Old 04-12-2009, 10:16 AM   #51
daverod
SSN 706
daverod's Avatar
Re: Daverods project 66
Originally Posted by Captainfab View Post
Looks good
Did you put that Evercoat high build primer direct on the bare metal, or did you spray it with an epoxy primer first?
I put it right on bare metal?
daverod is offline   Reply With Quote
Old 04-12-2009, 10:21 AM   #52
joe231
joe231's Avatar
Looks so nice
I like bare metal, but love the look of some nice primer
I have read you need to seal the metal first before priming, but then I have also read you can apply it to bare metal...so maybe it don't matter which way you do it.
the internet is great but you get so many different contradicting opinions....kinda confusing at times
CHEVY ONLY
Old 04-12-2009, 10:29 AM   #53
daverod
SSN 706
daverod's Avatar
My first words when I walked in the paint store were " I need a primer that I can put on bare metal". She told me that was the stuff?
Old 04-12-2009, 10:53 AM   #54
Strodder
Daring to be Different
Strodder's Avatar
I think if your going paint it right away you can use a metal primer. If you have body work to do you then have to seal it first so it won't rust. Again I said "I think". What do you guys think?
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 04-12-2009, 11:09 AM   #55
daverod
SSN 706
daverod's Avatar
My plan (do I have a plan) was to prime, do my body work (Rage body filler) then Slick sand, then paint? Mayde I have to seal the slick sand. I'm not sure. I was looking on evercoat web site the orginal featherfill says you can put it on bare metal. This stuff says g2 on in. I think that just means it can be used over a eching primer? I'm confused.
Old 04-12-2009, 11:28 PM   #56
daverod
SSN 706
daverod's Avatar
Worked on my doors today. Took the windows out, sanded the paint off, began to wonder if you can ever stop the rust? Used about 3 can off rust stop, hay it can't hurt. Sprayed it inside the doors, around and inside the hood, all the places I could'nt sand or sandblast. I'm going to see if I can get these doors to work. I don't really want to spend the money to buy new ones. Should be getting my engine back from the machine shop this week . It's a 350 bored .10 over. I have a turbo 350 and a 400. I think I'll use the 350. Did'nt really need to do the engine now but it just somthing else I can check off the list. Still looking for a steering column.
Old 04-12-2009, 11:29 PM   #57
Strodder
Strodder's Avatar
Man I'm glad I live in California with all the rust I've seen here. The etching/sealer primer that I use can have bondo over it.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 04-12-2009, 11:35 PM   #58
daverod
SSN 706
daverod's Avatar
Yea I'm pretty sure my next truck is going to come from California or Arizona.
Old 04-13-2009, 12:04 AM   #59
Captainfab
60-66 Nut
If Evercoat says it is a direct to metal primer, and you followed the prep recommendations, you should be fine. Whenever I'm working with blasted metal I first spray it with epoxy primer, then do the necessary filler work, and then start with the sandable primer. This is just what I've done for years.....learned it from a few local restoration and custom car builders.
Old 04-17-2009, 09:09 AM   #60
daverod
SSN 706
daverod's Avatar
Worked on my body work alittle last night. Seemed like all I do is put filler on then sand it all off. Ordered some new door bottoms from lmc. Going to pick up my engine from the machine shop today.
Old 04-17-2009, 10:00 AM   #61
Strodder
Strodder's Avatar
Ain't that a *****, all that blocking & sanding. Looken good. Keep it up Dave.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 04-17-2009, 10:10 PM   #62
daverod
SSN 706
daverod's Avatar
Won a tilt steering column on ebay I'm pumped. Came out of 79 chevy van. Now I can finish mounting my dash. Picked up my engine, cleaned out a spot in my garage to work on it. Now all I have to do is find the time to put it together. It's my first one so it might take awhile. Feel free to tell me what to do first.
Old 04-17-2009, 10:17 PM   #63
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
I hope your done sand blasting. Engines and sand don't mix well. I've rebuilt several chevy engines. I used "How to rebuild a small block chevy" if you follow it everything should work out fine. Cleanliness and order and recheck your work. It's simple to do just tedious.
Alan's Classic is offline   Reply With Quote
Old 04-17-2009, 10:22 PM   #64
daverod
SSN 706
daverod's Avatar
There will be no more sand blasting inside my garage ever! Took about a week to clean it out. I'll have to get me one of those how to books. Thanks Allen sorry about Grandma.
Old 04-17-2009, 10:34 PM   #65
daverod
SSN 706
daverod's Avatar
Just bought a how to book on Amazon used $9. Money well spent I'm sure. I've rebuild a few snowmachine engines so I have a little idea of what to do. Probably just enough knowledge to get in trouble.
Old 04-17-2009, 11:36 PM   #66
protrash64
Resistance is Futile
protrash64's Avatar
There are many knowledgeable people over in the engine section of this website. Ive read quite a bit over there, so if you have an issue you can post it up over there.
Looking good on the progress......I hate sanding.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 04-18-2009, 08:01 AM   #67
LILRED66
LILRED66's Avatar
It looks like you are making good, steady progress. Let us know how the engine assembly goes and keep up the good work.
LILRED66 is offline   Reply With Quote
Old 04-18-2009, 08:55 AM   #68
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Make sure the machine shop put that little galley plug back in place under the oil pump driveshaft area (ish...hard to describe. You should see it when looking in that area. Little feller, about 1/2 an inch if I remember right.). They remove them to vat the block.
It's happened a lot over the years. Forget that little plug and it won't build oil pressure. Big pain.
Old 04-18-2009, 09:09 AM   #69
daverod
SSN 706
daverod's Avatar
Thanks Tx I'll go look to make sure. No oil pressure would suuuckk.
Old 04-18-2009, 09:29 AM   #70
daverod
SSN 706
daverod's Avatar
I think it this is what your talking about Tx?
Old 04-18-2009, 09:33 AM   #71
Tx Firefighter
Look straight down into the engine bowels in this area.
It should likely be a shiny new little bitty freeze plug.
Old 04-18-2009, 09:36 AM   #72
Tx Firefighter
And that rusty thing sticking out of the block near the oil pan rail in your picture. That is some goofy unknown something or another. Unscrew it and replace it with a 1/4 npt plug. That's the lower drain for the block water galley.
Old 04-18-2009, 09:46 AM   #73
daverod
SSN 706
daverod's Avatar
I see nothing. I don't think they put it back. Maybe it's in the gasket kit?
Old 04-18-2009, 11:22 AM   #74
Tx Firefighter
It's been afew years, so I'm dealing mith my memory here...
I do believe you might have to remove the rear main cap to see the area better. It's up in here somehwere. I promise, I'm not getting Alzheimers yet. You will know it immediately when you see it. I think it's somewhere next to where the oil pump rod goes into the block.
Old 04-18-2009, 04:04 PM   #75
daverod
SSN 706
daverod's Avatar
hay hay hay. And to think I was beginning to doubt you. That's it right? One less thing to worry about. Thanks Kevin
