Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 12-12-2009, 09:23 PM   #51
turp mcspray
turp mcspray's Avatar
Re: New member from the Black Hills
Sorry for the double post. It's been so long since I've posted pics, I'm having a hard time remembering how to do it!
I'm also adding a traction bar to try and control axle wrap a bit.
I notched the frame rails a bit for the headers. I also decided to use the 73 up shifter linkage, as it will be easier to install, since moving the engine forward put the pivot point right where the cast shackle bracket is rivited to the frame rail.
I still have to fab something to attach the traction bar to, coming from the frame.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 12-12-2009, 09:33 PM   #52
turp mcspray
Smile Re: New member from the Black Hills
And here are a couple more.
Once I get everything mocked up,modified etc., my plan is to blow it back apart so I can sandblast and paint. I better get out the heat lamp and miracle grow so my money plants start producing. I'll need to buy new brake and fuel lines,cross over steering parts etc, not to mention getting started on my engine. Grow money plants grow! LOL!
Turp Mcspray
Old 12-12-2009, 10:35 PM   #53
swyfor5
swyfor5's Avatar
Nice! Been watering my plants, but they just aren't growing! Guess we just have to keep trying!
swyfor5 is offline   Reply With Quote
Old 12-12-2009, 11:31 PM   #54
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Looks like you had to take a bite out of the frame to clear the headers.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 12-13-2009, 06:38 PM   #55
70gmcjimmy
GMCDAC
70gmcjimmy's Avatar
Hey Scott, looking good! you're sure gettin' a lot done on MY Blazer---- it says so right on those headers! LOL. Gimme a call when you git 'er done fer me!
Later---DAC
1970 GMC K5 Jimmy Custom 4X4 Mom's driver from 1971 to 2001!! Under rebuild!
1972 GMC C2500 Pickup owned since 1979 Needs a rest and refurbish!
1955 GMC 100 2nd design driven almost daily!
Rest In Peace Mom. "Dolly" 7/15/23 - 5/18/09
GMC driver for 30 years!
70gmcjimmy is offline   Reply With Quote
Old 12-15-2009, 12:22 PM   #56
turp mcspray
I met a guy last summer with a 72 4wd long bed. He put a 502 in his truck with manifolds. I think he moved his engine ahead a little farther than I moved mine. He had to trim his passenger side frame rail for the manifold as well. I had to trim the left side on mine to, but only for one tube. I know a lot of guys don't want anything to do with such mods, but it didn't bother me one bit. I'm in the "headers are a must have camp" LOL!
Turp Mcspray
Old 12-15-2009, 01:08 PM   #57
jaros44sr
jaros44sr's Avatar
Got a question for ya...since you remove metal from the frame, does it have to have a stiffener plate added? Not saying you're wrong, just curious. I watched a guy bend his frame at that location, but he really hammered it to get over a log
Looks like you do really quality work, hurry up and work on it so I have something to read
Nice mod on the shift linkage!
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 12-15-2009, 03:08 PM   #58
turp mcspray
Personally, I don't think I removed enough to cause a problem. I'm not going to be jumping it or anything, HAHA! so I'm not too concerned
Turp Mcspray
Old 12-15-2009, 06:13 PM   #59
vtblazer
vtblazer's Avatar
If you plans include wheeling much, maybe a cable shifter would work better for you?
Lokar makes a nice kit that replaces all the factory hard linkages and bolts directly to the stock steering column.
vtblazer is offline   Reply With Quote
Old 12-15-2009, 10:06 PM   #60
turp mcspray
I'll still take it out in the woods, but I will probably shy away from the rocks that I used to crawl. I plan to paint this Blazer and keep it forever. (yeah I know...famous last words) I usually don't sell anything. The rocks were fun for awhile. But with a fullsize rig, you just about have to either replace the body every couple of years, or slowly evolve to a buggy type of rig. Neither of which I want to do. With this build I kind of of have the same mindset as you VT. A somewhat capable, do it all kind of rig, that will be driveable every day. The reason for using the newer shift linkage was simply the simplicity of it. I had it laying here from a truck I parted out this past summer. It was one less thing I had to fab or buy. Sometimes we all forget to "keep it simple" HaHa! I am aware of Lokar. But I appreciate you offering the info. How's your blazer coming along?
Turp Mcspray
Old 05-17-2010, 03:24 PM   #61
Brandoneh
What are the specs on those headers? I'm looking for a set for my 71.
71 K5 In progress!
Brandoneh is offline   Reply With Quote
Old 05-17-2010, 09:16 PM   #62
turp mcspray
The headers are "doug thorley". I believe they are 1 3/4" tubes. They are a "tri-y" style of header. Designed to maximize torque in the lowend and midrange rpm range. They are very well built with heavy gauge tubes and thick flanges. With a heavy blazer and 35" tires, I don't care if my engines powerband shutsdown at 5000rpm. I am after as much lowend and midrange torque as I can squeeze out of my 454. I would like to be able to drive my blazer on a regular basis, and not be in the single digits for milage. We'll see how that pans out. LOL!
Turp Mcspray
Old 05-20-2010, 01:16 AM   #63
chevyblazer
chevyblazer's Avatar
nice blazer man and welcome do a lot crawling
cucharitas customs
chevyblazer is offline   Reply With Quote
Old 05-20-2010, 02:40 PM   #64
Brandoneh
Thanks for the info. Any idea on a part number? I'm trying to make a list on what works!
Exhaust looks sweet! Very well done!
71 K5 In progress!
Old 05-20-2010, 09:35 PM   #65
turp mcspray
I don't remember the # off hand. I think they are listed as 2wd pickup. FYI...I DID have to clearance the frame rails to make them fit nice. If that sort of thing makes you squeemish you will have to keep searching! I have found, that in the world of aftermarket parts, there isn't much out there, that comes out of the box, and bolts right on.
Turp Mcspray
Old 05-21-2010, 01:05 AM   #66
Brandoneh
I hear that man. I'm ready to chop away!
71 K5 In progress!
Old 06-03-2011, 06:39 PM   #67
thor
thor's Avatar
one year checkup?
1972 Chevy Blazer CST.....Project: Polished Turd
thor is offline   Reply With Quote
Old 06-03-2011, 09:25 PM   #68
turp mcspray
Holy crap, has it been that long already?!!! I have made some progress. The chassis is painted, springs and cross members installed, brake and fuel lines installed. I have my receiver hitch and gas tank skid plate painted and ready to install. I need to purchase my crossover steering parts, and have the knuckle machined. I want to get my front axle finished, painted, and installed. Next step is engine, trans, and transfer case. Time to sell some of my NOS stash so I can buy more parts. LOL! I have been extremely busy with my shop. I am currently doing a frame off restoration on a loaded 72 2wd Blazer, and on a 72 super 4x4, shortbox. They keep me thinking about mine, but I just haven't had the time. I have been wanting to post some pics of both, but never seem to make it happen. I will try to post some pics of all three. I can't believe how fast time flies by! Thanks for posting on my project. I WILL post some pics soon.
Turp Mcspray
Old 06-04-2011, 11:24 PM   #69
rsavage
rsavage's Avatar
Turp,
I'm on a round the country trip and I was fortunate enough to spend 4 days in your neck of the woods. You live in some of the most beautiful country I have seen, Visited Mt. Rushmore, Crazy Horse, Deadwood, Sturgis. Custer State Park, etc. You are a lucky man.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 06-04-2011, 11:26 PM   #70
71swb4x4
71swb4x4's Avatar
Turp, we need some pictures of your customers' vehicles. Sounds like a fun shop you have.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 06-06-2011, 10:13 AM   #71
turp mcspray
Originally Posted by rsavage View Post
Turp,
Glad you had fun! If you could see some of the out of the way places that only locals know about, you would never want to leave! It is a very beautiful place to be. I moved away twice in my life, and I will NEVER do it again! LOL!
Turp Mcspray
Old 06-09-2011, 12:28 AM   #72
thor
thor's Avatar
Cool man. Glad to hear you are still turning wrenches on it. Nice to see others wheeling their blazers too!
Old 10-14-2011, 08:51 PM   #73
turp mcspray
Here are a few long overdo pics. I haven't had time to work on it for 6 or 7 months. I decided it was time to start again, a couple of weeks ago. I have all of my crossover steering parts bought. I am planning on painting the front axle, and other misc. parts tomorrow, so I can get the front end back together next.
Turp Mcspray
Old 10-14-2011, 08:58 PM   #74
turp mcspray
Oops, copied the wrong pic. Here are a few more.
Turp Mcspray
Old 01-15-2012, 01:09 AM   #75
turp mcspray
Here are a few more pics. Progress has been slower than I would like.
Turp Mcspray
