Old 02-28-2015, 04:05 PM   #51
Ohchiiit
Ohchiiit's Avatar
Re: Lowered 73-87 Short Beds
Originally Posted by muthstryker View Post
Like suggested above, I would go right to a 4/6. Most people will want to go lower even from there. I did a 3/3 on my friends truck we rolled it out of the garage and not even within 10 mins of seeing it he already wants it lower.
Mines a 6/8..
What size tires are you running?
Ohchiiit is offline   Reply With Quote
Old 09-12-2015, 03:22 AM   #52
Gabriel661
Originally Posted by joe1982 View Post
4.5ish closer to 5/6
Did u have to. C notch it
Gabriel661 is offline   Reply With Quote
Old 09-12-2015, 01:21 PM   #53
SDC10
My 74
SDC10 is offline   Reply With Quote
Old 09-12-2015, 01:55 PM   #54
Gabriel661
Originally Posted by criscodisco View Post
This is a lmc 4/6 with about a full coil cut off both fronts, and 2 more inches of block out back. The truck is my daily, and besides the occasional lower scrape, i have no complaints.
Did you have to c notch the back
Old 09-12-2015, 02:03 PM   #55
SDC10
Yes
Old 09-12-2015, 02:07 PM   #56
Gabriel661
Originally Posted by SDC10 View Post
Yes
What about if i go with a 3/5 do you have to notch it
Old 09-12-2015, 03:27 PM   #57
nlped
nlped's Avatar
You can go with 4.5"/6" without a notch. Any lower in the rear and a notch becomes necessary...
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 09-13-2015, 05:45 AM   #58
ms2335
ms2335's Avatar
4/6 2.5 drop spindles/springs front and flip kit rear
65 Chevy C10 Short Fleet BBW 6.0L/4l80E
68 Chevy C10 SWB 6.0L/4L80E
84 Chevy C10 SWB 5.3/4l60E QA1 Suspension
ms2335 is offline   Reply With Quote
Old 09-13-2015, 04:50 PM   #59
Speeding Dakota
Speeding Dakota's Avatar
Here mine 4/5 drop - 2.5" CPP drop spindles & 1 coil cut off, rear flip (using Specialtyretail 5" drop brackets) and using KYB Nitro Shocks. Running 255/45/18 & 275/40/18 tires.
Name:  14 - New Tires and paint 5.jpg
Name:  14 - New Tires and paint 9.jpg
Name:  14 - New Tires and paint 14.jpg
Speeding Dakota is offline   Reply With Quote
Old 09-16-2015, 01:50 PM   #60
ddr11
ddr11's Avatar
1987 Step Side W/5-7
ddr11 is offline   Reply With Quote
Old 09-16-2015, 04:59 PM   #61
bbbc10
Diggin The SquareLife
I had 6" drop in back an notched it....but I didn't have too....if your not going to haul anything or tow anything you don't have to with 6" drop.
bbbc10 is offline   Reply With Quote
Old 09-16-2015, 05:02 PM   #62
UKNOWME
UKNOWME's Avatar
Man, I love that truck!
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 09-18-2015, 04:39 AM   #63
dohc91gli
I have a flip in the rear, and the PO heated the coils in the front, any bump and its on the bump stops. I have a few questions.
how many inches does a flip get you? How are you guys achieving your 6"-7" drops in the rear.
and whats the best setup to get the 4.5" in the front?
I'm leaning towards a 4.5"/6" or a 5"/7"
dohc91gli is offline   Reply With Quote
Old 09-18-2015, 10:25 AM   #64
muthstryker
muthstryker's Avatar
Mines a 6/8..
Man I miss this truck!! I check craigslist everyday hoping the new owner has posted it so i can get the thing back from him!
For future reference for the guys that are wondering, the tire sizes at the time were 245/35/20 front and 295/35/20 rear. I regretted at the time not going with a 245/40/20 in the front and would advise anyone looking for a similar combo to go bigger than a 245/35 up front on these trucks.
Matt
muthstryker is offline   Reply With Quote
Old 09-18-2015, 11:27 AM   #65
UKNOWME
UKNOWME's Avatar
I did a flip kit and shackles to get 7. I would recommend spindles and springs for the front.
1964 Chevy c10
Old 05-19-2016, 11:56 PM   #66
TRAU 82
TRAU 82's Avatar
Originally Posted by Jonboy View Post
My '74 is about 6/8. I can't take the credit for the drop, as Scoti did it when it was his DD. I drive it to work a couple times a week, and it rides really well, though.
I really dig your truck Jonboy..would you or Scoti be able to recall what spindle/spring combo and rear setup you used and the staggered tire sizes in front and rear? That thing sits perfect..exactly the stance I'm going for with my '82..
TRAU 82 is offline   Reply With Quote
Old 02-25-2019, 04:02 PM   #67
Goose1985
Goose1985 is offline   Reply With Quote
Old 02-25-2019, 07:00 PM   #68
gmcmoose
gmcmoose's Avatar
The Front Tires Are P255/60/15 and The Rear Are P285/70/15 !!
gmcmoose is offline   Reply With Quote
Old 02-27-2019, 03:51 PM   #69
SCOTI
SCOTI's Avatar
This is an oldy but I noticed a question asked & not answered. JIC someone was/is curious, when that pic was taken, that 74 had dropped spindles, 1-coil removed from the factory V8/sbc coils, & relocated upper shock mounts. The rear was a flip kit on the 8-leaf HD spring pack, Western Chassis c-notches, drop shackles, & relocated lower shock mounts w/2" shorter shocks. It also had a driveway fabbed AOL set-up w/Schrader valves.
Fronts were 15x6.5" Van Ralleys & 215/70-15 BFG's.
Rears were 15x8" Truck Ralleys & 255/70-15 BFG's.
Jonboy indicated it "rides really well". It did.... on smooth pavement. Not so much on the much more common asphalt patched roads. It definitely needed more suspension travel clearance as it bottomed out front & rear.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-28-2019, 11:30 PM   #70
zach_carver
zach_carver's Avatar
Mine is flipped rear, and like a 4" front drop. 20s with 255/40R20 and 295/40R20s now. I think my springs are weak because the rear flip really lowered it a lot. Lol
1965 C10 LS2/4l70, WHITE, 5/7 DROP
LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283
1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E
1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE
zach_carver is offline   Reply With Quote
Old 02-28-2019, 11:35 PM   #71
mongocanfly
Post Whore
mongocanfly's Avatar
Truck looks great Zach....
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 02-28-2019, 11:48 PM   #72
sweetk30
sweetk30's Avatar
my 80's 2wd c-10 5.3LS / 4l60-e / 3.73 rear / 2.5" drop front and rear . pics show it on half worn 31" tires . goin 29" tires when done on stock 15x8 stock rally wheels .
used a stock no tow hook hole 4x4 air dam to make it look lower on the front . we got pot holes up here so didnt want to low .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 03-01-2019, 12:25 PM   #73
skyphix
I like the stance and the AT's on a lowered truck at that height. Looks tough, nice stance too.
I feel your pain with the potholes, pretty sure you can disappear in them here in Maine. I threw caution to the wind and am going lower with mine in the front than it already is, and its pretty low as is... after some of the giant ridges I ran over in NJ, not much could be worse at least in the spring/summer/fall when I actually drive my truck. I never bottemed out anywhere, even on some really, really nasty country roads where I've actually accidentally lifted the front wheels of my 4runner driving on, except in NJ on my drive home.
Eric
1980 C10 SWB
2003 Chevy Suburban 2500 LT
skyphix is offline   Reply With Quote
Old 03-22-2020, 08:43 PM   #74
novajess1972
novajess1972's Avatar
My 85 with Belltech 4/6 with 3/4 of the front coils cut.
1985 SWB Silverado 1/2 Ton
1972 Chevy SWB 1/2 Ton (sold)
1972 Chevy Chevelle SS (sold)
1971 Chevy Nova (sold)
1967 Chevy El Camino (sold)
2001 Mustang Bullitt (sold)
2019 Toyota Tundra Crewmax (daily)
novajess1972 is offline   Reply With Quote
Old 03-23-2020, 09:55 AM   #75
Keith Seymore
Keith Seymore's Avatar
4/6, cut coils in front relocated spring hangers in back.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
73-87 chevy truck, dropped, lowering, slammed
