Old 09-01-2010, 09:55 PM   #51
sick454
sick454's Avatar
Re: !!!!5.3 Vortec Swap Started!!!!
I guess no one knows anything about oxygen sensors on these LS Swaps?
sick454 is offline   Reply With Quote
Old 09-01-2010, 10:46 PM   #52
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
only one's in my build will be for the a/f gauge(s).
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 09-02-2010, 03:04 AM   #53
matthew20061
69' Chevy Stepside
matthew20061's Avatar
Well I can offer some advise I did this swap in my 69' and when I wired it up I plugged the drivers side o2 sensor plugin onto the passenger side o2 sensor and didn't even know I swapped them around! Made it run like crap, miss firing under load and a flashing check engine light. You probably don't have this particular problem but just check your wiring. I'm sure your bosch o2's are fine. Scan the computer for codes and let us know what comes up.
-Matthew
-69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead"
- Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread
-1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed
-1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting
-2003' Chevy Silverado SS AWD 6.0L! - Daily Driver
matthew20061 is offline   Reply With Quote
Old 09-02-2010, 09:35 AM   #54
Shon
Unplug the O2s, how does it run? this puts it into Open Loop.
Also, I would run your ALDL into the cab of truck rather than under the hood, will make difficult logging if you ever decide to have it tuned properly.
Also, why did you guess at the wiring of the O2s, they are quick connects, was your harness cut up? and make sure you have the FRONT O2s and did not wire them into the REAR O2s.....
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 09-02-2010, 10:12 AM   #55
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Has anyone installed these 02 sensors? How did you connect them? the engine is a 2007 classic silverado 5.3 with the 4L60E tranny.
I used Bosch direct fit sensors on mine (Bosch #15150) that plug right in, they should be the same for yours. I'm wondering like Shon, was your harness chopped? Is that why you used the universal sensors? I would always go for the direct fits sensors, Bosch or ACDelco.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 09-02-2010, 11:06 AM   #56
68GMCCustom
aren't the universal one's usually only 0v to 1V?
Kurt -
Old 09-05-2010, 11:06 PM   #57
sick454
sick454's Avatar
Just drove 480 Miles in my new 5.3 swap and it drove great. I have realized now that my suspension is not up to par with the horsepower and torque the new engine puts out. That's the next project. All this and I got 20 mpg!!!! It did drop to around 17 mpg but I was fighting a 25 mph head wind and had my 750 pound Harley Street Glide in the bed of the truck.
Old 09-12-2010, 12:44 AM   #58
sick454
sick454's Avatar
I guess because they are NOT quick connects. they are blank/cut wires out of the box with crappy diagrams. however, I did figure out that two if the wires on the drives side were swapped. It s now correced and running like a champ. Thanks for all the help
Old 09-12-2010, 12:49 AM   #59
sick454
sick454's Avatar
I only put it under the hood so I could drive it to Texas. I'm being transfered and had to get it together in a short minute. to drive it there. I als have a 1964 impala, 1962 Bel Air, 2 harleys, and a f-150. All This and moving. The military will only pay to move one car.
The rear O2 sensor wiring was removed from the harness completely, therefore they were not connected to the rear ones. the drives side was miss wired by myself. It has been fixed. Thanks for the help.
Old 09-12-2010, 12:51 AM   #60
sick454
sick454's Avatar
I would have went for direct fits, however, they are TWICE the cost as the univeral Bosch ones. I can't see paying that much just to have a connector on the other end. My harness was fine. It was just the cost factor. Thank you for the advice
Old 09-21-2010, 09:25 PM   #61
oldmanlance
oldmanlance's Avatar
im going to swap my old 402 for a 5.3 ,just wondering about what gaer ratio should u run ?
oldmanlance is offline   Reply With Quote
Old 09-28-2010, 11:40 PM   #62
sick454
sick454's Avatar
I'm running 3.72's in my 12 bolt rearend. and it runs fine. fairly stout in the low end and great highway cruising. Definatly not drag raceing ratio by any means. but great for everyday drivers.
Old 03-21-2012, 01:38 AM   #63
laid67
laid67's Avatar
Looks good man, im doing the same swap into mine. you ever swap over to a set of headers?
laid67 is offline   Reply With Quote
Old 03-02-2013, 04:20 PM   #64
slamed67
slamed67's Avatar
doug thorley makes a nice set of 5.3 swap headers.. mine just came in the mail today!
slamed67 is offline   Reply With Quote
