Old 01-03-2010, 06:09 PM   #51
79gmc5.3
6.0L power.........
79gmc5.3's Avatar
Re: 79 GMC Sierra LWB 6.0L swap
Ok guys, trying to decide on the electronic or a cable style throttle body. My engine came with an electronic style but I don't have the pedal or TCM. Or does the PCM control the throttle? I have a cable style also so I have both. Just need the pedal and TCM. What would I have to do to use the cable style? Thanks in advance.
What ever the mind of man can conceive......... he can achieve!
My built thread http://67-72chevytrucks.com/vboard/s...d.php?t=375914
1979 GMC Sierra 6.0 L 4L60E
1995 Mustang GT 347
79gmc5.3 is offline   Reply With Quote
Old 01-03-2010, 06:12 PM   #52
clinebarger
The ECMs are different between the drive by wire and drive by cable. Do you have both ECMs?
clinebarger is offline   Reply With Quote
Old 01-03-2010, 06:18 PM   #53
79gmc5.3
6.0L power.........
79gmc5.3's Avatar
No I just picked up an intake with the cable T/B on it. I have to have the PCM reflashed anyway, can the electronic T/B function be taken out? Or would it be best to just get the pedal and TCM?
1995 Mustang GT 347
Old 01-03-2010, 06:50 PM   #54
clinebarger
Get a pedal & TAC module. Drive by wire computers do not have IAC functions. And your stock harness has no IAC plug or harness. You will also need the harness between the TAC module and pedel.
I see modules,harness,pedal at wreaking yards all the time, got the whole package for $20 a few weeks ago
Old 01-03-2010, 07:55 PM   #55
menace121978
menace121978's Avatar
the drive by wire is a cleaner install and only requires 4 wires to be hooked up for cruise control because its all controlled by the computer.
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 01-03-2010, 10:09 PM   #56
79gmc5.3
6.0L power.........
79gmc5.3's Avatar
Thank God for all the wisdom on this board. See I knew if I ask the question I would get a wealth of knowledge. You guys are the best, thanks Dennis and Cline
1995 Mustang GT 347
Old 01-03-2010, 11:25 PM   #57
menace121978
anytime buddy! btw, have ya had a chance to go by BRP?
"Dennis the Menace"
Old 01-04-2010, 08:47 AM   #58
79gmc5.3
6.0L power.........
79gmc5.3's Avatar
Now that Christmas is over I will try to get over there this week. I am off Friday thats when I plan to go. BullDawgMuscleCars is also local for me I want to go by and see his build. He thinks that their kit will set the motor and trans high enough to get the a/c in the stock location. Thats what Phil at BRP told me also. But I would like to see before I spend the money.
1995 Mustang GT 347
Old 01-04-2010, 08:54 AM   #59
menace121978
your the man! thank you... i feel the same way. its piece of mind before dropping 1k on the mounts and headers
"Dennis the Menace"
Old 01-04-2010, 04:21 PM   #60
79gmc5.3
6.0L power.........
79gmc5.3's Avatar
Hey guys another stupid question. Does this electronic throttle pedal need a TAC (Throttle Accuator Control)? Or is it built in to the pedal or something seperate?
1995 Mustang GT 347
Old 01-04-2010, 04:28 PM   #61
clinebarger
You need the pedal, throttle actuator control module, the harness between the two. when i get off ill take some pics of one.
Old 01-04-2010, 07:17 PM   #62
79gmc5.3
6.0L power.........
79gmc5.3's Avatar
Man, That would be great thanks
1995 Mustang GT 347
Old 01-04-2010, 08:57 PM   #63
79gmc5.3
6.0L power.........
79gmc5.3's Avatar
Does anybody know year interchangeability for the 4l60E, 4l65E, and 4l80E are. The 6.0l is out of a 2003 Yukon Denali. Haven't decided which trans to use yet. Was told for a daily drive light towing the 4l60e is OK, the 4l65E is a beefed up 4l60E. and the 4l80E was used in the 3/4 ton trucks for heavy towing. Was also told that the 4l80E took more HP because of the large rotating mass of the internal components. I just need to know which years I can use. OK Ole guys of wisdom lets hear it.
1995 Mustang GT 347
Old 01-04-2010, 09:02 PM   #64
Shon
Depending on what trans the PCM and harness you have is made to control depends on what your next options are. If the PCM controlled the 4l60e and has the wiring harness then that is the easiest thing. If you change to a different trans then you will need to change some of the pin placements and have the PCM segmented for the right trans.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 01-04-2010, 09:23 PM   #65
79gmc5.3
6.0L power.........
79gmc5.3's Avatar
I was going to let wait4me performance reflash my PCM and rework my stock harness. Do you know what years I need to stay with?
1995 Mustang GT 347
Old 01-04-2010, 09:31 PM   #66
Shon
we use them all.....but if you are going to have him do it see if he has a preference.
Old 01-04-2010, 11:34 PM   #67
clinebarger
I cleaned out my garage for my 39 and dont know where i put it. but do have some illustrations hope this helps
Old 01-05-2010, 09:14 PM   #68
79gmc5.3
6.0L power.........
79gmc5.3's Avatar
Hey guys found a GM #12588924 Throttle Actuator Control will this work with my 2003 6.0L?
1995 Mustang GT 347
Old 01-09-2010, 02:23 PM   #69
79gmc5.3
6.0L power.........
79gmc5.3's Avatar
Small update with a few pics. Motor is back together. got the gas pedal and TAC module. Motor mount plates are ordered, got the Harness and ECM boxed ready to ship to Wait4Me Performance . Will start pulling old engine in the next few days. Slow but any progress is a good thing!
1995 Mustang GT 347
Old 01-09-2010, 08:02 PM   #70
menace121978
looking good buddy! slow and steady!!
"Dennis the Menace"
Old 01-11-2010, 04:59 PM   #71
BulldawgMusclecars
BulldawgMusclecars's Avatar
Looking good! Looks like my customer is running into a few delays, but hopefully it won't be too much longer. I'm really looking forward to doing one of these swaps for myself!
Joe Hinds
Bulldawg Musclecars
bulldawgmusclecars@yahoo.com
http://www.bulldawgmusclecars.com
BulldawgMusclecars is offline   Reply With Quote
Old 01-11-2010, 05:02 PM   #72
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Engine looks great. Cant wait to get my 6.0 shipped. I am VERY excited.
--Josh
Old 01-11-2010, 07:24 PM   #73
79gmc5.3
6.0L power.........
79gmc5.3's Avatar
Yea! I am working a little on the truck and a lot on my patience While I had it apart I put a set of Z06 Valve springs with titanium retainers and keepers with new valve seals and a set of Comp Cams .080 wall push rods. I did this now because when I get it in and running I may want to put a set of 1.8 roller tip rockers on it too help with the low end torque.
1995 Mustang GT 347
Old 01-15-2010, 01:48 PM   #74
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Dang, I'm just starting to get caught up on all the build threads. The swap is looking good! I like what your body guy did with the floor for the seats! I was kicking around using a set of those in my 85, but not sure I want to relocate the gas tanks after just buying 2 new ones! I've though about building my own mounts and using a set of universal slides, that would set the seats a lot lower.
Lookin great, keep it up!
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 01-22-2010, 05:38 PM   #75
STOCKISH
STOCKISH's Avatar
Looking great, hows the progress?
--Josh
