03-31-2011, 01:53 AM | #51 |
fat old dude
Re: Ice cream getter
thats alot of wires
1972 c-10 shortbed 350/400 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=389157 1968 workhorse http://67-72chevytrucks.com/vboard/s...d.php?t=446216 Accepting part donations |
03-31-2011, 05:20 AM | #52 |
Great to see this one making progress.
Body looks good! |
08-16-2011, 10:10 PM | #53 |
Another five months have clicked by with little to show but little is better than nothing right? Still mocking things up before another round of disassembly. Motor mounts are finished and after trying a couple sets of off the shelf headers and not being happy I had a pair custom made. It hurt a little, but I got just what I wanted.
08-20-2011, 11:06 PM | #54 |
A little more progress…
My original engine/front light harness was really shot so I made one good harness using three junk harnesses. Really easy after figuring out how to remove the blades without destroying them. Also put the left fender back on to make sure the location I choose to mount the ECM would work. That went well so I couldn’t resist hanging the right side. That didn’t go so well. Not happy with the gap at all. Two steps forward, one step back! I put the tires and wheels back on just because… |
08-20-2011, 11:12 PM | #55 |
VA72C10
I know you're not happy with the gaps but it's looking good in pictures
Looking for a 67-72 swb or blazer project in or around VA. |
08-21-2011, 07:55 AM | #56 |
^^^I agree, looks perfect from here, gaps can be worked on later bfore paint
Did you polish the slots Looks like a quality build so far
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
09-26-2011, 09:20 PM | #57 |
Thanks for the good words.
I agree, the gaps can always be adjusted after paint but I’m planning to build the truck, tear it all the way down, add paint and bolt it all back together without any surprises. That’s the plan anyway. I worked in a body shop about fifteen years ago and recently ran into a friend of mine who is still there. He doesn’t work in the shop anymore but offered to help me out. Good people. They allowed me to come in on a Saturday when the shop is closed and use one of the racks. Never burn bridges. My friend actually did all of the real work, I just did the grunt stuff. Anyway, we found three body mounts had settled or tipped down along with the frame rail turning outward. The worst was the main support under the driver’s feet which had dropped by about a ½” and the front right frame rail was down about ½”. We also pulled the right side of the cowl ahead about ¼”. All of this gave me the gaps around the right door that I was looking for without shims and with all hinges and fender slots being on center. Now, if after paint I still want to make some small adjustments, there is room. After a few tugs and getting really close |
09-26-2011, 09:29 PM | #58 |
jarros44sr I just seen your question about the slots. They are actually “new”. I found them on eBay. They are MT’s that were discontinued several years ago. Some guy in California had four 12” and one 10” and would not separate them. I keep checking every now and again to see if I can find anymore 10” to put another set together but no luck. If not it will make for a shiny hose hanger.
09-22-2012, 09:31 PM | #59 |
Fall is here so it’s time to get back at it. I removed the Skyjacker leafs and replaced them with a set from Deaver. Rears are basically a bolt in but because of the additional length the fronts required a little more effort.
Fronts - Skyjacker vs. Deaver Rears - Skyjacker vs. Deaver |
09-22-2012, 09:59 PM | #60 |
After another round of tear down I cut out a section of the fire wall and replaced it with the panel that came with a Vintage Air setup I picked up. I also had an opportunity to use a rotisserie. Not necessary but definitely makes things easier. I think this truck has had everything imaginable mounted under the dash at one time or another. Lots of holes to close up.
Kind of feels like I’m not getting anywhere… |
09-24-2012, 12:29 PM | #61 |
reading this brings back old memories lol.
good progress!
Blazer Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=483399 |
10-12-2012, 09:45 PM | #62 |
I wish I had a good comeback to that but I don’t so I’ll just keep sanding and sanding and sanding…
The tub should be ready for paint tomorrow and I still don’t know what color I'm going with. |
10-17-2012, 08:51 PM | #63 |
looks amazing so far,,,cant wait to see some color
21 2500hd duramax 58 apache HILLJOB GRAPHIX--for all your graphic needs My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=542497 LS ENGINE SWAP INFORMATION THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=377348 4l60 to an NP205 http://67-72chevytrucks.com/vboard/s...43#post3697343 |
10-17-2012, 09:47 PM | #64 |
Picking a color is absolutely killing me. I am “borrowing” space at a friend’s shop and have to spray this weekend. I still have no idea what color though!!
10-17-2012, 10:40 PM | #65 |
the color that it was looked good,,myself, i think im gonna do a 2 tone..me and my boy really like this one,only i might use a hugger orange,not sure
10-18-2012, 06:33 PM | #66 |
I hope you get a color you like(love) the 1st time...I painted the fire wall Sunburst Orange Met and decided it was too dark...I wanted something really bright. I finally mixed my own, more lime than olive. This Blazer is amazing, BTW...Good luck.
10-19-2012, 12:23 AM | #67 |
I'll will try and remember to look up the paint code, but what I'm using is Allis Chalmers Persian 2, it's an eye popping color. Here's our most recent restoration. David
10-21-2012, 09:29 AM | #68 |
Hilljob – that two tone blazer has been one of my favorites as well.
Notsolo – I like it. Reminds me of a ’75 I had. I think it was called spring something or other. A friend now owns that truck and says he gets compliments on the color all the time. |
10-21-2012, 09:38 AM | #69 |
Coggonobrien – I don’t farm but I really want to restore an old Case someday. I found a slide dated ’64 of a 530 that my wife’s grandfather owned and have wanted one ever since.
10-21-2012, 09:51 AM | #70 |
Well, after way too much thought I finally decided on a color. Dark olive it is. Not the direction I was originally thinking. I was looking for something bright and bold so I’m not sure so sure how I ended up with this. Should have had the outside completed too but had one of those nothing went right experiences.
10-21-2012, 10:08 AM | #71 |
Looks great...Dark Olive Excellent choice...This was in my top 10 file...not mine unfortunately...
10-21-2012, 12:04 PM | #72 |
Looking good nice color!I am still putting mine together after fresh paint last winter.Keep the fresh paint pictures comimg.
1972 Blazer CST Dark Olive, am/fm, tilt, tow hooks, tach dash 1972 SWB C-10 Highlander Blue/White 1972 Canadian 2wd Jimmy light olive 1970 SWB 4x4 4 speed 307 |
10-28-2012, 07:02 PM | #73 |
” I am still putting mine together after fresh paint last winter”
Gillnetter you are moving at a pace I am familiar with Finished painting the tub this week including blacking out the bottom. Base went ok but the clear, not so much. This stuff was thick and heavy like no clear I’ve sprayed before. I should have reduced it but wasn’t sure the reducer I had would work and as it was about midnight I couldn’t call anyone I knew to ask. My gun is set up for much finer or thinner material, like the base, so I kept spraying. I cranked up the air pressure and just poured it on. The end result was lots of orange peel and plenty of sags. Even had a couple of bugs decide to take a rest after the last coat. The worst part was when I turned the tip on my gun to spray with a horizontal fan for the tail light area. I quickly hung the gun up adjusted the rotisserie and then forget to turn the tip back before spraying the bed side. I was pissed. The next day loaded up and going home. |
10-29-2012, 05:48 AM | #74 |
It's alsways something.....
Anyone know what the seats are from in the Dark Olive interior? Those look great
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie 1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts 1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e |
10-30-2012, 09:46 AM | #75 |
Man.... is that looking good.
