Old 09-26-2011, 08:07 PM   #51
65Gregg
65Gregg's Avatar
Re: 63-72 Chevy P/U Rear Shock Mount System
Rob is there a reference point to measure from for the frames that don't have the 5/8 hole you had in the frame on the shop truck? I noticed Andy said his didn't have one. I have a hole in mine but I'm not sure it is the correct one. In the case of there not being a hole is there a a specific angle the shocks should be mounted at to have proper action? I have be told that Monroe shocks don't perform well at an angle in excess of 30 degrees, apparently the valveing is affected. You thoughts are appreciated.
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline   Reply With Quote
Old 09-27-2011, 01:46 PM   #52
robnolimit
robnolimit's Avatar
The rear specs I have are as follows. From the rear tip of the frame to the rear axle centerline is 34". From the rear tip of the frame to the center of the 5/8" hole is 17 1/2". So, from the axle centerline back to the center of th 5/8" hole is 16 1/2". The first two numbers are for shortbeds. The third measurement, 16 1/2", is good for any truck.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 09-27-2011, 02:30 PM   #53
kieth
kieth's Avatar
Originally Posted by robnolimit View Post
Please refer to the last picture of the instructions
How thick is the spacer block on the trailing arm ? about 1.5" ? and was this done so you did not have to raise the bracket on the crossmember or just for travel clearance on the trailing arm when it was lowered ? thanks, Kieth
kieth is offline   Reply With Quote
Old 09-27-2011, 03:39 PM   #54
robnolimit
robnolimit's Avatar
I think you are refering to the lowering block. It is 2" thick, although they are avail. in 1/2", 1", 1 1/2" also. I like to use a block for the firt 2" of lowering, this aproach keeps the spring as long as possible for a better ride.
Old 09-28-2011, 02:56 PM   #55
kieth
kieth's Avatar
what about the brackets on the crossmember for the trailing arms, should we still raise them up ?
Old 09-28-2011, 06:59 PM   #56
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: 63-72 Chevy P/U Rear Shock Mount System
Got the shocks truned around and glad I went back under there. I had left the top shock bolts loose for some unknow reason.
Camera died I post pictures once it charged up again.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 09-29-2011, 02:32 AM   #57
robnolimit
robnolimit's Avatar
Yes, I would still move them up, and/or flip them.
Old 09-29-2011, 05:07 PM   #58
kieth
kieth's Avatar
Thanks Rob, I am in the process of doing this as we speak, will use the 2x2 block, am getting ready to order your shock relocator kit, and at the same time we are moving the rear axle back 1.5" and adding a cpp notch kit. Busy Busy
I would order your fatboy panhard rod but cannot afford it right now. may add it later. We are also slamming a 65 LWB Fleetside so too many irons in the fire.
Thanks again , Kieth
Old 09-29-2011, 05:14 PM   #59
Andy4639
Old member
Andy4639's Avatar
Cool Re: 63-72 Chevy P/U Rear Shock Mount System
Got the shocks redone. Here are the pictures of the passenger side.
I took this one looking through the wheel.
Old 09-29-2011, 06:04 PM   #60
robnolimit
robnolimit's Avatar
Looks good now Andy. Have you drivin it yet?
Old 09-29-2011, 06:40 PM   #61
Andy4639
Old member
Andy4639's Avatar
Just went a short trip and it seems to be a smoother ride. Had to cross over some R/R tracks and it seemed to be a lot smoother!
Old 10-01-2011, 01:28 PM   #62
Andy4639
Old member
Andy4639's Avatar
Drove the truck about 60 miles today and it rode great. Back roads and interstate both.
Old 10-06-2011, 11:25 AM   #63
robnolimit
robnolimit's Avatar
Andy Glad to hear it. The feedback is great. With your comments and postings, we updated the instructions with more pictures and dimensions. Sometimes we see things differently as we were the ones that built the parts. These updates will help everyone, so thanks. Glad to hear the truck rides and handles better, we knew it would. I've been in S.C. in the fall when the leaves are changing, good time for a cruise and some fun. Thanks again, Rob
Old 10-06-2011, 02:54 PM   #64
volleyballer13
volleyballer13's Avatar
Hey Rob,
Just wondering if the rear shock mount system would work on a square body that has been converted to trailing arm rear suspension? I would love to use this kit on my truck. Thanks in advance.
Russell
volleyballer13 is offline   Reply With Quote
Old 10-06-2011, 03:20 PM   #65
robnolimit
robnolimit's Avatar
Not sure about that. the 73-87 frame is a little narrower than the 63-72, but not much. I haven't tried this yet.
Old 10-06-2011, 04:19 PM   #66
Andy4639
Old member
Andy4639's Avatar
Your welcome.
Yea from the last few times I have drove it I can tell it's a lot softer ride. It's not Harsh like before if the rear end hit bad bumps in the road. Thanks again, great product.
Old 10-07-2011, 11:50 AM   #67
k2rm
k2rm's Avatar
Is there any benefit for stock height trucks? I have a 70 C20 who's serious hauling days are over. I am trying to figure out the best way to improve the ride.
k2rm is offline   Reply With Quote
Old 10-07-2011, 11:56 AM   #68
Andy4639
Old member
Andy4639's Avatar
Question Re: 63-72 Chevy P/U Rear Shock Mount System
Try and find a stock height spring that is softer. (Spring Weight)That is the only thing unless you lower it.
Old 10-13-2011, 11:24 AM   #69
robnolimit
robnolimit's Avatar
Lately I have recieved several messages asking if there is a larger discount on these parts. For the short answer, no. Forum members already recieve a 10% discount. It is unfair then, to offer a lower price to some as others have already paid the advertised price. In the big picture, it is to no ones benefit that we sell parts at a loss. - Then we would go out of business, and not be able to help further the hobby. How often do you ask for a better deal at your favorate resteraunt? or at Sears? We are a 'real' business, not a swap meet. I understand the current economy as well as anyone, but if you want well made, American made parts, there is a price. I am sure that some of our competitors will copy these mounts and have them made in china soon enough, then you can get the low price that you want. Have a great day, buy American.
Old 10-13-2011, 11:53 AM   #70
BustedTruck
BustedTruck's Avatar
I ordered mine yesterday. I dont mind paying a little more to insure I get quality parts. Thanks Rob. I will be ordering sway bars as soon as their available.
BustedTruck is offline   Reply With Quote
Old 10-13-2011, 11:56 AM   #71
NPilot1975
NPilot1975's Avatar
Well stated, nothing makes me madder than people complaining about the state of the US economy as they drive around in some sort of foreign car, buying everything from china for the cheap price. I love to buy American whenever possible even if it costs a little more.
1972 Blazer body...need to get a thread started for the rest of the story
NPilot1975 is offline   Reply With Quote
Old 10-13-2011, 12:45 PM   #72
OJ1988
Just a car guy
OJ1988's Avatar
I feel you. It seems any business thats related to a 'hobby' gets treated that way.
Everyone wants a "deal", the deal is your getting better made, american made stuff!
1955 belair Blown Pro Street cruiser
1971 Camaro Pro Touring
1973 Vega Drag Car
1970 C20 tow rig
OJ1988 is offline   Reply With Quote
Old 10-13-2011, 06:39 PM   #73
65Gregg
65Gregg's Avatar
Rob I ordered my relocation kit Monday, can't wait for it to arrive. When I install everything which includes shocks, relocation kit, 2 in blocks and 3 in springs should I flip the trailing arm mounts to correct any pinion angle issues? Will it benefit me in any way?
65Gregg
Blue long bed
White TBSS
61 Impala
Old 10-13-2011, 07:34 PM   #74
robnolimit
robnolimit's Avatar
I would. I know it's a pain to get the rivits out, but if your under there doin' it, you may as well git 'er done. You'll be happy in the long run. Thanks for the order. Happy cruisin.
Old 10-23-2011, 09:02 PM   #75
65Gregg
65Gregg's Avatar
Rob I got my relocation kit installed, great stuff. While I was under my truck admiring your parts and my labor a thought crossed my mind. I'm sure you get enough of the arm chair engineers and our ideas but here goes anyway. What would happen if you made the lower shock brackets "flipped" over to reduce scrub line issues? Most of your design work is done it would mean extending the shock mount hole out to clear the trailing arm and if it was just a little wider the part that currently hangs down would be flush up against the lower edge of the trailing arm. Let me know what you think.
65Gregg
Blue long bed
White TBSS
61 Impala
