#51 |
Re: 1970 Burn Victim
my fiance took some engagement pictures with the truck...my fiance has named the truck Roxy. The photographer did great with the truck!
#52 |
Ok figured out the pictures are too large to post when I figure out how to shrink them I will post them
Posted via Mobile Device |
#53 |
Ok finally figured out this re-sizing thing...
Just trying to figure this out... 1970 SWB Step-Side http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=584499 1970 SWB One Owner Step Side 6.0 LY6/6L90 http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide http://67-72chevytrucks.com/vboard/s...86#post7531186 |
#54 |
two more
#55 |
![]() Join Date: Jul 2009
Nice pictures! See you in a couple weeks.
Rick 78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel 71 GMC C25 350/TH400 - Project Angie 59 Chevy SWB Stepside (next in line? Not sure now ![]() 2001 GMC Sierra K2500 |
#56 |
Yup!
#57 |
OK I am looking at installing a sway bar-which I already have. I installed one on my other '70 and really like it. This truck sits a little lower, does anyone have any suggestions on the frame brackets to suck it closer? I have power steering, so I can't bolt it directly to the frame. I use the ECE brackets on my last install just curious what else is out there.
#58 |
Still Learning
Dang! I love this truck! One of the nicest steppers I've seen on here. I go right through your town on my annual pilgrimage to Zapata. Thanks for sharing all the pictures.
#59 | |
I got some new wheels and tires a few days ago. I am trying to keep up with this truck while building another 6.0 '70. I went with a bigger tire in the back so that the front will have enough room to turn and the back will have enough meat to hook...sorta ![]()
#60 |
rear tire size
#61 |
the wheels and tires from this truck are going to the 6.0 build...until I melt them away
#62 |
Still Learning
Very nice new tires and wheels.
#63 |
Thank you so much. I was a bit nervous, but I think they turned out well.
#64 |
Nice choice on the wheels and tires.
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
#65 |
Looks good, I like me some old school chrome.
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
#66 |
The old wheels were sharp, but these look a lot more correct. Looks great (and shiney)!
#67 |
2WD Jimmy
![]() Join Date: Mar 2005
Perfect!
#68 |
Well it was time for some maintenance this week. My speedo has not been working for a while so I decided to track down the problem. I found out the speedo gear on the tailshaft had come loose and stripped the inner ring out so it no longer stays in place. I dropped the drive shaft and removed the trans tail shaft cover and then removed the gear located on the tail shaft. It was completely out of place amd no longer making contact with the speedo gear that attaches to the speedo cable...time to order a new gear. It is currently torn down in my garage...bummer.
While I was under my truck I noticed the exaughst was loose so tighter it up at well...then snap I broke a bolt...wonderful. I then pulled the manifold off and realized that a second bolt was bent so I replaced both of them. It was also time for some new exaughst manifold gaskets so I bought a set. Now time for everything to go back together...
#69 |
It's always something. Jared and I just spent 4-5 hours this weekend replacing his catalytic converter that should have been take out 4 bolts, replace converter and bolt back up. You can probably guess why 4 bolts on exhaust took so long
#70 | |
#71 |
![]() Join Date: Aug 2012
It's good to see someone save a old truck like that. You want be sorry for it. Take care George
Check out Patches Cars I owned in the past. 1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev 1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS 1967 Buick electra 225 1995 Harley Davidson bager What does not kill you will make you stronger 1968 c10 short wheel base stepper |
#72 |
Still Learning
You have to love routine maintenance. Especially when it throws a curve ball. Looks like you got it under control. Sure love this red truck! Keep on trucking.
#73 |
I got the truck all cleaned up yesterday for Valentine's Day. Its been a while since it was this clean!
#74 |
Man that's Purdy!
#75 |
'merica
Happy 4th everyone.
