Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 GMT400 Chevy & GMC Pickups Message Board > projects and builds 88-98
Old 02-14-2010, 10:23 PM   #51
19723DR
19723DR's Avatar
Re: Project ''Second Time Around''
Originally Posted by 88chevyshort View Post
nice build. how did you go about painting the dash trim like the glove box, etc?
Thanks. I'll be painting the rest of the plastic prices of my interior in the future. I will go into more detail then.
72 Suburban 3 Door http://67-72chevytrucks.com/vboard/s...d.php?t=265728 family fun cruiser
71 Cheyenne Project http://67-72chevytrucks.com/vboard/s...d.php?t=299232 Almost finished
93 Silverado http://www.67-72chevytrucks.com/vboa...d.php?t=378258 Flamed, bagged, body dropped on 22's
98 Chevy short bed DD
97 Z71 3 Door
51 Suburban-S-10 swap
"What other hot rod can you carry 7 of your friends in"
19723DR is offline   Reply With Quote
Old 02-14-2010, 10:46 PM   #52
19723DR
19723DR's Avatar
Today I finished up the passenger side. Here are the pic from this weekend.
Drilled a new hole for the air line.
97 Z71 3 Door
Old 02-14-2010, 11:00 PM   #53
19723DR
19723DR's Avatar
Air line.
Mounted to the frame.
Lower bracket. There is a bottom flat plate that is welded to the A arm. I originally had to modify this bracket to fit down inside the A-arm. Most of the kits now come with a lower cup.
97 Z71 3 Door
Old 02-14-2010, 11:17 PM   #54
19723DR
19723DR's Avatar
After running the air lines down the frame to the rear I put my 22" wheels on because they are the largest wheels that I have so I can get a good idea of where to place the inner fenders when I make them. Then, I pulled the jack stands and let it down to take some pictures.
Cut the inner fender out so the tire would tuck.
97 Z71 3 Door
Old 02-14-2010, 11:28 PM   #55
19723DR
19723DR's Avatar
With the fender and bumper on. Test fit.
I'm going to have to move the wiring harness.
97 Z71 3 Door
Old 02-14-2010, 11:44 PM   #56
Restrorob
The One And Only !!!
Restrorob's Avatar
Lookin Good !
I've got another question.... Hope you don't mind my questions ?
I may bag mine if I ever hit the lottery.
Since cutting out the fender I assume the wells will need modifying as well, What are your plans for re-locating the ABS and ECU ?
I had to modify my ECU mounting to clear the hood hinge assembly I installed and to me there's little room.
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 02-15-2010, 12:59 AM   #57
19723DR
19723DR's Avatar
Originally Posted by Restrorob View Post
Lookin Good !
I don't know about the lottery, but maybe Uncle Sam will be sending you a check in the mail soon!
For the inner fender, I'm going to take a trailer fender and weld it to the inside of the fender for my wheel well. Right now all I need to move is the wiring harness where it goes into the firewall so that I can steer when driving low.
The 95 and up are different. I know on the new models the ABS and ECU are a little more tricky to work around. I've seen guys make brackets on the new inner fender for those, but since mine's the older model, my ECU is in the dash and my ABS is out of the way.
Here's a picture where the tire sits now, not a very good angle. There is not as much junk under the hood of the older models, so I' lucky in that aspect.
97 Z71 3 Door
Old 02-15-2010, 06:57 PM   #58
Restrorob
Restrorob's Avatar
Well heck..... Guess I got the years mixed up ya have sooo many listed !
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 02-15-2010, 11:17 PM   #59
19723DR
19723DR's Avatar
No problem, questions are a good thing, keeps me on my toes.
97 Z71 3 Door
Old 02-23-2010, 02:55 PM   #60
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Looks sweet
I dig how you matched the paint on your JS
And I want that steering wheel !!! Does it do green ?
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 02-23-2010, 05:13 PM   #61
19723DR
19723DR's Avatar
Originally Posted by Spray-Bomb View Post
Looks sweet
Jet Ski. . . took me a minute. The Jet Ski was the guinea pig. It all started with an unfortunate accident when it jumped off the trailer and put a hole in the hull. In the process of fixing the hull I decided to just paint the entire thing.
Yes it does go green, blue, red, light blue, yellow, purple and white. There is also a setting where it will cycle through the colors.
97 Z71 3 Door
Old 03-12-2010, 07:51 PM   #62
70stroker
70stroker's Avatar
Hey man whats been the progress. Its been a few weeks since the last update. Im sure your just busy with that project called life.
70stroker is offline   Reply With Quote
Old 03-13-2010, 06:09 PM   #63
19723DR
19723DR's Avatar
Not much, I'm such a slacker. I worked on it a little bit today. I've mostly been trying to sell one of my other trucks so I can get funds for other stuff. Work has been really slow; I only worked 20 hours last week, but this week was better. You'd think I could find some time for the truck, but the house and yard need serious attention from the last four years of projects.
97 Z71 3 Door
Old 03-13-2010, 06:20 PM   #64
19723DR
19723DR's Avatar
Today I worked on the wiring harness. Since my truck has a clutch, there is no way to move my harness sideways, over and up, unless I want to move the clutch master cylinder - which isn't going to happen--so I did manage to notch the fire wall enough where I was able to recess the entire thing in about 3/4 of an inch which will give me enough room to get the wheel well in there and room to turn.
97 Z71 3 Door
Old 03-21-2010, 10:25 PM   #65
Ger
Where did you find a steering wheel like that? That is so cool
Ger is offline   Reply With Quote
Old 03-22-2010, 10:25 PM   #66
19723DR
19723DR's Avatar
Thank you. I got it from JC Whittney but I don't know if you can get it any more. I've had this about six years. It's made by APC. The one bad thing about it is a cord goes from the steering wheel to a control box so when you turn the cord gets wrapped up around the steering wheel and it's really annoying. I'll post some pictures of it lit up in the dark later.
97 Z71 3 Door
Old 03-25-2010, 03:56 PM   #67
88chevyshort
88chevyshort's Avatar
still extremely interested in how you went about painting your interior
1988 chevrolet k1500 shortbox, regular cab, 5.7, 6-lug 14bolt rear with 4:10 limited slip, 2500 leafs, extra leaf. front gears are still 3:73 =/ ride height is 3-4inches over stock. http://www.cardomain.com/ride/3346228
current daily driver: 1993 cherokee sport, 265k+ miles
http://www.cardomain.com/ride/3034735
88chevyshort is offline   Reply With Quote
Old 03-27-2010, 12:02 AM   #68
19723DR
19723DR's Avatar
since it will be a while before I get to painting any plastic pieces, here is a great link that will show you all the basics.
http://www.fullsizechevy.com/showthr...extured-pieces!
97 Z71 3 Door
Old 04-12-2010, 12:53 AM   #69
19723DR
19723DR's Avatar
For the last two weeks I had way to much time off (No work) and have kept busy at home getting all the things I been putting off around the house. I did find some time for the truck removing the helper bags, spare tire brackets, and cleaning up the rear frame. This truck is going to be on the back burner for awhile, lack of funds. But if you know me I'll find time for it soon.
97 Z71 3 Door
Old 04-12-2010, 06:52 PM   #70
70stroker
70stroker's Avatar
best of luck to ya man. I know youll get stuff sorted out
Old 04-13-2010, 12:35 AM   #71
19723DR
19723DR's Avatar
Thanks. I've been collecting materials for years now from demo jobs for years. A few years back I saved some heavy gauge fence posts. This weekend I built a car port on the side of the house out of that. So far I'm into it $25 bucks for the cement for the posts, just need to buy the roof matirial. The good thing is I'm 6 months ahead of schedule on all the house projects from all the time off. Right now I can't justify spending any money on toys.
Good new is my company just landed a 6 month job to start the end of this week.
97 Z71 3 Door
Old 05-02-2010, 10:06 PM   #72
19723DR
19723DR's Avatar
This weekend was really good. Saturday morning me and my brother went to Pick-n-Pull and picked up some cams for his MR2. On the way home we stopped and picked up some trailer fenders and a new chrome 95-98 grill. The rest of Sat and Sun I spent working the inner fenders.
97 Z71 3 Door
Old 05-02-2010, 10:20 PM   #73
19723DR
19723DR's Avatar
That's as far as I got this weekend. Earlier this week I visited my friend Chappy at Sinister Fab Works, a local custom truck builder. He talked me into making the 2-Link from scratch. He's going to line me up with all the rear suspension parts.
97 Z71 3 Door
Old 05-03-2010, 12:11 PM   #74
98lowtahoe
98lowtahoe's Avatar
Looks good keep up the good work
98lowtahoe is offline   Reply With Quote
Old 05-16-2010, 11:35 PM   #75
19723DR
19723DR's Avatar
Thanks. I appreciate the support.
97 Z71 3 Door
