Old 12-27-2010, 10:43 AM   #51
67cheby
67cheby
67cheby's Avatar
Re: Barn raising
Chris Farley would be very proud, nice work
67cheby is offline   Reply With Quote
Old 12-27-2010, 12:27 PM   #52
brn agn
brn agn's Avatar
Re: Barn raising
That looks great! It adds a nice touch to the truck.
1969 C10 SWB Project Charity Case AKA "Roscoe"
1971 Cheyenne Super A Combined Effort
The Service Station-A practical ministry for those in need
brn agn is offline   Reply With Quote
Old 12-27-2010, 01:25 PM   #53
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Re: Barn raising
Nice! Are you going to buy a little coat and hire a fat guy for shows?
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 12-27-2010, 02:21 PM   #54
67cheby
67cheby
67cheby's Avatar
Re: Barn raising
fat man in a little coat.....
Old 12-27-2010, 03:17 PM   #55
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Barn raising
that is awesome! tons of attitude!!!
John
1999 Toyota Tacoma 4x4
Old 12-28-2010, 01:25 PM   #56
VDOG
Grand PooBaa Member
VDOG's Avatar
Re: Barn raising
Originally Posted by Mike Bradbury View Post
As with any build they have been on and off multiple times as I tweak different geometry sets. Having trouble with the coil overs and their length. I had wanted a shorter shock and spring but was counseled that more travel and dampening the better ride I will get. so I welded the brackets as high as I could get them and it is still two inches taller than I want.
Your build is amazing, your truck is coming along great. Looking at your Lincoln 9" at first glance it looked longer than the chevy rearend to me especially seeing where your shocks are mounted.
But then I read you say its shorter and your tires right at stock spacing..
Since you have the backspace you want on your rim, could you run a wider, lower tire instead of a spacer? Im just throwing something outhere. I had to get my 10 1/2" ralleys altered so I would have a 4 1/2" backspace so they would fit under without cutting tubbing.
VDOG is offline   Reply With Quote
Old 12-28-2010, 02:12 PM   #57
Mike Bradbury
Mike Bradbury's Avatar
Re: Barn raising
Thanks Vdog
The lincoln is wider than the C20 rear by several inches but not the C10 rear. C20's have huge drums on them which takes up axle width. So this is where I was just guessing at the correct width of the axle and b.s. needed.
Unfortunately I did not get the back spacing I wanted. Coy's has certain b.s. for certain wheels and I did not want the wide 10" rim for gas mileage reasons, but I wanted a deeper well on the wheel which would have pushed them out further w/o the need for a spacer. Coy's had recently discontinued the C55 rim that I really wanted, and had only small amount of 18's left to choose from. None were deeper than the ones I got, so I hoped that the amount of b.s. on these wheels would move them out enough, as you can see it did but not enough.
I do not think running a wider tire would have given me the width that i was looking to achieve with the spacers. Maybe next time I will try wider. but I wanted to run the exact same front and rear so that I could rotate when needed.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale
Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961
Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583
Mike Bradbury is offline   Reply With Quote
Old 12-28-2010, 08:48 PM   #58
VDOG
Grand PooBaa Member
VDOG's Avatar
Re: Barn raising
Thanks Vdog
The lincoln is wider than the C20 rear by several inches but not the C10 rear. C20's have huge drums on them wich takes up axle width. So this is where I was just guessing at the correct width of the axle and b.s. needed.
I understand now. I forgot you had a C20, which now makes sense. On that note, as far as a good backspacer, im not sure. Maybe a tire and rim shop might be able to reccomend a good one.
Old 12-28-2010, 09:01 PM   #59
JasonBird
'67 C-10 LWB Driver
JasonBird's Avatar
Re: Barn raising
nice build! the rear end is awesome. very cool truck indeed!
'67 C-10 LWB - My Build Thread
'67 C-20 LWB - My Donor/ Parts truck - SOLD!
'92 GMC SAFARI VAN - My Parts Go Getter
'06 KIA SPORTAGE EX - My Commuter
"All of this crap better make a truck!" - my wife Sue.
Proud U.S.M.C. Dad!
JasonBird is offline   Reply With Quote
Old 12-29-2010, 02:06 AM   #60
Mike Bradbury
Re: Barn raising
Ended up going to Off Road Warehouse and getting a real nice billet set that is designed for off road trucks going off jumps and whoops, so I think it should be fine for street driving. Pushes the wheels 1.125" on each side and is just the right width.
Old 12-29-2010, 01:43 PM   #61
VDOG
Grand PooBaa Member
VDOG's Avatar
Re: Barn raising
Mike thats great news, glad you found some good ones. I went to 4x4 Warehouse in Lawndale a few years ago when I could not find rearend spacers at any local parts store. Cost me a 12 pack of Pepsi for about 20 spacers.
Old 12-30-2010, 12:45 AM   #62
Hoffa
Hoffa's Avatar
Re: Barn raising
Very nice! I like everything you have done with the pickup and you have done it well. Great job.
68 Chev SWB 2WD w/'95 LT1, 6spd, 4:56, 17" whls - family owned since 1973.
70 GMC LWB 4WD w/RAMJET 350, 4spd, 4inch lift, 33" tires, Warn Winch
72 Chev Blazer CST, 350, TH350, 4WD, factory A/C, tilt, radio delete, 77K miles, orig. paint/interior
Hoffa is offline   Reply With Quote
Old 12-31-2010, 06:45 PM   #63
Mike Bradbury
Re: Barn raising
Figured I would take it out and take a couple of pictures that were not in my driveway.
Old 01-01-2011, 12:06 AM   #64
eagleuh1
eagleuh1's Avatar
Re: Barn raising
Love it. The sign looks great.
eagleuh1 is offline   Reply With Quote
Old 01-01-2011, 11:46 AM   #65
67cheby
67cheby
67cheby's Avatar
Re: Barn raising
those were some cool shots
Old 01-01-2011, 12:08 PM   #66
redracer95
Re: Barn raising
hey- from the Sandusky, oh area. the truck looks great. nice job man.
redracer95 is offline   Reply With Quote
Old 01-11-2011, 11:45 PM   #67
Dudewith4x4
Momma Tried.
Dudewith4x4's Avatar
Re: Barn raising
This is my favorite truck on this site..
Ross
1980 c10 4x4 project (Sold):http://67-72chevytrucks.com/vboard/s...d.php?t=377155
1999 F-150 4x4 (DD)
Saving up for a 64
17 and loving it.
Dudewith4x4 is offline   Reply With Quote
Old 01-12-2011, 02:57 AM   #68
Mike Bradbury
Re: Barn raising
Well I don't know what to say, First of all thank you! I am kind of at a loss for words because I have so many inspirations that I have drawn from both here and elsewhere that has ended up with the end result. Over two years it changed in my mind and on paper about three times before I started the build.
I have noticed that after I lowered it and started refining the theme I get all kinds of compliments to the point that I am starting to think about alarm systems and I now park it in the garage and the wife's explorer is on the driveway, she is not thrilled with the arrangement.
Old 01-15-2011, 11:03 PM   #69
77BBGMC
77BBGMC's Avatar
Re: Barn raising
That is a cool pickup!
77BBGMC is offline   Reply With Quote
Old 01-16-2011, 12:14 AM   #70
thirdstreettito
Resident of Here
Re: Barn raising
Hey, for you tires I have a great idea.
Alsa Corporation "Rubber Paint"
Nothing sticks better to rubber!
Rubber Paint goes where other paints dare not tread! It sticks to most rubbers and pliable urethane substrates with unequaled "stretch". No more cracking or peeling like traditional paint. Our special formulation retains it's flexibility much longer than other products which use flex additives that leach out of the paint finish over time. Rubber Paint is an ideal product for restoring or retouching the color if your rubber.
Email them, it isn't on their website, but it's in the catalog.
http://alsacorp.com/
~Bradley~
Miss having a truck
Old 01-16-2011, 01:10 AM   #71
67chevy1series
67chevy1series's Avatar
Re: Barn raising
how hard was it to register your truck as a 1/2 ton
67chevy1series is offline   Reply With Quote
Old 01-16-2011, 04:52 AM   #72
Mike Bradbury
Re: Barn raising
Well that is an interesting story, I am still in the process of it. Had a camper shell on it when I bought it so it had auto plates. When I restored the black and yellow plates for it I went back to commercial. They only asked me to weigh the vehicle, they never had any question about C20 or C10 status. But I am having a heck of a time getting the YOM plates on the truck.
Old 01-16-2011, 04:54 AM   #73
Mike Bradbury
Re: Barn raising
I will have to look up that rubber paint in the catalog but I am really interested in the chrome powder coat, that stuff is cool. I think I will get some and write a review on it for the board.
Old 01-16-2011, 01:45 PM   #74
67chevy1series
Re: Barn raising
my cab came from a 67 3/4 ton truck and i now have it 1/2 ton and wanted to know if i was gonna have any problems
Old 01-16-2011, 04:07 PM   #75
chevy2tom
chevy2tom's Avatar
Re: Barn raising
Mike, I'm thinking of running the Patriot side pipes on my 71. Where did you get them ,what length kit did you orgionaly buy,and how is the sound outside and inside the cab at idle and on the throttle? Thank's, Tom
chevy2tom is offline   Reply With Quote
