Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 10-20-2010, 09:24 AM   #51
madmopar
This guy has got to be stopped
madmopar's Avatar
Re: "The possum" build - 1970 4x4 LWB on mid 70's chassis
Originally Posted by swamp rat View Post
Oh, I did read on other threads that there could be a potential for gas comming out of the filler on a rear fill tank mounted to these trucks, i fail to see how that could be when the tank is used in cars without a problem, i assume you have dispelled the mith?
I used a roadrunner tank, which is originally installed more level than some of the GM tanks that have been used by others... I can see how it might leak on a tank that is supposed to be mounted at an angle (camaro) - OR if you parked on an extreme angle right after filling it up.
Honestly though, I've only put 5-10 gallons in this tank so far... I haven't made the trip to the nearest gas station (15 miles away) to top it off, as the truck is unlicensed, uninsured, and has only the front driveshaft!
It seems to be working well though.
Thanks for your replies... I'm on page 3 now! How many more pages until it is road ready?
J P Evers
1970 4x4 LWB project: http://67-72chevytrucks.com/vboard/s...d.php?t=415134
madmopar is offline   Reply With Quote
Old 10-20-2010, 02:48 PM   #52
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Well, you have it mobile under it's own power. I have a truck build thread on here with a couple more pages than yours and it isn't road worthy or running, and might not be for a few months. I need to knock over that dang money tree! So I'd say you're doing just fine.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 10-26-2010, 03:59 PM   #53
madmopar
madmopar's Avatar
Sorry, no pics again - I didn't do much this weekend. I hooked up the speedometer - which should've taken 20 minutes, but turned into 3 hours...
First, the old speedometer cable was broke off in the speedo gear shaft... so I had to get that out... tried a big magnet, no luck... then ended up taking it out and leaking fluid all over everything... then it took me 30 minutes to coax it out by tapping on it...
Re-installed the gear shaft, and after that, I ran the cable up front... removed the gauge cluster and broke the oil line! so I had to replace that... then I routed the speedo cable into the dash and guess what? the ends were different! The cable I had was the push on style that is held on with a clip to the back of the speedo... but the speedo itself had a screw on fitting!
So I swapped to the '75 speedo I had... I had to grind the mounting ears off the tin guage face on it, but it had the older style mounting on back of the unit too, so it basically bolted right in...
I did have to make a clip to hold it on - but that was pretty simple.
Now I have 2 sets of numbers... they line up perfectly, so I guess I coulda scraped them off of the new speedo (or the lens)... but oh well... it looks like it has a KPH/MPH speedo now... except they read the same!
I'll probably scrape one set of numbers off eventually. I want to add an aftermarket fuel guage (for my chrysler fuel tank and sending unit) in the factory tach hole and put a tach in the factory fuel guage spot. I'm hoping I can find an old Ford or Mopar to donate both guages... or find them at next springs swap meets...
J P Evers
Old 10-26-2010, 04:04 PM   #54
Dieselwrencher
Nice progress.
Ryan
Old 11-09-2010, 05:05 PM   #55
madmopar
madmopar's Avatar
Sorry I don't have any updates... I got a tire repaired... the valve stem was bad... thats about the only thing I've done to the 70 Chevy. I put an old set of radial tires on the 70GMC, and got rid of the split rims... I've been using it to haul wood into the house from the woodshed... like a big wheelbarrow!
I spent this past weekend cleaning out my shop/shed. It can hold 4 cars but I was down to 1 small space to work... I've reclaimed 2 large spaces. I think I may bring the GMC in for the winter and do a total tear down of it... then a 4x4 conversion... I keep saying "might as well" to myself... If I do, I'll start a new build for it...
I've also got lots of other things going on...
We are expecting a BABY GIRL any day... so I've been helping do little things around the house, and waiting.... and waiting... and waiting...
The next couple weeks will be spent helping with the baby, and hopefully I'll get to sneak out and deer hunt a couple days... Then, it'll be Thanksgiving... then Christmas... so I don't think I'll be adding much more this year... I'll check in from time to time though... and I may post pics of the baby... and the deer!
Thanks to everyone who is following this build... I hope to make some real progress next spring!
J P Evers
Old 11-30-2010, 11:25 PM   #56
madmopar
madmopar's Avatar
I have not been working on the truck at all. We had a baby girl on 11/11/2010. Here is a pic of the happy family:
Here is my little girl with her eyes wide open!
J P Evers
Old 12-01-2010, 01:06 AM   #57
swamp rat
swamp rat's Avatar
Congratulations!! Guess some things just take presedence huh?
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 12-01-2010, 03:16 PM   #58
drjeffdc
drjeffdc's Avatar
congrads!!! Looks like a good egg!!!
drjeffdc is offline   Reply With Quote
Old 12-01-2010, 04:14 PM   #59
Dieselwrencher
Congradulations!
Ryan
Old 02-22-2011, 06:16 PM   #60
madmopar
madmopar's Avatar
Well since its been warm, I've been itching to work on the truck. I went parts hunting at a local swap meet last week... looking for a tailgate and doors... I bought a couple doors with all the glass and even chrome trim around the vent windows for $60! only problem with them is the hinge plates need welded... and they have huge trim holes... I'm thinking I might find some upper trim for the truck... but I'll have to fill in the lower holes. I'll get pictures ASAP!
J P Evers
Old 03-08-2011, 02:45 PM   #61
madmopar
madmopar's Avatar
Not much news... but I've done some more parts gathering... I got a set of 40 series flowmasters - 2.5 inches in and out... probably too big for my stock 350... but I got room to upgrade... and it'll sound cool anyway...
I also picked up a couple sets of big tires: 36x14.50x15 and 35x12.50x16.5. I'm looking for some wide wheels as we speak... I've also been marketing them locally looking to trade for some 33's... I think with 36's, I'll have to lift the front... which might need done anyway. Also if I could get 33's, I could stick with my wheels... but I'll probably lift it anyway...
hmm... hard to see, the future... always changing, it is... *Yoda*
J P Evers
Old 06-17-2014, 03:53 PM   #62
madmopar
madmopar's Avatar
UPDATE - This trucks transmission was going out when I put the drive train in it... that combined with a house move, and the salvage title issues, and I kinda lost interest in it. Its been taking up space in my barn, and I had been debating parting it out, but I just picked up another project that this will be a parts truck for. This will be parts/donor on a 72 c/20. The motor and the bed are for sure going onto the 72. I'm not sure what my ultimate goal is with the 72 c/20... I'm leaning rat rod/ shop truck - logo on the door type... might be a new thread...
J P Evers
Old 11-29-2014, 11:26 PM   #63
Matt72blaze
Matt72blaze's Avatar
Hey Mopar,
I'm thinking about doing a body swap like yours. I'm trying to decide where to start. Did you line the front wheels up in the wheelwell and then work your way back? Or, did at least one set of frame/cab mounts line up and you started there?
I'm thinking I'll take off the cab mounts on my '84 frame and use the mounts on my '70 to get the cab on. I know I'l have some fabbing to do either way. I'm also thinking I can set the '70 body down over the rad support mount and use DIY4X's b52 kit to move the axle forward some.
Any tips???
1970 C20 now a K30
1986 3+3 Dually
Matt72blaze is offline   Reply With Quote
