Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The pre 1947 Chevrolet & GMC Truck Message Board
Old 01-07-2013, 12:29 AM   #51
old yelr
Re: 1940 "project moonshine"
Hey Chizzler, let me know what you find out from Steele Rubber. I would be interested in getting one that's like the original. As far as putting up pics, I'm still collecting parts for the project so no "real" progress yet but I love what you and paintman are doing! When I get to a point where I can start I'll put something up here.
old yelr is offline   Reply With Quote
Old 01-07-2013, 12:33 AM   #52
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
sounds good.glad to help if i can.
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 01-07-2013, 07:41 PM   #53
CHIZZLER
CHIZZLER's Avatar
found out from steele rubber today that the the back window gasket does not come with holes in it.they are drilled once it is in place.it is a vulcanized 1 piece seal.
61-crew cab D-max
Old 01-07-2013, 07:57 PM   #54
old yelr
So do you think there is a down side to using the less expensive one from Jim Carter or similar place? For the cost difference it might be worth it to experiment with it and if it turns out to be less than satisfactory it's really not that big a deal.
I was going to put a couple of pictures up on here of what my truck looked like when I got it but I'm not sure how to do that.
Old 01-07-2013, 08:01 PM   #55
CHIZZLER
CHIZZLER's Avatar
i do think buying the $19 one would be worth it.thats a $70 savings.if the pics are in your computer you go to advanced then click the manage attachments and it will direct you.
61-crew cab D-max
Old 01-07-2013, 08:44 PM   #56
old yelr
I tried several times to upload pictures but I keep getting a "security tag missing" message. Maybe my files are too large. I'll try again later
Old 01-07-2013, 09:09 PM   #57
paintman
Hey Chizz! If you have a chance can you take a couple of close up pics of how you mounted your bumper. It looks like you made some kind of pockets for it. It looks as if you and I ran into the same trouble with our sway bars where we had to make extensions to the frame rails. I was trying to figure out the best way to mount my bumper. I might copy yours if ya don't mind. I was just going to through bolt into the frame extensions I made, but your deal might help solve a couple of other problems I have.
paintman is offline   Reply With Quote
Old 01-07-2013, 09:26 PM   #58
CHIZZLER
CHIZZLER's Avatar
on my year truck the bumper bracket would have bolted flat onto the frame horns.we had to cut them off when we channeled the cab.we ended up cutting up the used brackets i got and welding them to the frame.we kinda just made it work.your extended frame horns might need to be cut down not to interfere with the front fenders.my sway bar mount is only a few inches from the bumper bracket cut outs.
61-crew cab D-max
Old 01-07-2013, 09:36 PM   #59
paintman
Overall I think the frame is about an 1 1/2 longer then stock. My bumper originaly bolted to 2 bumper horns that slid up into the frame and then had a bolt run through them from the top of the frame and nutted on the bottom. With the sway bar bushing mounts now having nuts on the inside of the frame it doesn't allow me to slide those horns back in to there original spot. that's why I thought those pockets you made looked pretty slick.
Old 01-07-2013, 09:43 PM   #60
CHIZZLER
CHIZZLER's Avatar
we threw the horns out and welded to the outside of the frame.if you already have bumper brackets then just fit them and bend a little and make them work.
61-crew cab D-max
Old 01-09-2013, 12:05 PM   #61
CHIZZLER
CHIZZLER's Avatar
finally the air tank showed up.we set it up behind the gas tank and made a louvered panel to fill the back where the bed floor came up.we also got the firewall holes filled and finished the cab and cleaned up all the welds.next will be sand blasting the cab.thanks chizzler.
61-crew cab D-max
Old 01-09-2013, 06:39 PM   #62
paintman
Damn!!!!!!!!!!!!!!!!!!!!!!!!
Old 01-14-2013, 12:17 AM   #63
CHIZZLER
CHIZZLER's Avatar
few updates.blew everything apart for blasting.cleaned up the firewall and final welded the frame. one heck of a pile to blast.maybe get everything blasted and epoxied soon.
61-crew cab D-max
Old 01-17-2013, 09:01 PM   #64
docrock
docrock's Avatar
your project looks very cool. Cant you use glass setting tape around the back window and then screw it together with the diecast trim? Are you using the stock glass with the metal frames in the side windows?
1954 GMC on 93 Silverado chassis http://67-72chevytrucks.com/vboard/s...d.php?t=408344
1942 Chevy 1/2 ton Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=429494
R.I.P. TOM SEFFRON 68 FOUR DOOR http://67-72chevytrucks.com/vboard/s...d.php?t=495438
1942 Chevy that ate my brain 70 Chassis https://67-72chevytrucks.com/vboard/...d.php?t=835250
docrock is offline   Reply With Quote
Old 01-18-2013, 08:55 PM   #65
CHIZZLER
CHIZZLER's Avatar
i found the gasket im going to use for the rear its from chevs of the 40's.i am going to use the metal frames for the side windows.
61-crew cab D-max
Old 01-18-2013, 09:00 PM   #66
CHIZZLER
CHIZZLER's Avatar
Couple updates.boss got all the chassie parts blasted and most of it epoxied.did some seam sealing on the cab and next will be undercoating the bottom of the cab and raptor lining the inside of the cab.more to come.chizzler
61-crew cab D-max
Old 01-20-2013, 11:32 PM   #67
CHIZZLER
CHIZZLER's Avatar
got the chassie all back together.
61-crew cab D-max
Old 01-21-2013, 11:32 AM   #68
Scottshotrods
Coming along really good!!!!
Justin
Scottshotrods is offline   Reply With Quote
Old 01-21-2013, 10:03 PM   #69
CHIZZLER
CHIZZLER's Avatar
couple updates.raptor liner and undercoating are done.started tearing down motor for new cam kit and all new gaskets.thanks
61-crew cab D-max
Old 01-21-2013, 10:28 PM   #70
hopped up
hopped up's Avatar
Frame looks great!! So do the seams on the floor
hopped up is offline   Reply With Quote
Old 01-22-2013, 04:02 PM   #71
docrock
docrock's Avatar
this is so cool. thanks for the update and pics
Old 01-22-2013, 07:13 PM   #72
Luther Grimace
Luther Grimace's Avatar
Awesome build.
1955.2 Chevy 3100, 6bt, Getrag G360 5-speed, NP205, Dana 60/70 - http://67-72chevytrucks.com/vboard/s...d.php?t=536540
1992 Chevy K1500 Silverado ECSB
1965 "Crewcab" Chevelle 300 Deluxe - soon to be LBZ Duramax/4L85E powered
Luther Grimace is offline   Reply With Quote
Old 01-22-2013, 07:20 PM   #73
LEEVON
LEEVON's Avatar
My new favorite build thread. I'm already sad for when it's done!
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 01-22-2013, 08:51 PM   #74
CHIZZLER
CHIZZLER's Avatar
thanks everyone.it has been a fun build.everyones support really keeps me motivated.leevon i cant wait till you get that truck done.docrock there is a link to my burban build on my posts.chizzler
61-crew cab D-max
Old 01-23-2013, 09:54 PM   #75
paintman
Hey Chizz,? Your fuel tank, is that a standard tank or stainless???????? I see where I can get a stainless one for only $70 more then plain steel.
