Old 12-26-2011, 01:43 AM   #51
Devillusion
Devillusion's Avatar
Re: "Brown Truck" 1984 K30 Crew Cab
How is the interior holding up so far?
1967 K30 4x4/12v Cummins/getrag/D60/D70/355s
1967 GMC suburban 4x4/LS swap 5.3/4500/205/10 bolt/14 bolt full floater
1963 C10 reg cab long box
1970 Chevelle
1968 Biscayne 2dr post
"...there is no excuse for what I am about to do, but dangit....it's gonna be fun!"
Devillusion is offline   Reply With Quote
Old 12-26-2011, 01:58 AM   #52
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
The truck looks nice without the moulding, but that tip is too dang small!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 12-26-2011, 10:23 AM   #53
yousesteers
Interior is holding up good does not seem to scratch to easy
Clint Youse
Paris, MO
1984 Chevrolet 3+3 K30 with Cummins
1966 IH Scout has been a work in progress for 16 yrs
yousesteers is offline   Reply With Quote
Old 01-20-2012, 10:48 PM   #54
yousesteers
I have not got anything done in a month on this truck, parts are still sitting on the floor just minor stuff to put on but we are busy at work may be a month before I get anything else done we did get a really nice long bed 2wd on a consignment auction we are having. I have not even been driving the truck to work just take my John Deere Gator it is only a mile i hate to start the diesel in the cold to drive a mile.
Clint Youse
Paris, MO
Old 01-21-2012, 12:23 AM   #55
Dieselwrencher
That's crazy, a mile to work? Yeah, it would take more fuel to warm it up than to get to work for sure!
Ryan
Old 02-28-2012, 11:33 AM   #56
87chevy305
Question on fuel swap from gas to diesel , what did you do with the pumps that where in the tank? Did you leave them in pull em out? Please go into details on what you did with the fuel system . I'm currentlydoingthe same swap and need some help here . Thanks
87chevy305 is offline   Reply With Quote
Old 02-28-2012, 04:32 PM   #57
Dieselwrencher
I remove them and install a draw straw to feed the factory lift pump or after market fuel system. I leave the factiry sending unit so the stock fuel gauge will operate normally.
Ryan
Old 02-28-2012, 05:26 PM   #58
87chevy305
Thank you for the quick response!! Do you remember where you got the Draw straw from ?
Old 02-28-2012, 05:33 PM   #59
Dieselwrencher
I can get them from a few places for you. Or you can build your own from steel tubing like brake line and fuel line.
Ryan
Old 02-28-2012, 11:15 PM   #60
yousesteers
Mine only had Straws (no in tank pump) with the sock on the end I had removed the sock when it was a gas truck so I just put line from the factory steel lines to the lift pump on the cummins some time I want to redo all of it and run it straight up the driverside but I was on a real time constraint at the time so took the easy route
Clint Youse
Paris, MO
Old 03-02-2012, 04:05 AM   #61
snm95ls
Love it!
What size tires are you running in the last pic you posted?
snm95ls is offline   Reply With Quote
Old 03-02-2012, 12:38 PM   #62
yousesteers
Originally Posted by snm95ls View Post
Love it!
Those are 265/75/16 when I put new ones on may jump up a size.
Clint Youse
Paris, MO
Old 04-08-2012, 09:36 PM   #63
yousesteers
Took the truck on its first long trip about 220 miles round trip took an empty trailer one way and got a load of machinery. It ran great and made it ok I still need a second overdrive I could run about 65 to 70mph on I-70 just kinda fell in with the governed semis and stayed there. I have added a couple small things to the truck like a coolant over flow and just odds and ends nothing major.
Does any body have a source for factory front leaf springs checked Rock Auto they offer a 3 leaf pack mine has 4. Local auto parts stores can only get lift springs.
Clint Youse
Paris, MO
Old 04-09-2012, 12:20 AM   #64
joe231
joe231's Avatar
What gears in the diffs?
Was that 70mph loaded?
CHEVY ONLY
Old 04-09-2012, 09:02 AM   #65
yousesteers
It has 4:56 gears in it. does not matter 70mph loaded or empty any more and it just pushes to many RPMs. I want to put a gear vendors in to give a second overdrive this should make it cruise pretty comfortable at 80mph or so and not push a great amount of RPMs yet retain my lower gears for in town or larger loads.
Clint Youse
Paris, MO
Old 04-09-2012, 09:30 AM   #66
crewcabsquared
My 86 K30 crew had 3 leafs in the front from the factory, but there were many different spring combos used on these 1 tons. Are yours bad, you need replacements? I have my original springs that are in good shape if you just need some replacements. I put lift springs under mine. If so let me know.
Steve
crewcabsquared is offline   Reply With Quote
Old 04-09-2012, 04:31 PM   #67
Dieselwrencher
Check out Husky spring. They offer 3 and 4 leaf springs. I'd either re gear your axles or lift your truck a little and put a taller tire on. Those over drives are pricey. They are nice, but re gearing would be cheaper for sure. Just to give you an idea, my 95 F-350 has a VE 12v in it. It has 3:55's and 285's. It has a ZF5 ford trans which 5th is an over drive. It gets 21mpg hwy and 17-18 every day driving back and forth to work. I drive from 25-75mph most days. A Gear Vendors was like $3500 for a dodge cummins last I checked. You can buy a nice set of gears and a posi for the rear and front and have some left over.
Ryan
Old 04-09-2012, 09:18 PM   #68
yousesteers
My springs are shot they were before I put the cummins in the bushings are gone and the springs sag pretty bad I am just gonna put a new 4 leaf pack on. I checked into the Gear Vendors it was gonna run about $2500 to go on the 205 transfer case. $2500 is most of the reason I have not done it yet. I am getting good fuel milage I just want a little more speed for the interstate driving. I dont drive my truck every day some times not even every week it is my only vehicle but it is only 1 mile to work on gravel road so I just take our John Deere Gator. Most of the time when I drive it it stays with in 15 miles of home but there are those times I go on a long trip to pick something up.
Clint Youse
Paris, MO
Old 04-09-2012, 10:35 PM   #69
Dieselwrencher
Nothing else look around for a mud bog guy or a rock crawler who wants 4:56 axles and swap them.
Ryan
Old 04-10-2012, 12:33 AM   #70
gvchevy
Try Al Scheppers Motor Company in Jefferson City Mo. best source for local, the last set I bought was the best price around they also sell replacement leafs if you just want to rebuild. They also have a press to bend new u-bolts I hope this helps.
gvchevy is offline   Reply With Quote
Old 04-11-2012, 04:32 AM   #71
JPalmer81
JPalmer81's Avatar
Good lookin truck. My old boss had property right outside of paris that i went deer hunting on every year. Thinkin about putting the NV4500 in my truck, doing some research on it now. Good job on the build so far, needs about a 2.5-4 lift IMO, but that is just me. So what is nect on the list?
1988 Chevy Crew Cab 1ton 4x4 SRW LWB
1977 Dodge 1 ton 4x4
My Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=516872
"The price of Freedom is Eternal Vigilance"
JPalmer81 is offline   Reply With Quote
Old 04-11-2012, 10:42 AM   #72
nekkidhillbilly
4:56 is a little deep actually most diesel trucks are running 3:73 gears and can pull 18k
nekkidhillbilly is offline   Reply With Quote
Old 04-13-2012, 09:26 PM   #73
yousesteers
I knew the 4.56 were too low when i put the motor in. I just flat ran out of time on the engine swap so once it was running and moving down the road I drove it the plan at that time was to swap gears the truck the motor and trans came out of had 3.42 I was going to put in 3.73 but have not ordered the gears so have been thinking about a way to split what I got. The truck most generally does not go over 30 miles from home and probably has a trailer on 50% of the time (moving machinery and cattle).
As far as what is next I am have a few things.
small stuff I want to change with the motor swap
electric fan controllers
clean the wiring up
fix windshield wipers
new front leaf springs
finish the interior
little more sound deadening
head liner
sound system
Paint going to have the local Vo tech school paint it some time next school year if funds allow
Clint Youse
Paris, MO
Last edited by yousesteers; 04-13-2012 at 09:32 PM. Reason: posted before i was done
Old 10-28-2012, 09:19 PM   #74
yousesteers
I have put a little under 10,000 miles on the truck since the swap. I replaced the radiator in it a couple of weeks ago mine started leaking. It was the original 4 core radiator and I think the Cummins ended up just shaking it apart. I have not really got anything else done on the truck. Bought a new farm/house and have spent every free minute doing stuff to it. That and the new place has no shop at all just a small 1 car garage the the mirrors on the truck have to be folded in to get it in and then just the hood and half the cab will fit so if I do anything either do it in drive way or go to dad's shop. not much of an update but all I got for now. truck will get driven until I get a shop built then will go back to working on it.
Clint Youse
Paris, MO
Old 05-02-2014, 02:58 AM   #75
Truck Guy99
About how much did it cost you for the swap? Would you mind doing a cost breakdown?
My names Tye. No Chevy right now
Truck Guy99 is offline   Reply With Quote
