Old 10-24-2011, 12:13 PM   #51
Conundrum
Conundrum's Avatar
Re: "Sin-thia" My 74 GMC
I don't remember how much it was, I may have it wrote down somewhere, i'll try and look tonight.
All I have done since I posted the last pics has been getting my other 2 tires mountes and modified another center cap. Don't have any pics yet.
74 GMC SWB Project "Sin-thia" Static Dropped 8"f/10"r
http://67-72chevytrucks.com/vboard/s...d.php?t=460030
97 GMC reg cab short bed, 4.3V6 / 5spd, daily driver
220,000 miles, all stock for now
Conundrum is offline   Reply With Quote
Old 10-24-2011, 04:53 PM   #52
jcspaek009
jcspaek009's Avatar
well its looking pretty epic so far man, you have put in alot of work in the truck from where it started from, but that is the name of the game right. i cant wait to cut the frame this week, how did the box holes line up after?
jcspaek009 is offline   Reply With Quote
Old 10-26-2011, 09:45 AM   #53
rs72z
rs72z's Avatar
I have seen in a few other articles on frame shortening that says you have to cut 6" off the rear of the frame also. Did you do this too?
I am picking up a 78 cc this weekend that i am going to shorten. Thanks ahead of time for the info.
rs72z is offline   Reply With Quote
Old 10-26-2011, 10:10 AM   #54
Conundrum
Conundrum's Avatar
I have read that as well, but my frame was already cut off at the rear due to the dump setup so i'll actually have to add a couple inches to mine.
Old 10-26-2011, 10:16 AM   #55
rs72z
rs72z's Avatar
Ok. thanks
Old 10-26-2011, 11:15 AM   #56
jcspaek009
jcspaek009's Avatar
so is it forsure that 6 inch's has to come off the rear? how many bolts hold on a short box to a frame, hey rs72z would you happen to have a link to the article for shorting frames
1950 Chevy 1/2 ton short box
1975 C10 project
2006 Nissan Titan
2007 Saturn Outlook
2008 Yz250f
Old 10-26-2011, 11:19 AM   #57
rs72z
rs72z's Avatar
It's on my home computer. I will post a link tonight.
The way it's done in this post is the best way i think to do the front.
The other article says to remove the rear sill crossmember and cut 6" off and bolt the crossmember back in using factory holes.
Old 10-26-2011, 11:33 AM   #58
jcspaek009
jcspaek009's Avatar
ok sounds wicked, just a side note make sure when you cut the frame you wheel base is 117.5''(2985mm)
so i will wait to read your post before i start cut more on the frame
1975 C10 project
2006 Nissan Titan
2007 Saturn Outlook
2008 Yz250f
Old 10-26-2011, 12:09 PM   #59
rs72z
rs72z's Avatar
Found it, not near as good as this one though, except for the mention of the rear portion.
http://73-87.com/7387garage/chassis_...lwb_to_swb.htm
Old 10-26-2011, 12:37 PM   #60
Corts60
Just here to tinker
Corts60's Avatar
Great work man! I love the look of this truck.
Old 10-26-2011, 07:52 PM   #61
Conundrum
Conundrum's Avatar
There are 8 bolts holding the short beds on as well.
Thanks.
Old 10-26-2011, 10:02 PM   #62
jcspaek009
jcspaek009's Avatar
Are you sure about the 8 bolts conundrum cuz I looked at a short box today and I only seen 4, 2 near the front of the box and 2 right at the end. I might be wrong but that all I seen on this truck, and the guy said it totally original.I have been wrong before. Lol
1975 C10 project
2006 Nissan Titan
2007 Saturn Outlook
2008 Yz250f
Old 10-26-2011, 10:12 PM   #63
Conundrum
Conundrum's Avatar
Mine takes 8
Old 10-26-2011, 10:26 PM   #64
rs72z
rs72z's Avatar
He's right on the 8 bolts, just looked at my 87 scsb. 2 at the front and 2 at the rear.
Old 10-27-2011, 05:44 PM   #65
Conundrum
Conundrum's Avatar
It's not much, but I did something.
Cut the 2 pieces off the frame for radiator/support clearance and seen I also have to clearance the radiator support to clear the steering box as well....
Luckily this radiator support isn't much good so it'll allow me to get the clearance I need and then I can figure out how to do my good one so it looks good.
Also got some more pics of the truck....
I think it may be the angle, but I really like the second pic of the truck.
Old 10-27-2011, 07:02 PM   #66
mcboomport
mcboomport's Avatar
Nice dude! I'm digging those wheels!
mcboomport is offline   Reply With Quote
Old 10-27-2011, 07:23 PM   #67
jcspaek009
jcspaek009's Avatar
Looking pimp bro. It sure is coming along.
1975 C10 project
2006 Nissan Titan
2007 Saturn Outlook
2008 Yz250f
Old 11-09-2011, 02:06 PM   #68
jcspaek009
jcspaek009's Avatar
Any thing new going on with your truck? Just pick up a box for mine and all the measurement turned out awesome, only 4 out of the 8 bed bolts lined up.no big deal to drill 4 new holes tho.
1975 C10 project
2006 Nissan Titan
2007 Saturn Outlook
2008 Yz250f
Old 11-09-2011, 07:02 PM   #69
Conundrum
Conundrum's Avatar
No not recently, haven't had much time.
Glad to hear yours is coming along.
Old 11-09-2011, 09:48 PM   #70
jcspaek009
jcspaek009's Avatar
ya its coming slowly, haha, just need to find a motor and tranny for it, thinking of a 350 for now with a turbo 400 behind it, what are you running in your c10? would you know how low i can go with my c10? i was hoping for a 5/7 drop but i heard that the lower control arms would rub on a stock 15" rim. its not a daily driver so i want it as low as possible.
1975 C10 project
2006 Nissan Titan
2007 Saturn Outlook
2008 Yz250f
Old 11-09-2011, 10:15 PM   #71
Conundrum
Conundrum's Avatar
I currently have a Pontiac 400, i'd like to find a 455, it currently has a turbo 350 bolted toit but if I run an auto i'll probably use the 2004R I have. I'd really like to run a manual trans, maybe a 6spd but that'll have to wait.
As far as how low you can go all depends on how low you want to go and the amount of work you're willing to do. So far the math on the amount of drop in the front of mine is 8". As far as a stock wheel rubbing will depend on backspacing with a 2.5" drop spindle, mine just barely touched in a couple places with a 15x8 rally so it wouldn't take much to get the needed clearance. If you use a 3" spindle, your backspacing is more important.
Old 11-16-2011, 11:01 PM   #72
Conundrum
Conundrum's Avatar
Thanks guys.
I'm hoping to have another update soon, although it may only be a small one. With it getting colder outside, I have been spending a lot of time thinking about what I want to do to it. So far I have decided to do a manual trans, 4, 5 or 6spd all depends on what I get my hands on. Although if I do a 6spd i'll need to ditch the 3.08s that are in that rearend for sure. And i'm considering swapping out the leaf springs for some truck arms, if I go with the arms I can get all that stuff for free from my dad.
Old 11-28-2011, 10:57 PM   #73
Conundrum
Conundrum's Avatar
I got a little done over the weekend, I trimmed the radiator support to fit around the steering box, put the drivers fender on, set the hood on and put my grille and headlight bezels back on. Pulled my bed off and removed the bumpstops, then put the bed back on. I'll post some pics in the next day or 2.
Old 12-12-2011, 07:48 PM   #74
Conundrum
Conundrum's Avatar
I'm a little behind on my update LOL
Here are some pics from yesterday.....
And this one shows the bumper I picked up the previous weekend for $10, it had never been mounted but it is a foreign repop so it's got some rust on the top side that's pretty rough. But I have plans for it then it'll get powder coated either black, silver or white, I haven't decided just yet.....
But this may be the last update til spring, with no heat in the garage it's a little hard to work on the truck.
Old 12-12-2011, 08:34 PM   #75
franky69c10
chevy runs deep
franky69c10's Avatar
nice
RAIDER NATION
1969 c10 swb soon 2 b on the road...
My LWB is a SWB now
http://67-72chevytrucks.com/vboard/s...d.php?t=498241
franky69c10 is offline   Reply With Quote
