Eric 1967 C10 Small Window - LWB http://67-72chevytrucks.com/vboard/s...d.php?t=657509 2004 Silverado 2500HD - Turbo Diesel 603 rwhp / 1090 rwtq 2016 Camaro SS - Satin Pearl Nero wrap My 2010 Camaro SS Magazine feature (SOLD) http://www.superchevy.com/features/g...of-perfection/ |
#719 |
Very neat!
#720 |
![]() Join Date: Nov 2004
Oh no... I've gone cross eyed...
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
#721 |
I think I have to move to a warmer climate so I don't have to take 4 0r 5 month's off
94 k2500 EXCab Long Bed 350ci New Toy 95 K2500 Suburban New PlowTruck 454ci Support our Troops @ http://anyairman.com http://www.woundedwarriorproject.org/ |
#722 |
As the warning light relo project swung into high gear the war room got pretty messy.
Next is a shot of the newly wired console ready for it's first trip back up into the roof of the cab. Then a shot with the key on and 5 out of 6 of the lights doing their thing. Finally a shot after a few seconds of running - now all the lights but the left one are off. The left one is (I mean will be) the green DRL light which stays on. So far so good. And so far it's OK that my crude looking light housing is working. But the final task is to come up with a clean, factory looking front cover. Wish me luck! |
#723 |
I'll be driving the first couple of days with the fire extinguisher riding shotgun. Nothing like an electrical fire to ruin a perfectly good project truck.
#724 |
"And remember, only YOU can prevent project fires!" -- Smoky the Bear
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
#725 | |
"I feel the need for speed!"... as soon as I am done with my nap. |
