Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 02-12-2013, 07:47 AM   #51
68_Shortbox
68_Shortbox's Avatar
Re: Project First Car '68 Shortbox Fleetside
We got the transmission installed the other night. We are replacing the gaskets that are leaking and then I will paint it. I plan on painting the transmission cast iron gray and the covers that are on the sides either silver or black. I will hopefully have some more pictures in the next few days.
Build thread for my SWB 4x4 http://67-72chevytrucks.com/vboard/s...d.php?t=447938
1968 Chevy K/10 short box fleetside (my project)
1969 Chevy Z/28 Camaro (my dad's project)
1968 Chevy C/20 long box fleetside (parts truck)
68_Shortbox is offline   Reply With Quote
Old 02-14-2013, 06:37 AM   #52
68_Shortbox
I got the transmission primed and painted tonight and I am pleased with the way it turned out. I am up for suggestions on what color I should paint the covers that go on the sides. I am leaning towards either black or silver.
Old 02-14-2013, 09:34 AM   #53
72LSK10
72LSK10's Avatar
Nice build, love the color of the tranny.
72LSK10 is offline   Reply With Quote
Old 02-15-2013, 03:52 AM   #54
68_Shortbox
Thanks! I was going to paint both the adapter and the transmission aluminum silver but I am really happy with the cast gray. The transfer case is going to be Chevy engine orange.
Old 04-04-2013, 02:48 AM   #55
68_Shortbox
The transfer case is installed and painted. We still have to replace the gaskets for all of the covers on the transfer case. I will also clean the paint off of the aluminum covers and shine them up a little bit. I also got the covers for the transmission painted. We took the rear brake drums off and the shoes don't look that good especially the passenger side (see picture). After we finish the transfer case the plan is to redo the rear brakes, put in new leaf spring bushings, and paint the axles and the rest of the frame. I also picked up a Holley 1850 on craigslist for a pretty decent price. The Holley needs a rebuild but I want to wait to do that once we get some of the other stuff done.
Old 04-11-2013, 05:14 AM   #56
68_Shortbox
The transfer case is all sealed up and looking new again!
Old 04-24-2013, 02:53 AM   #57
68_Shortbox
We got the rear axle dropped and the driver side leaf spring off and are working on getting the other side off. It took a sawzall, hacksaw, cutoff wheel, and a chisel to cut the old bolts off. I am hoping to get the firewall painted before we put the cab on and have been looking at paint colors. I am leaning towards going with lemans blue, fathom blue, or dark blue poly so that way I wouldn't have to recover my seats. I thought I would also share another picture of Willie the guard cat.
Old 05-02-2013, 01:46 AM   #58
68_Shortbox
We finally had a stretch of good weather so I decided to paint my alternator. We also got the passenger side rear leaf spring and shackle off. I have been cleaning up the rear axle and the rest of the frame trying to get it ready to paint. Hopefully I can get the rest of the frame painted soon so we can start putting the truck back together.
Old 05-06-2013, 11:05 PM   #59
MyDad'sTruck
COOL. Please tell me: what tranny was in it, what Tcase was in it? And what Tcase are your putting in it and what is that front end with discs from!??? Thanks!
MyDad'sTruck is offline   Reply With Quote
Old 05-07-2013, 02:59 AM   #60
68_Shortbox
It currently has a Muncie SM465 4-speed and a NP205 transfer-case. I believe from the factory it would of had a Rockwell T-221 transfer-case and the SM465 4-speed. The axles are out of a '72 K10 Suburban and are supposed to be 3.07's. The previous owner did the transfer-case and axle swap.
Old 06-28-2013, 07:21 PM   #61
68_Shortbox
I painted the frame, axle, and rear leaf springs last night with Chassis Saver. I will wait a day or two and then sand everything a little bit to smooth out the finish the best that I can and then I will top coat it with Eastwood Extreme Chassis Black aerosol paint.
Old 07-03-2013, 04:54 AM   #62
68_Shortbox
I got the axle, frame, and leaf springs top coated last night. I sanded everything with 400 grit before I sprayed it. I still have to paint the differential cover and some misc. parts and then we should be able to start assembling everything.
Old 07-11-2013, 09:47 PM   #63
68_Shortbox
We drilled the holes for the cross-members and decided it might be easier if we put the exhaust in now while the cross-members are still out. So with that being said I painted the exhaust and should be able to install it tomorrow and then we can get the cross-members back in.
Old 07-31-2013, 12:48 AM   #64
68_Shortbox
I put new rear leaf spring and shackle bushings in and bolted it all together. I used the polyurethane w/graphite kit from Energy Suspension. Four of the sleeves were too short so they had to send me longer ones to get the kit to fit. I also ordered their kit for the front and that is way out of whack. The entire front kit is not even close to being right. They sent us what they could to make it work and it still isn't right. I will give more details about the front kit once we start redoing the springs if anyone is interested.
Old 08-04-2013, 01:22 AM   #65
68_Shortbox
The rear axle is bolted back in place now. I bought new u bolts and I painted the differential cover and the u bolt mounting plates with Eastwood's detail gray.
Old 09-19-2013, 01:15 AM   #66
68_Shortbox
When I pulled the rear end cover off I checked the numbers on the gears to find out they are '73 3.07's. That led me to look at the front and rear axle housings and it turns out they are '73 axles. When I bought the truck the p.o. said he pulled them from a '72 Suburban.
Old 09-19-2013, 04:20 AM   #67
swamp rat
swamp rat's Avatar
Lookin good!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 09-19-2013, 05:48 PM   #68
68_Shortbox
Originally Posted by swamp rat View Post
Lookin good!
Thanks Swamp Rat! Its taking longer than it should but we are trying to at least get the cab swap done before the snow starts flying. Knowing Minnesota it could snow tomorrow haha!
Old 09-19-2013, 06:49 PM   #69
swamp rat
swamp rat's Avatar
At least you have a garage to work in!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 10-29-2013, 05:34 AM   #70
68_Shortbox
I cleaned and painted the drivers side drum the other day and then we put in new shoes and a spring kit. After it was all together we noticed that the parking brake lever was missing so we will have to take it apart again and find one to put in it. While we are searching for a lever we decided to start doing the passenger side. So far we got the passenger side apart and I painted the backing plate. I also got a pretty good deal on a set of slots a few weeks ago. The tires are shot but I have a set of 265/75's to put on them. I cleaned up two of the wheels so far and they appear to be in pretty good shape.
Old 10-29-2013, 07:03 PM   #71
rgunlock
rgunlock's Avatar
Nice build you and your dad are doing. A lot of attention to the details, many of them only you and your dad will even know about.
Rick
78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel
71 GMC C25 350/TH400 - Project Angie
59 Chevy SWB Stepside (next in line? Not sure now )
2001 GMC Sierra K2500
rgunlock is online now   Reply With Quote
Old 10-29-2013, 07:37 PM   #72
68_Shortbox
Thank you! I know most people won't even see any of it but I might as well clean and paint everything while we have it apart. Plus it should be a bit easier to take it apart if we ever have to again.
Old 10-30-2013, 07:55 PM   #73
Ol'Rover
Project: years too late.
Ol'Rover's Avatar
I am impressed, this thing is going to be cool when its done! keep up the good work!
ps. I like that idea with the engine hoist to lift the cab!
1971 C10 Stepper LSX 5.3/4L60E 3.73 12bolt posi. Father Son Project. In Memory of Bruce C. Shorten. Rest easy Dad. Ill take it fryom here.
Ol'Rover is offline   Reply With Quote
Old 10-31-2013, 02:53 AM   #74
68_Shortbox
Thanks Ol'Rover! The engine hoist definitely made the job easier on our backs!
Old 11-14-2013, 08:50 PM   #75
bhammer
Hey! Nice looking rebuild! I see you reused the original engine/motor mount crossmember. I am looking for one, the PO on my truck took it out to install a big ass 455 in the truck and I want to put am original 350 in it and have been having a hell of a time finding an original replacement. I sent you a PM but that we before I saw you had reused the original, sorry.
bhammer is offline   Reply With Quote
