Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 02-29-2012, 11:18 PM   #51
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Re: 540 BBC 68 Burb Dually 54" Boggers on Rocks
Sweet burb! I guess part of the dually fender on the passenger side will open up with the door? While your at it why not round off the openings to match the front fenders a little more?
I love me some ice cold Colorado Kool Aid!
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 03-02-2012, 12:21 AM   #52
68burbanontherocks
68burbanontherocks's Avatar
Haha thanks man i sure do enjoy my rocky mountain water! I will end up rounding the fenders to match the fronts the only problem is that i need to put the front set of tires lined up with the front quarters to see if i need to do a little trimming.
With the rear passenger dually, it extends into the passender rear door. Just now it will go. Further onto the door. The problem is that it will cover up the door lock/handle so i guess i will buy a set of door poppers and shave the rear door and use a popper for the passenger doors since it comes in a set of 2. Ill still keep my driver door with the handle just incase there were to be a malfunction with the poppers ect. Let me know what ya think!
68burbanontherocks is offline   Reply With Quote
Old 03-06-2012, 01:41 AM   #53
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Sounds good, cant wait to see it!
Tony
Old 03-16-2012, 03:34 PM   #54
Cumminpwr11
Southern Nevada Coal Roller
What dually fenders are you using. I really want a dually burb. Your lines are killer
Chris
Chris
72 Suburban, 1 ton dodge chassis 4wd cummins, DTT 47rh 89%, PDR VE 3200 spring, PODS, Piers Turbo.
36 Chevy P/U rat rod project. 4bta cummins
Cumminpwr11 is offline   Reply With Quote
Old 04-04-2012, 02:07 PM   #55
68burbanontherocks
Chris
Hey buddy, sorry for the late response! I’ve been real busy but i actually looked at the fenders and one of my buddies has a 93 dually and the quarters are the same. Only difference is whoever had the fenders prior to me put a lot of body filler in them to close up some of the gaps and body lines. I’ve got a lot done on the truck though and ill post up pics here in the next few days. Started on the tube frame chassis, got the paint all off, sand blasted all the nooks and crannies, and clipped the drip pan on the sides.
As a side note I’m looking to sell the IFS/dana 60 8 lug dually set up as well as the wheels and tires that was on the truck prior to the rockwells. I only say that because you said you wanted a dually suburban Ill pm ya if your interested!
And oh yea thanks for the complement
Old 04-09-2012, 03:05 AM   #56
HeavyMetalChevy
Just a Member
HeavyMetalChevy's Avatar
sweet thread!!!!!!!!!!!!!!!
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st)
69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd)
70 C-20 88 350 long block rebuild .040 bore. forged crank
GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum
TH400(3rd)
71 SWB frame off with 68 body. POSI
PayPal: remimartin257@aol.com
Business Inquires: 812 801 5111
"Help me, help you" that's my motto
Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog
HeavyMetalChevy is offline   Reply With Quote
Old 04-24-2012, 10:28 AM   #57
68burbanontherocks
Picture updates soon to come!!!
Old 04-24-2012, 01:29 PM   #58
OneOffStroker
Nice progress.
Personally, I liked the slammed street dually, but originality and custom definitely dominate this build.
1972 C10 "Shop Truck" Build - EFI, 5-speed, Posi, and Patina http://67-72chevytrucks.com/vboard/s...d.php?t=834292
1957 Chevy pickup - Twin Turbo 5.3/NV3500, Jag IFS & IRS, AirRide http://67-72chevytrucks.com/vboard/s...d.php?t=606987
Check me out on YouTube - "Tiny Garage Fabrication" http://www.youtube.com/oneoffstroker
OneOffStroker is offline   Reply With Quote
Old 04-24-2012, 01:56 PM   #59
Southcity
Southcity's Avatar
great work! - subscribed
66 GMC Suburban Custom
66 Chevy K10 Suburban
Southcity is offline   Reply With Quote
Old 04-25-2012, 10:40 AM   #60
68burbanontherocks
Originally Posted by OneOffStroker View Post
Nice progress.
Haha thanks man, yea to each his own i guess. Theres going to be a lot of people that think it is stupid or gaudy yadda yadda which is fine to me as long as they recognize and appreciate the fab work that went into it thats all i can ask for!
Old 04-25-2012, 10:41 AM   #61
68burbanontherocks
Thanks buddy! Im gonna post up some pics here in a bit to make sure to keep following the progress and any tips and critisism is greatly appreciated alike.
Old 04-25-2012, 10:47 AM   #62
68burbanontherocks
So ive been meaning to post some more up to date pics but they were all on my phone. I get bad about not taking pics during the work cause i just get cought up in what im doing and documenting it is just an after thought. So heres where im at right now....
1. Clipped the drip pan off the sides and tach welded the roof down.
2. Replaced the rocker box on the drivers side.
3. Lots of little body work here and there filling gaps n such.
4. Building a tube frame chassis. All 2" .120 wall DOM tubing.
Old 04-25-2012, 10:51 AM   #63
68burbanontherocks
Drip pan before clip
Old 04-25-2012, 10:55 AM   #64
68burbanontherocks
back side sorry about lighting
Old 04-25-2012, 10:58 AM   #65
68burbanontherocks
Driver Side applying some mud...
Old 04-25-2012, 10:59 AM   #66
68burbanontherocks
Rear of drivers side after sanding.
Old 04-25-2012, 11:06 AM   #67
68burbanontherocks
So in order to start building my tube frame chassis i needed a flat, level, and even surface in order to make sure the tube was all 100% square. So one of my friends has a shop where im going to build the chassis so i had to transport my old chassis and tires as well as material to his house...
Old 04-25-2012, 11:10 AM   #68
68burbanontherocks
Just tooling around pics with my helpers. Dude in the red shirt owns Mad Hatter Customs, does some legit work and sends a good bit of stuff off to SEMA every year. Old hippy guy with the white shirt is the owner of the shop who is graciously letting me using his space!
Old 04-25-2012, 11:15 AM   #69
68burbanontherocks
Ah now for the chassis design stuff, i just started on saturday so its goin kinda slow but heres where im at as of last night 4/24/12, almost have one half done. An incredible amount of knotching and a huge learning curve!!! Not to mention that at 7 bucks a foot very expensive mistakes!
Old 04-25-2012, 11:19 AM   #70
68burbanontherocks
Just more tubing pics. Last pic is a tube knotching software program called tube miter. Allows you to make accurate copes by entering the size of the materials being knotched together and angle... pretty sweet if your a cheap skate and dont want to shell out the cash for a trick tools knotcher!
Old 04-25-2012, 11:23 AM   #71
68burbanontherocks
More poser tubing pics... The last 2 pics are at 11 hours of fab work.
Old 04-25-2012, 11:28 AM   #72
68burbanontherocks
Day 2. end pic is at 21 hours...
Old 04-25-2012, 11:31 AM   #73
68burbanontherocks
oops not that end pic this end pic is at 21 hours! haha
Old 04-25-2012, 11:33 AM   #74
68burbanontherocks
Just welding on some cheap pipe to make sure the gaps from the knotched copes would be able to be welded with out warping the material real bad...
Old 04-25-2012, 12:29 PM   #75
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Insane work man!
Tony
54" boggers, big block, dually, monster truck, suburban
