Old 04-29-2012, 11:30 PM   #51
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Exclamation Re: 1960-1966 Chevy/GMC Pickup Truck Specs & Engine/Trans/Axle ID's
>>>> "DOWNLOAD THIS! <<<<
>>>> "SAVE IT AND PRINT IT OUT!" <<<<
>>>> "THIS IS VERY VALUABLE! INFO" <<<<
Done some digging and I found some goodies for all the 1960-1966 members!
1Bad62Pro/Street - Certified 60-66 Truck nut.....
This may need to be a sticky again.
1960 Chevrolet Truck
http://www.gmheritagecenter.com/gm-h...olet-Truck.pdf
1961 Chevrolet Truck
1962 Chevrolet Truck
1963 Chevrolet Truck
1964 Chevrolet Truck
1965 Chevrolet Truck
1966 Chevrolet Truck
General Motors Corp.
Chevrolet Trucks (All Models Listed Below)
http://www.gmheritagecenter.com/gm-h...tion-kits.html
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
Last edited by 1Bad62Pro/Street; 12-04-2012 at 09:18 PM. Reason: Reason for Editing:
1Bad62Pro/Street is offline   Reply With Quote
Old 04-30-2012, 12:40 PM   #52
61K10
61K10's Avatar
my 61 k10 swb/fs has the 0 in vin witch is oakland calif. the plant was built in 1916 and was known as Detroit west. closed in 1963 and moved to freemont. i had a 56 nomad that was built in oakland also. here is my project--
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 05-02-2012, 11:10 AM   #53
1Bad62Pro/Street
Arrow Re: 1960-1966 Chevy/GMC Pickup Truck Specs & Engine/Trans/Axle ID's
If you have troubles with the links try:
Click on Chevrolet Trucks (All Models Not Listed Below) [ SHOW ]
Chevrolet Trucks (All Models Not Listed Below) Hide
1930 Chevrolet Truck 1931 Chevrolet Truck 1932 Chevrolet Truck
1933 Chevrolet Truck 1934 Chevrolet Truck 1935 Chevrolet Truck
1936 Chevrolet Truck 1937 Chevrolet Truck 1938 Chevrolet Truck
1939 Chevrolet Truck 1940 Chevrolet Truck 1941 Chevrolet Truck
1942 Chevrolet Truck 1946 Chevrolet Truck 1947 Chevrolet Truck
1948 Chevrolet Truck 1949 Chevrolet Truck 1950 Chevrolet Truck
1951 Chevrolet Truck 1952 Chevrolet Truck 1953 Chevrolet Truck
1954 Chevrolet Truck 1955 Chevrolet Truck 1st Series 1955 Chevrolet Truck 2nd Series
1956 Chevrolet Truck 1957 Chevrolet Truck 1958 Chevrolet Truck
1959 Chevrolet Truck 1960 Chevrolet Truck 1961 Chevrolet Truck
1962 Chevrolet Truck 1963 Chevrolet Truck 1964 Chevrolet Truck
1965 Chevrolet Truck 1966 Chevrolet Truck 1967 Chevrolet Truck
1968 Chevrolet Truck 1969 Chevrolet Truck 1970 Chevrolet Truck
1971 Chevrolet Truck 1972 Chevrolet Truck 1973 Chevrolet Truck
1974 Chevrolet Truck 1975 Chevrolet Truck 1976 Chevrolet Truck
1977 Chevrolet Truck 1978 Chevrolet Truck 1979 Chevrolet Truck
1980 Chevrolet Truck 1981 Chevrolet Truck 1982 Chevrolet Truck
1983 Chevrolet Truck 1984 Chevrolet Truck 1985 Chevrolet Truck
1986 Chevrolet Truck 1987 Chevrolet Truck 1988 Chevrolet Truck
1989 Chevrolet Truck 1990 Chevrolet Truck 1991 Chevrolet Truck
1992 Chevrolet Truck 1993 Chevrolet Truck 1994 Chevrolet Truck
1995 Chevrolet Truck 1996 Chevrolet Truck 1997 Chevrolet Truck
1998 Chevrolet Truck 1999 Chevrolet Truck 2000 Chevrolet Truck and Silverado
Old 07-01-2012, 08:03 PM   #54
1Bad62Pro/Street
GMC Transmission Data
http://www.6066gmcguy.org/SM420.htm
More GMC Stuff:
1960 - 1966 Canadian Chevrolet & GMC VIN
http://www.oeltd.net/doc/6066gmc/vins/gmc-canada.htm
Old 11-25-2013, 01:34 AM   #55
A.T. RockDriller
A.T. RockDriller's Avatar
Yep! My truck had a 235 inline 6 cylinder in it, but was out of a 65 or 66.
This will help you!
Small Block Chevy Engine Block Identification
http://67-72chevytrucks.com/vboard/s....php?p=3469041
Small Block Chevy Cylinder Head Identification
http://67-72chevytrucks.com/vboard/s....php?p=3416964
Chevy Six Cylinder Casting Numbers
http://67-72chevytrucks.com/vboard/s...d.php?t=356268
Just as an example here is my truck info:
I couldn't quite make out your fine print #'s on HP @ 8500 rpm's..
Les Hunter
'59 3803 someday to be 3853
'63 GMC K1000...351E, TH400 Daily
'66 GMC 4000...351C, 5&2
A.T. RockDriller is offline   Reply With Quote
Old 11-25-2013, 12:20 PM   #56
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
I agree! Should be a sticky.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 11-29-2013, 05:49 PM   #57
1Bad62Pro/Street
Which ones Bud?
Old 01-02-2014, 11:48 PM   #58
Scooterbilt
Scooterbilt's Avatar
Does anyone know where I can find specs on how wide a front axle is from a 60's C50 truck? I am in the middle of a project and need a narrower front axle for my 66 C60.
http://67-72chevytrucks.com/vboard/s...d.php?t=556899
Scooterbilt is offline   Reply With Quote
Old 09-11-2014, 02:30 PM   #59
1Bad62Pro/Street
Hey guys,
If anyone of you guys have any valuable information please add to this thread!
Thanks,
1Bad62Pro/Street
Old 11-27-2014, 09:53 PM   #60
YatYas
YatYas's Avatar
I recently bought a 66 C10. The PO advised that the rear axle came out of a 61 and had 308 gears.
Thanks to this thread I located my stamped numbers on the axle. They are, "HB 01 20".
So according to the info listed previously on this thread the PO is incorrect? Did the axle really come out of a 65 and it's 307 geared?
YatYas is offline   Reply With Quote
Old 11-27-2014, 11:49 PM   #61
Captainfab
60-66 Nut
Glad you were able to find out for sure just what differential your truck has by using info in this thread
Old 03-30-2015, 08:31 PM   #62
spikemike01
I have a 1964 Chrvrolet C20 pickup that I have been cleaning up. I recently found this information stamped on the engine block. I believe it is saying that my engine is the 292 4.8L straight 6 but am not sure. After looking at my LMC catalog it states that the engine Id code should be PG but I don't see that here. Can someone help me decider what all of this means?
Thank you,
Michael
spikemike01 is offline   Reply With Quote
Old 03-31-2015, 09:02 AM   #63
1963c-10
1963c-10's Avatar
Originally Posted by spikemike01 View Post
Attachment 1384803
Thank you,
Michael
I believe its a Mexican cast or possibly remanufactured 292 (forum search on the casting # popped that up), probably made in the 80's. Can you find a date code?
Link: http://67-72chevytrucks.com/vboard/s...d.php?t=553451
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 03-31-2015, 10:41 AM   #64
spikemike01
Thank you for helping me out with this. I am definitely willing to look for a date code. Do you know if it would be close to where I found this information? Also would it look like a date or would it just be a series of letters an numbers?
Old 10-05-2016, 02:54 AM   #65
snoopy59
hello I seek the data for the setting up of a front; parallelism, hunting and pinching for 1963 c10
thank you
snoopy59 is offline   Reply With Quote
Old 10-05-2016, 11:25 PM   #66
Captainfab
60-66 Nut
Hello
I'm thinking that what you seek is the specs for a front suspension alignment? If so I think you might find what you are seeking here.
http://www.67-72chevytrucks.com/vboa...aysprune=&f=25
thank you
