Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 09-14-2011, 02:42 PM   #51
DBear
DBear's Avatar
Re: 1970 Chevrolet Suburban: Project "Beach Wagon"
Thanks for the reply bud...I love the color you are going with....it is similiar to the color I would want on my Burb. Here is a pic of a 60's Burb with some kind of turquiose that I want on mine...
Oh, and I really wanted to know what size those tires that are on your burb in this thread? Your actual build pictures....Thanks again, and keep us updated with your progress!
DBear is offline   Reply With Quote
Old 10-19-2011, 09:40 AM   #52
Jesse@Bluskyclsccrs
Got some rrreally good progress goin on londoncallings burb! We decided to get the body all blocked out and painted. In doing this we can continue with the mechanical and electrical side of things and do the panels later so we dont risk chipping or scratching the doors fender hood because of the constant back and forth in and out of the truck.
So with that its painted! I have yet to get some pics of it cleared because we unfortunatly got hit with some rain today so we'll have to wait to see it all shiny and nice! Once it does come back I will get to sanding and buffing the quarters before the clear hardens up cause once it is it gets hard as a rock! (dupont keeps changing up the formulas on their 72200 clear).
The way I tackle my body work is I sand the entire panel and coat the whole thing in body filler. Its merely just a skim coat. This allows me to block down the entire panel to get it as straight as possible. (Especially with that 9'2" drivers side quarter panel! This is the longest panel I have ever done!) I start with 36 grit paper (basically dirt glued to paper) on a 18 inch long sanding board and go to town. That gets a "rough" cut going. I then get out my 36" long board out and block out the entire panel with 80 grit to get rid of the 36 grit scratches. This straightens out the panel even more since I'm using such a long block, the bigger the block the more area it can level at the same time. I finally reblock the entire panel with 180 grit sand paper to remove the 80 grit scratches. Once the entire panel is blocked out in 180 and there are no remaining low spots, (sometimes the entire panel needs to be coated several times but I lucked out getting it done in one) I mask out the panels and spray a polyester filler on the panel. This helps fill in and minut imperfections and pin holes left in the body filler and is an awesome product to block out perfectly straight with 180 grit once again and then following that with 320 and then prime the entire vehicle. Its a very very timely process but the outcome is outstanding.
I also did some surgery on the tailgate making one really nice tailgate out of two decent tail gates. The outer skin and inner structure of the replacement tailgate were in really good shape but the ribbed portion was all dented up but on his original everything was in opposite shape! So I cut the two apart and had my sand blaster blast the inside and out of the two peices and got the epoxied so there is very little chance of any serious rust coming through again. I then did body work on the seams and weld areas and inbetween the ribs and it is now looking brand new!
After I finish the lift gate I will move onto fixing the lift gate and move my way to the doors, fenders, hood, etc. and getting them in prime and ready for paint!
Heres some pics of the progress. This is of the truck in the filler prime I mentioned in the explanation of straightening the panels.
I didnt get many pictures of that cause there's really not much to see. These are a couple pictures of the truck masked up and primed.
Here is the progress on the tailgate. I tacked it together on a stand and then mocked it up to make sure it lined up well. It was way off so I was able to adjust it and continue welding. It fits exactly like it did before I cut it apart. I then did filler and body work to it to make the section line completely invisible. The inside is currently in final prime.
Here's the truck in the booth prepped and ready to go.
And some color pics. I will get pics of the body all shiny and painted once she can come out of the booth and not get soaked!!
Jesse@Bluskyclsccrs is offline   Reply With Quote
Old 10-19-2011, 09:43 AM   #53
67cheby
67cheby
67cheby's Avatar
WOW...it looks great
67cheby is offline   Reply With Quote
Old 10-19-2011, 12:19 PM   #54
VA72C10
VA72C10
VA72C10's Avatar
Looking GREAT!!!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 10-19-2011, 01:08 PM   #55
Jesse@Bluskyclsccrs
Got break in the weather so the Burb was able to get back to the shop and I started sanding the passengers side quarter to buff it!
all the minimal orange peel is eliminated. I will post pics once I'm done buffing this quarter this afternoon!
Old 10-19-2011, 03:08 PM   #56
VA72C10
VA72C10
VA72C10's Avatar
Looks great!
Old 10-19-2011, 03:16 PM   #57
Mt Man Chad
Mt Man Chad's Avatar
Very VERY NICE work!
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps.
68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread
Mt Man Chad is offline   Reply With Quote
Old 10-19-2011, 04:50 PM   #58
Jesse@Bluskyclsccrs
and a few more pics. I was able to get the quarters done today, jus gonna do the rear body panel tomorrow quick cause theres some dirt nibs in it so Im gonna take care of that.
Old 10-19-2011, 07:01 PM   #59
Mt Man Chad
What brand and type of paint are you shooting?
Old 10-20-2011, 08:33 AM   #60
Jesse@Bluskyclsccrs
Dupont Chroma Premier Sealer, Chromabase Base coat and Dupont Chromapremier 72200 Clear.
Old 10-20-2011, 08:35 PM   #61
DBear
DBear's Avatar
Damn....me and my Burb are really jealous! That is real nice work fellas.....did I say I was jealous?
Old 10-21-2011, 11:08 PM   #62
goldenburb
goldenburb's Avatar
Glad to see this moving forward. Nice work.
70 c10 2wd crashed Suburban
67 c10 2wd sb truck
67 c10 4wd lb truck
goldenburb is offline   Reply With Quote
Old 10-21-2011, 11:29 PM   #63
vectorit
What?
vectorit's Avatar
Diggin that old 4x4 burb!
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 10-22-2011, 12:39 AM   #64
DBear
DBear's Avatar
I know what you mean Chris....if I could have your burb, beezleburb's and that mid 60's burb in my driveway, life would be great! You got that new 70 swb now, so you really don't need your burb anymore right?
Old 12-14-2011, 03:34 AM   #65
The Frisian outlaw
Thumbs up Re: 1970 Chevrolet Suburban: Project "Beach Wagon"
A very nice fresh color! Amazing how you people take easely your whole suburban appart and build it up from A to Z. This burb will be in better shape than when it came from the factory.
I'm curious about the way you're gonna build up your interior. Are you using the same colours inside?
Nice work
The Frisian outlaw
The Frisian outlaw is offline   Reply With Quote
Old 01-14-2012, 10:34 AM   #66
Beautiful Jesse! How are things coming along ?
I own a 1970 3/4 ton 4X4 burb that is waiting (and needing) for my attention
Old 01-18-2012, 12:03 PM   #67
botmfedr1
botmfedr1's Avatar
Just looking at your build brings back many memories...I grew up in a paint shop. My old man painted cars for many years. I can still smell the paint and hear the air compressor in the background...
Great job...hopefully I will get my "68 50th ANNV and Suburban done like that!!
botmfedr1 is offline   Reply With Quote
Old 01-21-2012, 11:21 PM   #68
68 Four on the Floor
68 Four on the Floor's Avatar
Wow that Burb looks amazing. Good job
68 Four on the Floor is offline   Reply With Quote
Old 02-08-2012, 05:08 PM   #69
zellway
zellway's Avatar
This is going to be one clean ride!
Erik
My 69 suburban http://67-72chevytrucks.com/vboard/s...d.php?t=530626
1970 C10 step Project Jiminy http://67-72chevytrucks.com/vboard/s...d.php?t=682647
RUST!? Thats just mother natures way of telling all of us.....MINE!!!!
zellway is offline   Reply With Quote
Old 03-06-2012, 07:31 PM   #70
Updates? Hope things are going OK
Old 05-30-2012, 01:28 PM   #71
Artboy47
I hadn't been online in a while and I am sure you finished it by now. Can I see the final pictures.
thanks
Artboy
Mark Young
Bridgewater, Ma.
markyoung233@aol.com - I am still interested if you decide to sell someday. Hope all is well.
Artboy47 is offline   Reply With Quote
Old 07-24-2012, 07:36 AM   #72
Just checkin' in to see how the (very nice) project is coming along.
Old 12-01-2012, 01:45 PM   #73
Gobuffalo
Gobuffalo's Avatar
I love the color. It's looks like the original color of mine. Inside the glove box on the option sticker it says special paint.
I'm just getting started on the body and paint on mine. Already straightened the frame and got the power train sorted out. Winter has made things harder.
Power train:
496 big block, 9.5 to 1 Eagle rotating assembly, Edelbrock O-port heads, Comp hyd. roller cam. Built for torque, 575 lb. ft.
TH400, NP205, 14 bolt rear with 4.56's and a locker, Dana 60 front with 4.56's and a posi. It will pass almost anything except a gas station.
Here's some pics.
Gobuffalo is offline   Reply With Quote
Old 12-01-2012, 02:55 PM   #74
Gobuffalo
Gobuffalo's Avatar
More burb pics.
I got rid of the exposed filler. Got the fuel door off an early 90's Suburban. I had to modify the filler tube a little.
Old 11-15-2013, 11:01 PM   #75
ThreeQtr
Either of these suburbans near or complete.
Seems like all the Burb owners are disappearing.
ThreeQtr is offline   Reply With Quote
