Old 12-31-2012, 08:40 PM   #51
Johnnyfever
Re: 1970 Project Build
It's being bored .060 over as we speak
Johnnyfever is offline   Reply With Quote
Old 01-13-2013, 12:57 AM   #52
Johnnyfever
So I stripped the interior and removed all of the glass. I was surprised to find such little rust underneath the window seal. I did have a rusted out place on the driver side outside lower window sill and at the top of the windshield above the steering wheel.
Old 01-13-2013, 12:58 AM   #53
Johnnyfever
Patched those up.
Old 01-13-2013, 01:01 AM   #54
Johnnyfever
Picked up my parts from the sand/media blaster. Looks like more pin holes to repair. Hood, doors, cowl, and doors are pretty solid and ready for SPI, but the fenders and bed sides need tons of attention.
Old 01-20-2013, 10:19 PM   #55
Johnnyfever
I used the back portion of an old fender to patch my bedsides today. I ordered the patch panels from one of the manufacturers. You almost couldn't tell what the parts were for they were so poorly made. The groove around the wheel well brow wasn't even stamped into the part. I ended up using an old lower rear portion of a fender to do the patch and I would recommend that anyone who needs just a small portion of the bed patched behind the back wheel to order the lower rear portion of the fender. It actually has all of the correct stamping.
Old 01-21-2013, 07:44 PM   #56
Johnnyfever
The weekend update. I shot a little SPI epoxy primer this weekend.
Old 01-23-2013, 12:16 AM   #57
67c10rustbuket
67c10rustbuket's Avatar
Those blasted and primed parts look great! You're getting ahead of me now.
It looks like you must be using flux core wire with your welder. Once you upgrade to true mig gas you will wonder why you ever tried to weld sheet metal with flux core. It is so much easier!!
I have the same exact rust that you repaired on the bottom driverside windshield opening. That is going to be a fun one when I get back on my rusty cab.
Keep it up man, great job
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 02-03-2013, 02:41 AM   #58
Johnnyfever
yes, it was a metal brake project. good luck with yours. I know the area where you bought your truck and it's a pretty corrosive place.
Old 02-03-2013, 02:49 AM   #59
Johnnyfever
This weekend I had to repair a spot that was hiding from me. Not sure how I overlooked it but it was not a fun one.
Old 02-03-2013, 02:53 AM   #60
Johnnyfever
I replaced my door hinge pins (suprisingly easy) so I could align the drivers door. And then I moved on to finish the epoxy primer from Southern Polyurethanes, good stuff. I have the turbo 2K ready to go on in black.
Old 02-03-2013, 03:24 AM   #61
67c10rustbuket
I have a press brake at work, and many other sheetmetal fab tools so no prob there other than the curve. That will be a pain!
Man you are kicking that trucks butt now! The welds look much better, have ar/co2 now? The previous looked to have the old flux core white ash on the welds. I have to do the same on mine in the cowl area, well maybe a little smaller just the outer skin. I cut a section out then decided I had to do it all right and switched from "fix rust/install drivetrain" to full on frame off resto. The cab is looking great in primer, congrats you have passed a big milestone on this truck defeating the rust!
Dan <---(my name)
Old 02-03-2013, 04:35 AM   #62
Johnnyfever
Actually I was out of argon at one point and around here you can't get argon on sat and sun so I switched to flux core to get some headway. Gotta work with whatcha got sometimes.
Old 02-04-2013, 10:37 AM   #63
Johnnyfever
And I painted a few more parts with epoxy. My dad snuck in a few '51 parts for the shoot. Next is to assemble the whole truck and get the Rage Gold filler applied.
Old 02-05-2013, 10:47 AM   #64
Johnnyfever
Dan, watch out for that small rust on the outer skin. I had the same thing on mine and when I opened it up the entire vent area and lower inner portion was completely rusted out. Thought it was a 45 minute repair that turned into a half day.
Old 02-05-2013, 02:11 PM   #65
Low Elco
Also, check the cowl under the dash where the sheets lap together. Down inside the cowl box bottom. I also welded the seams going into the windshield solid to try to prevent leaks. Cool project! Keep it up!
Johnny Fever, awesome. I wanted to be Andy Travis when I grew up. And, while Jennifer is awesome and all that, I still want summa dat Bailey. Yum yum!
Oh yeah, if you have Tractor Supply near, lots of them carry welding gas. Just did all of mine there.
Low Elco is offline   Reply With Quote
Old 02-16-2013, 12:49 AM   #66
Johnnyfever
Put a little RAGE GOLD on today. Hard to believe it was so nice outside today and it's supposed to be a high of 37 tomorrow.
Old 02-16-2013, 12:29 PM   #67
67cheby
67cheby
67cheby's Avatar
man, you are moving quick, nice progress !
67cheby is offline   Reply With Quote
Old 03-04-2013, 07:27 PM   #68
Johnnyfever
Only did a few things to the C10 this weekend. A little body work. I had to rush up to Durham for an emergency and I made sure to show my grandpa the truck progress on my iPad while I was up there. Hopefully he enjoyed it. I still hope to have it finished for the Father's Day car show. Well maybe not 100% finished, it's going to be driven there in whatever condition it might be.
Old 03-30-2013, 12:02 AM   #69
Johnnyfever
Changed out the passenger door hinge pins. Picked up door weather stripping off of a 1995 S-10 just for kicks and it fits and seals pretty well. I may be using it instead of soffseal...expensive stuff. And more rage gold and more hand sanding. Tomorrow I plan on shooting everything with Turbo 2K in black.
Old 03-30-2013, 03:44 PM   #70
Johnnyfever
Anyone out there work all night long making sure that their doors and all other body panels on their truck are perfect? Then wake up in the morning excited to put a coat of primer on the entire truck, but before you get to that you RUN OVER THE PASSENGER DOOR? I had to take a break from the truck for a few hours.
Old 04-13-2013, 09:38 AM   #71
Johnnyfever
I spent 3 days at the Charlotte Auto Fair last weekend and I think I walked 400 miles. I posted a few pics in my gallery section. I'll add a few more later. Anyone else out there attend? Now I have to repair the door that I ran over.
Old 04-13-2013, 09:43 AM   #72
Johnnyfever
Now it's on to the repairs. I had a door in pretty bad shape that I used as a donor. I had to modify things a little to make the 70 door work with the 72 hole for mounting the vent window - not too difficult. I spent too much time since I was extra tedious to make the fit as tight as possible. Moral of this story is "DON'T RUN OVER YOUR DOORS"!
Old 04-13-2013, 09:45 AM   #73
Johnnyfever
And here is the final fit....no more crushed door. I'll have it tacked in, filled, and hopefully the whole truck covered in 2K by midnight.
Old 04-26-2013, 06:54 PM   #74
Johnnyfever
I used my Eastwood self leveling seam sealer today. Great product, but very messy. Then I finished up all of the filler work to get the body as smoothed out as possible. Hopefully I'll have the 2K turbo primer on tonight since it's raining tomorrow.
Old 04-27-2013, 12:30 AM   #75
Mustard72
Mustard72's Avatar
Note to self:
Don't run over door.
Priceless. Not everyone would admit to doing that.
Nice work, Johnny. I'm in the market for some seam sealer, too. Glad to see you liked the Eastwood stuff.
Those are repop fenders, aren't they? Do they fit OK? I've heard bad things about them at times. Yours look good, though.
Nick
Old Mustard, 1972 Chevy C20, 350, TH350, 4.10 Dana 60 rear, owned since I was 16 in 1986
http://67-72chevytrucks.com/vboard/s...d.php?t=545356
Blue Bell, 1987 K20, 6.2L Diesel, TH400/NP208, 4.10 gears
Ustahav 1976 K10, 350/350/203, Gov Loc, Yooper beater trail truck.
Mustard72 is offline   Reply With Quote
