Old 01-08-2012, 01:16 AM   #51
Mr. 250r
Mr. 250r's Avatar
Re: My swap. 5.3 into a 1990 3/4 ton 4x4 Suburban.
I don't think anybody has a good solution for ls 4wd swap headers i think my4by2 had some lucky with i think... trailblazer headers with slight fitment issues he's went through a few headers trying to get the right ones not 100% what though
And its probably easiest to use the tranny that goes with the motor as far as wiring goes but thats my opinion ill be using a 1991 4l80e and swapping out the plug from a new 4l80e so the wiring is the same and my 6.0 is on the way so im watching this thread since its a near mirror image of my build =-p
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 01-08-2012, 04:00 PM   #52
y5mgisi
Second Chance Program
y5mgisi's Avatar
Not a whole lot of excitiment as work has slowed significantly sense i had to go back to work... But the other day i did get the starter installed and ran the battery cables. Now i just gotta swap out the fuel pump, adapt the exhaust, and get o2 sensors and i should be at least ready for a test fire.
y5mgisi is offline   Reply With Quote
Old 01-11-2012, 03:52 PM   #53
y5mgisi
y5mgisi's Avatar
Little bit of progress. Cut the fuel pump access panel so i never have to worry about dropping the tank again! And so i could change out the fuel pump to the high pressure unit.
Old 01-11-2012, 09:58 PM   #54
85burb
85burb's Avatar
shon has a thread on ls swap area called gauging intersest that he says dougs now makes headers for us.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 01-11-2012, 11:44 PM   #55
y5mgisi
y5mgisi's Avatar
Going to go check that out right now.
Old 01-18-2012, 11:48 AM   #56
jkade
jkade's Avatar
You can make Mac Mid Length for a fbody work, that is what I have on my K5. Also a set of Sanderson S10 LS/swap headers fit great as well. I have a set of Mac's I need to get rid of for $200 shipped if someone needs them.
jkade is offline   Reply With Quote
Old 01-22-2012, 03:46 AM   #57
y5mgisi
y5mgisi's Avatar
ITS ALIVE!!!
Im the one filming in both videos. Only about 8" of exhaust past the manifolds so its loud.
http://www.youtube.com/watch?v=fxr9Y...layer_embedded
http://www.youtube.com/watch?v=gEEzA...layer_embedded
Old 01-25-2012, 02:09 AM   #58
franky69c10
chevy runs deep
franky69c10's Avatar
Nice
RAIDER NATION
1969 c10 swb soon 2 b on the road...
My LWB is a SWB now
http://67-72chevytrucks.com/vboard/s...d.php?t=498241
franky69c10 is offline   Reply With Quote
Old 01-25-2012, 02:35 AM   #59
franky69c10
chevy runs deep
Originally Posted by 91Subbed View Post
The wiring is what gets me! It's looks confusing.
X2
RAIDER NATION
My LWB is a SWB now
Old 01-30-2012, 07:55 PM   #60
terry b
terry b's Avatar
That looks like some good work. About how many hours do you have into it so far?
terry b is offline   Reply With Quote
Old 01-30-2012, 11:06 PM   #61
y5mgisi
y5mgisi's Avatar
I think realistically, its about 30-40hrs on the actual swap itself. Thats not including any prep work like getting and cleaning the motor and all that junk. Latest pics,
Should be on the road next week.
Old 01-30-2012, 11:39 PM   #62
gringoloco
A guy with a truck
gringoloco's Avatar
Looking VERY nice
With the 1" setback adapter plates, did the trans bolt right up, or did it need to move?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 01-30-2012, 11:45 PM   #63
Ranger6202
What did you do to get the stock truck manifolds to fit? (sorry if you already described this) Mine just weren't gonna work, so i opted for the 2010 F-body manifolds that fit like the old 350 manifolds.
Ranger6202 is offline   Reply With Quote
Old 01-31-2012, 12:48 AM   #64
y5mgisi
y5mgisi's Avatar
The setback mounts put the motor mount exactly in the stock position. I used the truck manifolds. The passenger side fit no problem. The driver side took some cutting and welding on the down pipe to get it to work. FYI Trailblazer SS manifolds seem to fit really well.
Old 01-31-2012, 02:13 AM   #65
Ranger6202
One more question for ya. What did you do for the "in gear" wire to tell you pcm to idle down when you put it in gear. I know on the newer trucks the safety switch and "in gear" switch are the same switch. But on my '85, all i can find is the reverse light switch at the bottom of my column. I know i have a safety switch cause i could never start it in any other gear when i had the 350 in it, but i can't find it.
Old 01-31-2012, 02:24 AM   #66
y5mgisi
y5mgisi's Avatar
I didnt. Im going to see how it goes but lots of folks including a friend of mine dont have it hooked up and it behaves just fine. If i start to not like it i will figure out something to do with it.
Old 02-04-2012, 05:34 AM   #67
Mr. 250r
Mr. 250r's Avatar
i ended up using the edelbrock shorty headers that came on my 6.0 and they fit perfect on driver side but passenger need minimal amounts of hammer work and then fit im not worried about a small dent because notching my frame is out of question i didnt feel like spending extra money on manifolds because i need to get it done soon
2003 1500 Silverado
Old 02-04-2012, 08:03 PM   #68
y5mgisi
y5mgisi's Avatar
Cool! Yea if you can make the headers work you might as well use them! I got lucky yesterday and found out that a buddy of mine who recently put a 6.0 in a jeep still had his mechanical fan that i needed and gave it to me for free! So thats pretty awesome.
Also got a bunch of other little stuff done today. Just a couple little things to button up and then i still need to get a throttle cable and i will be good to go!
Old 02-16-2012, 01:53 PM   #69
y5mgisi
y5mgisi's Avatar
Recent pic. Just need an intake tube setup and I'll be ready to hit the road!
Old 02-16-2012, 02:20 PM   #70
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I found this site to be helpfull for the CAI parts.
http://intakehoses.com/?gclid=CPzyyd...FWdjTAodz2KU0w
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-16-2012, 09:15 PM   #71
y5mgisi
y5mgisi's Avatar
Thanks for that link! After i had my basket full of everything i needed(the "cobra head pieces are especially awesome!) i decided to check one more time on ebay for a factory one. Found one for $25 shipped! So, i ordered it up and hopefully it will work cause otherwise, my basket at intakehoses.com was about $100! Not to mention that i really want the look of the factory one anyway so i really hope this one works out! Here is the one i got,
http://www.ebay.com/itm/290670350586...84.m1439.l2649
Old 02-20-2012, 02:35 AM   #72
y5mgisi
y5mgisi's Avatar
Drove it for the first time tonight!
Old 02-20-2012, 10:41 AM   #73
85burb
85burb's Avatar
Well....how did it go...
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-20-2012, 09:39 PM   #74
y5mgisi
y5mgisi's Avatar
Went excellent! All i did was drive it up and down my dead end street twice. I got two really bad videos of it just for the file. Here they are.
Old 02-24-2012, 02:40 AM   #75
y5mgisi
y5mgisi's Avatar
Well i can say that its pretty much done! Few minor issues to wrap up but its pretty well ready to hit the highway! As usual, here is some videos!
