Old 08-16-2012, 02:07 AM   #51
tll74
"Junkyard Dog"
tll74's Avatar
Re: Serpentine belt conversions
Originally Posted by dbstepside View Post
any pics of a bbc setup, also what style p/s pump comes with this kit? also would you happen to have the air comp. delete pulley if so would setup be less $ without the compressor?
Here's some pics of one of two. They are both the same. The P/S pump is a conventional Saginaw pump with dual return ports. I don't have the delete pulley. I can do 60.00 less if I keep the AC pump. Thanks, Tom
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process.
http://s289.photobucket.com/albums/l...t=7eae161e.pbw
88 Monte Carlo SS bought new only 10k miles.
73 Chevelle SS 454 had since high school.
74 Camaro Z28 350 AT numbers matching, Black on Black.
73 El Camino SS 350 4sp.
70 Chevelle SS 396 4sp, number matching with LS6 454
69 Chevy C30 Car Hauler
86 K20 383 4sp 4" lift frame off restoration.
http://s289.photobucket.com/albums/l...t=1b1082d3.pbw
tll74 is offline   Reply With Quote
Old 08-16-2012, 02:14 AM   #52
tll74
"Junkyard Dog"
tll74's Avatar
Originally Posted by rushingg149 View Post
I'm looking for a set to put on a 1970 Chevy 1 ton with a 396 BB. What do you have that would work?
The kit just pictured would work.
Old 08-16-2012, 09:08 AM   #53
rushingg149
rushingg149's Avatar
What is the cost for the kit and the shipping to 75428 zip code? Would you please list everthing that is included? Please include payment instructions.
rushingg149 is offline   Reply With Quote
Old 08-17-2012, 01:01 AM   #54
tll74
"Junkyard Dog"
tll74's Avatar
I'll pull it off and picture it and that will answer what is included. Also I will be able to get shipping cost. Thanks, Tom
Old 08-18-2012, 12:22 AM   #55
tll74
"Junkyard Dog"
tll74's Avatar
Pics of the conversion after pulled off.
rushingg149 shipping is 80.26
dbstepside shipping is 85.36
Old 08-20-2012, 10:10 AM   #56
dbstepside
dbstepside's Avatar
thanks for the shipping quote but i'm gonna have to pass right now in process of trying to buy a 72 burb so out of funds right now. dennis
dbstepside is offline   Reply With Quote
Old 08-28-2012, 11:44 AM   #57
mr.wilson
Do you have any sbc complete kits left? If so are they detailed/natural and what is shipping to 19372?
Wilson
1972 Cheyenne LWB, 350ci TH-350.
Restoration in progress.
mr.wilson is offline   Reply With Quote
Old 08-30-2012, 05:56 PM   #58
tll74
"Junkyard Dog"
tll74's Avatar
Yes I have some left. Shipping is 78.65. It would be cleaned only. 100.00 extra to disassemble and detail. Thanks, Tom
Old 09-09-2012, 02:26 AM   #59
70K10Hunter
70K10Hunter's Avatar
Do you have any complete SBC kits left? and shipping to 92065
70K10Hunter is offline   Reply With Quote
Old 09-09-2012, 11:30 AM   #60
tll74
"Junkyard Dog"
tll74's Avatar
Yes I do and shipping would be 60.00 to Cali. I can check in the morning for a exact price but 60.00 is going to be very close. Thanks, Tom
Old 09-09-2012, 01:23 PM   #61
70K10Hunter
10-4 be waiting for total and payment info.
Old 09-09-2012, 11:53 PM   #62
SunSoaked
SunSoaked's Avatar
I was going to go this route before stumbling uopn my 91 setup ay a local junkyard. It's a good deal. I have mine on my motor but it wont actually run for awhile. I'll tell you in advance your going to need a new water neck because the angle of the one you have runs the upper radiator hose right into the serp belt.
Good luck
SunSoaked is offline   Reply With Quote
Old 09-10-2012, 01:23 AM   #63
70K10Hunter
thanks do you have a part# or a source for the correct neck? or do I buy one for the late model setup?
Old 09-10-2012, 01:25 AM   #64
70K10Hunter
Oh' I will be checking my local junkyard too, but these guys are expensive and I can't pull my own parts.
Old 09-10-2012, 09:58 AM   #65
SunSoaked
SunSoaked's Avatar
I meant the neck angles the hose into the back of the alternator. I would assume the late model has the correct angle neck since its still a small block. I didn't even think of it at the time. I'll let you know what I find out. tll74 might know what the fix is?
Old 09-10-2012, 02:58 PM   #66
tll74
"Junkyard Dog"
tll74's Avatar
I can get you the water neck to match the serp set up, no extra charge. As mentioned you will need to buy a new water pump. Order one for a 95 C/K 1500 if you want it to have the provision for the return heater hose. If not order it for a 89 C/K 1500. The early pump will give a cleaner look as it doesn't have a port to plug. PM sent
Thanks, Tom
Old 10-22-2012, 01:26 AM   #67
sduckworth13
sduckworth13's Avatar
I just bought a serpentine setup. I have a 1981 SBC with the dbl hump heads with the accessory bolt holes. What is the part number for the water pump I need?
Thanks,
Scott
Scott
sduckworth13 is offline   Reply With Quote
Old 10-22-2012, 01:36 AM   #68
sduckworth13
Tom, GATES Part # 43114 Water Pump (Standard); Cast Iron, Reverse Rotation, 2 Outlets, is this the one I need to use. This is the setup I have. part# 101187851 a/c bracket and part# 10118701 alternator bracket.
Scott
Old 10-29-2012, 07:29 PM   #69
tll74
"Junkyard Dog"
tll74's Avatar
Sorry for the delay just got back from a 9 day elk hunting trip. Yes, the description sounds correct. Thanks, Tom
Old 10-29-2012, 11:27 PM   #70
chevy6869
chevy6869's Avatar
still have any available? how do you go about the dummy pully for the ac?
chevy6869 is offline   Reply With Quote
Old 10-30-2012, 01:27 AM   #71
tll74
"Junkyard Dog"
tll74's Avatar
Yes, I still have some available for both the BBC and SBC. The idler that takes place of the AC pump is a hard find used but is still available new. I can check on the price of the idler and see how it it would afect the cost if your wanting a conversion. Thanks, Tom
Old 11-10-2012, 01:03 PM   #72
tll74
"Junkyard Dog"
tll74's Avatar
ttt...I have 2 sbc kits and 2 bbc kits
Old 11-28-2012, 08:38 AM   #73
TobyArnot
Quit if it's not FUN!!!
TobyArnot's Avatar
Originally Posted by TobyArnot View Post
Hey Tom,
What water pump does this use and can I find it locally? How much wiring trouble to replace old ext. reg. alt? Thanks
Well Tom, Some months later, but I think I'm ready. I would like conv. for Small Block with A/C, P/S, Alt. complete, shipped to 29708 ? ? Do you include the late model water neck?
Hope I can stand shipping
MY MOTTO:
Eat it all up, Wear it out,
Use the last few drops,
Spend all you've got,
Late in life, you'll think of the things you didn't do, not the things you did. - Get out and experience life !
Robbie Robinson a.k.a. TobyArnot (Toe Bee or not toe bee)
TobyArnot is offline   Reply With Quote
Old 11-28-2012, 09:08 AM   #74
dbcampbell3
I'm interest in a conversion for a small block if one is available.
dbcampbell3 is offline   Reply With Quote
Old 11-28-2012, 09:09 AM   #75
dbcampbell3
PM sent
