Old 04-03-2010, 10:53 AM   #51
creep
Registered Loser
creep's Avatar
Re: '63 GMC Project
We changed the rear cab mount perches out with some 1/2 ton perches I got from Tony (Lilred66) and replaced all the cab mount bushings with new urethanes. It is finally sitting on the ground now too.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 04-03-2010, 10:56 AM   #52
creep
Registered Loser
creep's Avatar
Re: '63 GMC Project
This shot is going to be my new avatar
Old 04-03-2010, 11:05 AM   #53
Broke1
Broke1's Avatar
Re: '63 GMC Project
Broke1 is offline   Reply With Quote
Old 04-03-2010, 11:07 AM   #54
creep
Registered Loser
creep's Avatar
Re: '63 GMC Project
Originally Posted by ruffrida2005 View Post
Let me know how far you set your axle from the rear cab mounts at ride height. I believe it's 56". I'm going to set my pinion at ride height, then drop it to the ground before I mount the bags. I'm not going to run very much air in the rear to lift it. I hope I'm going in the right direction.
Well I Measured the distance from the axle to the cab mount for you but unfortunately I measured from the 3/4 ton mounts and not the 1/2 mounts and the 3/4 ton mounts look a little wider, sorry. It was close to 56" like you said but we moved my axle back a little to split the differenced between the wheelbase at ride hieght and laying out. My lower links are about 35-3/8" from bolt center to bolt center. that may change when the pinion is completely dialed with a driveshaft in it.
Old 04-03-2010, 10:41 PM   #55
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Re: '63 GMC Project
Thanks man, the truck looks sweet. You gonna get it on the pinch or the rocker. I'm thinking about laying it on the rocker since I have to cut the trans tunnel anyways, whats a little extra metal to cut out of the way.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 04-04-2010, 10:32 AM   #56
creep
Registered Loser
creep's Avatar
Re: '63 GMC Project
It wouldn't be that hard, maybe just hit the urethane cab mount bushings with the belt sander, but It sits fine for me now.
Old 04-19-2010, 04:07 PM   #57
creep
Registered Loser
creep's Avatar
Re: '63 GMC Project
Got a few more things done. Installed the swaybar, test fit the rear caliper brackets and painted the centercaps for the steelies I'm going to run for a while. We also painted the rest of the frame (except the very rear, untill we get a fuel cell test fit) and rear suspension parts but haven't taken any pics of it yet.
The swaybar:
The rear calipers:
The centercaps:
Old 04-21-2010, 09:19 AM   #58
creep
Registered Loser
creep's Avatar
Re: '63 GMC Project
Can this thread be moved to the "Projects and Builds" section?
Old 04-21-2010, 12:10 PM   #59
Bazooka
Keepin it old school
Bazooka's Avatar
Re: '63 GMC Project
Project is looking good man..
Bazooka is offline   Reply With Quote
Old 04-26-2010, 04:17 PM   #60
creep
Registered Loser
creep's Avatar
Re: '63 GMC Project
Old 05-02-2010, 10:47 AM   #61
creep
Registered Loser
creep's Avatar
Re: '63 GMC Project
I went to a swap meet yesterday and picked up some new door seals and an air intake for the 63, but the real magic happened at Summit Racing on the way home. I finally ordered my motor, a 405 hp Blueprint 383 longblock. Can't wait 'till that bad boy comes in so we can go pick it up.
Old 05-02-2010, 02:26 PM   #62
creep
Registered Loser
creep's Avatar
Re: '63 GMC Project
This is the motor: http://www.summitracing.com/parts/MLL-BP3830CT1/
Old 05-02-2010, 02:58 PM   #63
Bazooka
Bazooka's Avatar
Re: '63 GMC Project
That motor should be fun
Old 05-02-2010, 04:30 PM   #64
ruffrida2005
Re: '63 GMC Project
Man I need your job man, your blowing your load on this truck.
Paul
Old 05-02-2010, 05:42 PM   #65
creep
Registered Loser
creep's Avatar
Re: '63 GMC Project
Unemployment pays better than you think
Old 05-02-2010, 05:45 PM   #66
creep
Registered Loser
creep's Avatar
Re: '63 GMC Project
The motor was on sale for $2,965 when I ordered it.
Old 05-02-2010, 09:58 PM   #67
ruffrida2005
Re: '63 GMC Project
I guess I need to hurry up and get out the army so I can get somewhere in life.
Paul
Old 05-02-2010, 10:47 PM   #68
scotts62
One day...
scotts62's Avatar
Re: '63 GMC Project
Nice build you have going, keep up the good work!!
Scott
93 crew cab build
Project 62
Old 05-24-2010, 09:39 AM   #69
creep
Registered Loser
creep's Avatar
Re: '63 GMC Project
a little more progress...
Old 05-24-2010, 06:23 PM   #70
scotts62
One day...
scotts62's Avatar
Re: '63 GMC Project
Thats going to be fun to cruise around in!
Scott
93 crew cab build
Project 62
Old 05-24-2010, 06:53 PM   #71
TwiggyTheDrummer
Keep It Simple Stupid.. Nope..
TwiggyTheDrummer's Avatar
Re: '63 GMC Project
Man, I love it!
1963 GMC SWB Fleetside in Sunburst Orange Metallic
305E V6 w/ Plaid VC, Powerglide, BOSS 313 20" Chrome Wheels, Kumho Ecsta STX 275/45/R20's, Alpine/Clarion System, Dynomax Exhaust
Old custom classic trucks have soul. Their dashboards aren't plastic, and they've survived both the best and worst of what the 20th century had to offer. For the owners of these trucks, it's often the same story. Through both good and bad times they persevered, until one day they could turn the key and roll up in a customized truck everyone with good taste would admire.Custom Classic Trucks
TwiggyTheDrummer is offline   Reply With Quote
Old 05-25-2010, 08:37 AM   #72
creep
Registered Loser
creep's Avatar
Re: '63 GMC Project
Thanks guys.
It will be hard to not smoke the skinny tires that I will be running for a while, that's for sure.
Old 05-25-2010, 09:19 AM   #73
TwiggyTheDrummer
Re: '63 GMC Project
One day I'll drop mine, but man, I do love the look of airbags. Can't wait to see it on the road.
And hey, all those unemployment checks that they withheld and then suddenly sent me payed for those wheels and tires on my Blazer. And it only took half of what they owed me. They just didn't think I was looking for jobs until they saw that I got one.
Old 08-08-2010, 09:30 PM   #74
creep
Registered Loser
creep's Avatar
Re: '63 GMC Project
Ok, time for an update. We have been working on it, just lots of little boring stuff like brakelines and painting little parts. But today was a pretty good day. The new tires are finally mounted and the motor and tranny went in today. We also rolled it outside to see it in the sun.
Old 08-08-2010, 09:55 PM   #75
McC_65_91
McC_65_91's Avatar
Re: '63 GMC Project
good work, interesting build... and i love long beds as well as the its different, i got a 65 gmc
McC_65_91 is offline   Reply With Quote
