Old 09-28-2010, 09:04 PM   #51
AZ66GMC
Desert Dweller
AZ66GMC's Avatar
Re: My 66 GMC LWB
Originally Posted by Shaky View Post
Man - you sure work fast. That looks great.
Thanks Shaky
Tony
Tony
66 GMC LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=399283
AZ66GMC is offline   Reply With Quote
Old 09-30-2010, 11:55 PM   #52
AZ66GMC
Desert Dweller
AZ66GMC's Avatar
Re: My 66 GMC LWB
Thanks shaky
Hope to get the front put back together this weekend.
Tony
Tony
66 GMC LWB
Old 12-27-2010, 12:05 AM   #53
AZ66GMC
Desert Dweller
AZ66GMC's Avatar
Re: My 66 GMC LWB
I spent the day putting on some of the Christmas goodies that I got
First I installed the head light relay kit that I got from LMC. I figured that this would be the easiest way, but boy was I wrong...
I had no problem installing the kit, but when I fired up the light switch, it was another story... The outside lights worked fine, but the inner two lights had a slight glow to them. When I hit the high beams, they all worked fine.
First, I thought that I had a bad ground, so I installed a ground wire from each headlight bucket to the battery. That helped a little, but the inner two light still had a glow to them with the low beams on. I pulled the grill out again to look at the wiring again and make sure that I didn't have and loose connections.
As I was looking everything over, I compared the original harness to the new one and noticed that the outer headlight connectors on the new harness had the green and black wires in opposite locations. I looked into the headlamp (sealed halogen) and noticed that this high beam wire (green) was connecting to the common terminal on the back of the headlight... So I was running the power through the common ground for the two filaments instead of the high beam filament... I swapped the wires in the connectors and they are now working properly... Of coarse, now one of my high beam lamps (4001) burnt out in the process...
So, to sum it up, if I had known that this harness from LMC was made in Taiwan, I would have just got some new headlight wire connectors, wire, relays and just wired it myself... I didn't want to return it thinking that it should work fine and didn't want to disappoint the wifey...
Oh well, live and learn
Tony
Tony
66 GMC LWB
Old 12-27-2010, 12:08 AM   #54
AZ66GMC
Desert Dweller
AZ66GMC's Avatar
Re: My 66 GMC LWB
I also converted my external regulator alternator to and internal one and installed my new clear dome light with and LED lamp
Tony
Tony
66 GMC LWB
Old 12-27-2010, 12:10 AM   #55
AZ66GMC
Desert Dweller
AZ66GMC's Avatar
Re: My 66 GMC LWB
And, my new tach
Tony
Tony
66 GMC LWB
Old 12-27-2010, 01:00 AM   #56
daverod
SSN 706
daverod's Avatar
Re: My 66 GMC LWB
Very nice. Like how you work. I would be scared to work on a truck that nice. I'll be looking for another cross member.
daverod is offline   Reply With Quote
Old 12-27-2010, 01:23 AM   #57
AZ66GMC
Desert Dweller
AZ66GMC's Avatar
Re: My 66 GMC LWB
Thanks daverod, I would love to do a frame of resto, but the funds don't permit it and I'm already knee deep in my tribute truck for my belated son. I just don't have the room or funds
The truck is pretty solid, but I did find some small rust holes in the lower part of both front fenders and in the floor board at the kick panels... I was pretty disappointed when I found them, but they are fixable.
Just need more time and money....
Tony
Tony
66 GMC LWB
Old 12-29-2010, 01:57 PM   #58
AZ66GMC
Desert Dweller
AZ66GMC's Avatar
Re: My 66 GMC LWB
I forgot to mention that I finally got the truck registered with my vintage 1966 plate
It's an original 1966 plate that was last registered in 1968
Tony
Tony
66 GMC LWB
Old 12-29-2010, 02:12 PM   #59
daverod
SSN 706
daverod's Avatar
Re: My 66 GMC LWB
Very cool. I got a thing for plates. Thinking of doing my firewall and kick panels next.
Old 12-29-2010, 06:24 PM   #60
AZ66GMC
Desert Dweller
AZ66GMC's Avatar
Re: My 66 GMC LWB
Thanks Dave
Ya, I like the vintage plates too. They sell them at a local swap meet for some pretty good coin, but I got lucky and found mine online for $15 shipped
Tony
Tony
66 GMC LWB
Old 12-30-2010, 02:36 PM   #61
AZ66GMC
Desert Dweller
AZ66GMC's Avatar
Re: My 66 GMC LWB
I was playing around with photoshop since it's raining.
This is my Micro-machines version of my truck
Here is a chopped top version
Tony
Tony
66 GMC LWB
Old 12-30-2010, 03:01 PM   #62
daverod
SSN 706
daverod's Avatar
Re: My 66 GMC LWB
Now all u have to do is build it. I'm thinking you'll be the first. Maybe not? Oh ya and make it lay frame. I'm really surprised I hav'nt seen any of those around.
Old 12-30-2010, 04:13 PM   #63
AZ66GMC
Desert Dweller
AZ66GMC's Avatar
Re: My 66 GMC LWB
Ya, that would be cool to build one like that. If I had the time and money, it would be done
Gonna have to go back to play'n the LOTO I guess
Tony
Tony
66 GMC LWB
Old 12-30-2010, 06:49 PM   #64
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
Re: My 66 GMC LWB
Hey Tony,
Thanks for the score on the grill.
Stopped by the platers and they gave me a price on fixing and replating it. Now I just need the extra dough before I drop it off... looking forward to the tax return,,,, filing next Monday... OH! And it was a pleasure meeting you. I think all the 60-66 guys in central AZ should start a club if there isn't one already.
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline   Reply With Quote
Old 12-30-2010, 06:50 PM   #65
66-PMD-GMC
66-PMD-GMC's Avatar
Re: My 66 GMC LWB
Originally Posted by 66-PMD-GMC View Post
Hey Tony,
I forgot to metion.... NICE truck
Projects..
440CID 2X4 Pontiac
Old 12-30-2010, 09:06 PM   #66
AZ66GMC
Desert Dweller
AZ66GMC's Avatar
Re: My 66 GMC LWB
Hey Tony,
Hey Chris, it was great meeting you today. I'm glad that someone got the grill that can put it to good use hopefully it's not too costly to have it rechromed.
I totally agree about a local AZ 60-66 club. We have got plenty of these trucks here
I'll have to look you up the next time I'm the far East side
Tony
Tony
66 GMC LWB
Old 12-31-2010, 10:33 AM   #67
66-PMD-GMC
66-PMD-GMC's Avatar
Re: My 66 GMC LWB
Tony
I have had a lot of stuff done by this plating guy over the years and it's not as bad as you may imagine.
Now all I need to do is find lettering...
And hey, it's really not all that far...
I was home by dark.....
and it snowed on us going home!
That was crazy!
Projects..
440CID 2X4 Pontiac
Old 02-02-2011, 08:06 PM   #68
AZ66GMC
Desert Dweller
AZ66GMC's Avatar
Re: My 66 GMC LWB
I got a good deal on some leather 05 Silverado seats for my truck
Exact color that I was looking for
I got the drivers side bolted in, but still need to finish the other two. Hopefully this Saturday
Hoping to drive it to the Glendale Community College swap meet this Sunday and sell some of my junk I don't need anymore...
Tony
Tony
66 GMC LWB
Old 02-02-2011, 08:16 PM   #69
jimmydean
jimmydean's Avatar
Re: My 66 GMC LWB
Damn, those look awesome! I am looking to do something similar, can't wait,
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 02-02-2011, 08:21 PM   #70
AZ66GMC
Desert Dweller
AZ66GMC's Avatar
Re: My 66 GMC LWB
I've been wanting some for awhile now and just happen to be the first to call on them. They were usually sold by the time I called...
They are very comfortable, I just wish they were a little thinner on the back portion. With the seats hitting the back of the cab, I feel like I need them to go back one or two more clicks on the adjusters... Still not bad to drive, just wouldn't want to drive for hours...
Tony
Tony
66 GMC LWB
Old 02-02-2011, 10:36 PM   #71
66-PMD-GMC
66-PMD-GMC's Avatar
Re: My 66 GMC LWB
I know exactly what you mean about needing just a little more room behind the seat.
I am very seriously contemplating stretching my cab a foot and using a short bed on my longbed frame.
Kind of an extended cab.
I get out of my 95 suburban and slip into the 66 and it just feels pinched.
Projects..
440CID 2X4 Pontiac
Old 02-03-2011, 12:43 AM   #72
SFTorange
SFTorange's Avatar
Re: My 66 GMC LWB
Your seats look great! I wish mine were in tan, but grey is all I've been able to find. Doing a frame off resto is really nice, but expensive and all-consuming. Your truck is WAY better off now than mine ever was. From what I can see, drive it and enjoy it! Nice work!
SFTorange is offline   Reply With Quote
Old 02-26-2011, 12:42 AM   #73
AZ66GMC
Desert Dweller
AZ66GMC's Avatar
Re: My 66 GMC LWB
Well, I installed my third brake light when I got home this afternoon. It was pretty easy and took about an hour to install. I think the hardest part was getting under the dash to tie in the wire to the brake light...
I was smart enough to pull a nylon string in when I replaced my dome light and wire harness, it made it so simple to pull the wire down to the door jam
Tony
Tony
66 GMC LWB
Old 02-26-2011, 12:44 AM   #74
AZ66GMC
Desert Dweller
AZ66GMC's Avatar
Re: My 66 GMC LWB
And... I started working on my spare instrument cluster. I got some cool little LED lights for the turn signals, high beams and alternator.
I'll post more details soon
Tony
Tony
66 GMC LWB
Old 02-26-2011, 07:44 AM   #75
Shaky
Six in a row makes it go...
Shaky's Avatar
Re: My 66 GMC LWB
The third brake light is slick. I like the dash panel too. The '60-'66 panels really lend themselves to customizing (at least they're easier than the '67-'72 clusters).
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
